• Hardware Platform (Jetson / GPU) dGPU (T4)
• DeepStream Version 6.2
• TensorRT Version n/a
• NVIDIA GPU Driver Version (valid for GPU only) 525.125.06
• Issue Type( questions, new requirements, bugs) question
Howto configure the new nvstreammux for processing offline (file source and not syncing to clocks in the sink), with a single file source, with batching (of that single file source)?
Pipeline is trivial ( uridecodebin → nvstreammux → queue → fakesink sync=“false” )
My last try is something like that:
streammux.set_property('batch-size', 4)
and a config file:
"[property]\n"
"adaptive-batching=0\n"
"overall-max-fps-n=10000\n"
"overall-max-fps-d=1\n"
"overall-min-fps-n=1\n"
"overall-min-fps-d=1\n"
"max-fps-control=0\n"
I have probes after decoder and after the mux, and they show something like that:
2023-08-09 14:34:47.028 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 0.0
2023-08-09 14:34:47.043 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 66.0
2023-08-09 14:34:47.043 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 132.0
2023-08-09 14:34:47.048 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 198.0
2023-08-09 14:34:48.029 | DEBUG | __main__:streammux_src_buffer_probe:52 - streammux src probe: gst buf pts: 65.93
2023-08-09 14:34:48.029 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 0.0 batch_id 0
2023-08-09 14:34:48.030 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 264.0
2023-08-09 14:34:49.029 | DEBUG | __main__:streammux_src_buffer_probe:52 - streammux src probe: gst buf pts: 131.86
2023-08-09 14:34:49.029 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 66.0 batch_id 0
2023-08-09 14:34:49.030 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 330.0
2023-08-09 14:34:50.029 | DEBUG | __main__:streammux_src_buffer_probe:52 - streammux src probe: gst buf pts: 197.79
Note the streammux outputting not-batched data AND every one second (probably owning to the overall-min-fps config). I’d expect it to output batched data (4 frames per buffer) quickly (as fast as hardware decoder decodes).
Attaching the pipeline dot as well:
The “old” nvstreammux with following config:
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batched-push-timeout', 4000000)
streammux.set_property('live-source', False)
behaves as expected:
2023-08-09 14:39:20.089 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 0.0
2023-08-09 14:39:20.103 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 66.0
2023-08-09 14:39:20.103 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 132.0
2023-08-09 14:39:20.108 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 198.0
2023-08-09 14:39:20.108 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 264.0
2023-08-09 14:39:20.108 | DEBUG | __main__:streammux_src_buffer_probe:52 - streammux src probe: gst buf pts: 0.0
2023-08-09 14:39:20.108 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 0.0 batch_id 0
2023-08-09 14:39:20.108 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 66.0 batch_id 1
2023-08-09 14:39:20.108 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 132.0 batch_id 2
2023-08-09 14:39:20.109 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 198.0 batch_id 3
2023-08-09 14:39:20.122 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 330.0
2023-08-09 14:39:20.122 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 396.0
2023-08-09 14:39:20.127 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 462.0
2023-08-09 14:39:20.127 | DEBUG | __main__:decoder_src_buffer_probe:45 - decoder src probe: buf pts: 527.0
2023-08-09 14:39:20.127 | DEBUG | __main__:streammux_src_buffer_probe:52 - streammux src probe: gst buf pts: 65.93
2023-08-09 14:39:20.127 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 264.0 batch_id 0
2023-08-09 14:39:20.127 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 330.0 batch_id 1
2023-08-09 14:39:20.127 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 396.0 batch_id 2
2023-08-09 14:39:20.127 | DEBUG | __main__:streammux_src_buffer_probe:60 - streammux src probe: frame pts: 462.0 batch_id 3
