DeepStream 6.4 Aborted (core dumped)
GPU RTX 2080
• DeepStream Version
6.4
• TensorRT Version
default tensorrt in 6.4 nvcr.io/nvidia/deepstream:6.4-triton-multiarch
| NVIDIA-SMI 535.183.01
Driver Version: 535.183.01
CUDA Version: 12.2 |
bugs
with this dockerfile
FROM nvcr.io/nvidia/deepstream:6.4-triton-multiarch AS base
ENV DEBIAN_FRONTEND=noninteractive
RUN /opt/nvidia/deepstream/deepstream/user_additional_install.sh
RUN apt-get update && apt install -y python3.10-venv
RUN python3 -m pip install --upgrade pip
RUN pip3 install redis paho-mqtt opencv-python packaging
RUN curl -O -L https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/releases/download/v1.1.10/pyds-1.1.10-py3-none-linux_x86_64.whl
RUN pip3 install ./pyds-1.1.10-py3-none-linux_x86_64.whl
then running
Working directory /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test3.
deepstream_test_3.py -i rtsp://admin:password@192.168.4.170:8554/ppe_basic.mp4 --no-display
i get
0:00:04.011101800 17825 0x55559384e110 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b1_gpu0_int8.engine
[New Thread 0x7fff7d7fe640 (LWP 17843)]
[New Thread 0x7fff7cffd640 (LWP 17844)]
[New Thread 0x7fff67fff640 (LWP 17845)]
0:00:04.014986093 17825 0x55559384e110 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest3_pgie_config.txt sucessfully
[New Thread 0x7fff677fe640 (LWP 17846)]
Decodebin child added: source
[New Thread 0x7fff66ffd640 (LWP 17847)]
[New Thread 0x7fff667fc640 (LWP 17848)]
[New Thread 0x7fff65ffb640 (LWP 17849)]
[New Thread 0x7fff657fa640 (LWP 17850)]
Thread 18 "pool-python3" received signal SIGABRT, Aborted.
[Switching to Thread 0x7fff657fa640 (LWP 17850)]
0x00007ffff7ce59fc in pthread_kill () from /lib/x86_64-linux-gnu/libc.so.6
(gdb) Quit
(gdb) pwd
RUN /opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh --build-bindings -r v1.1.10
Please install the pyds dependencies correctly, add the above content to your dockerfile, and remove the following two items
thank you @junshengy,
after updating the nvidia driver to
| NVIDIA-SMI 560.35.03, CUDA Version: 12.6
i tried directly with deepstream 7.1 with this dockerfile and it worked
FROM nvcr.io/nvidia/deepstream:7.1-gc-triton-devel AS base
ENV DS_VERSION=7.1.0
RUN /opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh --version 1.2.0
i had to change something in the pipeline/python probes from my old codebase btw, i think something changed beetween DS 6.2 (which i’m migrating from) and DS 7.1, in particular, this pipeline working in DS 6.2
demux.src_0 ! nvvideoconvert nvbuf-memory-type=3 \
! video/x-raw,format=RGBA \
! nvvideoconvert nvbuf-memory-type=3 name=videoconv
became
demux.src_0 ! nvvideoconvert name=videoconv
and the probe to videoconv it’s changed from (working in DS 6.2. but giving SEG FAULT in DS 7.1)
 def videoconv_probe(self, pad, info, u_data):
        try:
            buffer = info.get_buffer()
            if not buffer:
                print("Unable to get GstBuffer")
                return
            caps = pad.get_current_caps()
            success, map_info = buffer.map(Gst.MapFlags.READ)
            try:
                if not success:
                    return Gst.PadProbeReturn.DROP
                batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buffer))
                l_frame = batch_meta.frame_meta_list
                while l_frame is not None:
                    try:
                    except StopIteration:
                        break
                    frame_number = frame_meta.frame_num
                    l_obj = frame_meta.obj_meta_list
                    try:
                        l_frame = l_frame.next
                        break
            finally:
                buffer.unmap(map_info)
             rgb_frame = np.ndarray(
                shape=(
                    caps.get_structure(0).get_value("height"),
                    caps.get_structure(0).get_value("width"),
                    4,
                dtype=np.uint8,
                buffer=map_info.data,
        except Exception as e:
            print('caught exception in videoconvs_probe')
            print (traceback.format_exc())
        return Gst.PadProbeReturn.OK
to (following the example in deepstream python apps)
        frame_number = 0
        print('video conv probe', frame_number)
        num_rects = 0
        gst_buffer = info.get_buffer()
        if not gst_buffer:
            print("Unable to get GstBuffer ")
            return
        batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
            try:
                # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
                # The casting is done by pyds.NvDsFrameMeta.cast()
                # The casting also keeps ownership of the underlying memory
                # in the C code, so the Python garbage collector will leave
                # it alone.
                break
            is_first_obj = True
            while l_obj is not None:
                try:
                    # Casting l_obj.data to pyds.NvDsObjectMeta
                    obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                    break
                if is_first_obj:
                    is_first_obj = False
                    n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
                    # convert python array into numpy array format in the copy mode.
                    frame_copy = np.array(n_frame, copy=True, order='C')
                    # convert the array into cv2 default color format
                    rgb_frame = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGRA)
                try:
                    l_obj = l_obj.next
                    break
            try:
                break
am i migrating correctly?
another question, now that i installed for DS 7.1
560.35.03 + cuda 12.6
am i able to run DS 6.4 that requires
525.125.06 + cuda 12.1
on the same machine by changing the docker container?
thank you, William
The above pipeline could be simplified, The following pipelines should work for DS-6.4/DS-7.1 on dGPU. Add the probe at capsfilter src pad.
demux.src_0  !  nvvideoconvert  nvbuf-memory-type=3  ! video/x-raw(memory:NVMM),format=RGBA name=capsfilter !
The image contains the corresponding version of cuda, no additional installation is required. Generally speaking, if the driver has been installed correctly, you can use the docker images of DS-6.4 and DS-7.1 at the same time
this actually works, what am i missing?
ok i narrowed down the problem
this works in DS 6.2, but not in DS 7.1
gst-launch-1.0 nvstreammux sync-inputs=0 nvbuf-memory-type=3 name=mux enable-padding=true batch-size=1 width=1282 height=722 \
! nvinfer  name="primary_inference" config-file-path="config.txt" batch-size=1 \
model-engine-file="model_b1_gpu0_fp16.engine" \
! nvstreamdemux name=demux \
uridecodebin uri="rtsp://admin:password@192.168.4.170:8554/ppe_basic.mp4" name=source_0 \
! nvvideoconvert name=source_videoconv_0 nvbuf-memory-type=3 ! queue name=queue_0 leaky=2 max-size-buffers=1 ! mux.sink_0 \
Please follow the method I mentioned above to build the pipeline. pyds.get_nvds_buf_surface only support RGBA/RGB color Format currently.
In addition, there is no need to convert multiple times. Reducing unnecessary conversions optimizes performance
ok i followed your advice and it seems to be working with 1 source
nvstreammux sync-inputs=0 live-source=1 attach-sys-ts=TRUE nvbuf-memory-type=3
! nvinfer name="primary_inference" interval=5 config-file-path=config.txt batch-size=1
nvurisrcbin rtsp-reconnect-attempts=-1 rtsp-reconnect-interval=10
uri="rtsp://admin:********@192.168.10.185/h264Preview_01_sub" name=source_0 ! mux.sink_0
! fakesink name=sink0
but it’s not working with multiple sources
name=mux enable-padding=true batch-size=2 width=1282 height=722
! nvinfer name="primary_inference" interval=5 config-file-path=config.txt batch-size=2
model-engine-file="model_b2_gpu0_fp16.engine"
nvurisrcbin rtsp-reconnect-attempts=-1 rtsp-reconnect-interval=10 uri="rtsp://admin:***************@192.168.10.220:8554/ppe_basic.mp4" name=source_0 ! mux.sink_0
nvurisrcbin rtsp-reconnect-attempts=-1 rtsp-reconnect-interval=10 uri="rtsp://admin:****************@192.168.10.185/h264Preview_01_sub" name=source_1 ! mux.sink_1
demux.src_1 ! nvvideoconvert nvbuf-memory-type=3 ! video/x-raw(memory:NVMM),format=RGB
! fakesink name=sink1
the code of the probe is
    def raw_probe(self, pad, info, u_data):
        if not gst_buffer:
            return
        print('raw_probe')
            try:
                break
            stream_index = frame_meta.pad_index
            is_first_obj = True
                try:
                    break
                if is_first_obj:
                try:
                    l_obj = l_obj.next
                    break
            try:
                break
what happens with two sources is that the print(‘raw_probe’) is executed only once, then it hangs
thank you in advance for your advice
In GStreamer, a queue element is the thread boundary element through which you can force the use of threads.
Queues are recommended after nvstreamdemux source pads
Try the following pipeline
gst-launch-1.0 nvurisrcbin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_ride_bike.mov gpu-id=0 ! mux.sink_0 \
               nvurisrcbin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_ride_bike.mov gpu-id=0 ! mux.sink_1 \
               nvstreammux name=mux gpu-id=0 batch-size=2 width=1920 height=1080 live-source=1 batched-push-timeout=40000 nvbuf-memory-type=3 ! \
               nvinfer gpu-id=0  batch-size=2 config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt ! \
               nvstreamdemux name=demux demux.src_0 ! queue ! nvvideoconvert nvbuf-memory-type=3 ! "video/x-raw(memory:NVMM),format=RGBA" ! fakesink name=sink0 \
                                        demux.src_1 ! queue ! nvvideoconvert nvbuf-memory-type=3 ! "video/x-raw(memory:NVMM),format=RGBA" ! fakesink name=sink1
ok now it works, thank you, can i ask how the batched-push-timeout=40000 is calculated? thank you
This issue should be caused by adding queue instead of setting batched-push-timeout
