Disable frame batching from same stream - batch only from different streams in Deepstream
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2 Triton
• TensorRT Version 8.5.2
• NVIDIA GPU Driver Version (valid for GPU only) Driver Version: 525.85.05 CUDA Version: 12.0
• Issue Type( questions, new requirements, bugs) Question
  1. Use old nvstreammux, set batch size > 1
  2. Use multisrcbin, set max batch size > 1
I am using a pipeline with LSTM model with dynamic batching. Since I am using a statefull model, I need to disable batching of frames from the same stream, but allow batching of frames from several streams.
I currently cannot find how to perform this.
Any insights?
Guy
please refer to nvstreammux’s doc doc, especially here "The muxer uses a round-robin algorithm to collect frames from the sources. It tries to collect an average of (batch-size/num-source) frames per batch from each source ", you might set nvstreammux 's batch-size to source 's num.
