• Hardware Platform (Jetson / GPU) : dGPU、Jetson
• DeepStream Version : 6.0、6.1
• JetPack Version (valid for Jetson only) : 4.6(DS6.0)、5.0.2(DS6.1)
• TensorRT Version : 8.0.1(DS6.0)、8.4.1(DS6.1)
• NVIDIA GPU Driver Version (valid for GPU only) : 525.147.05
• Issue Type( questions, new requirements, bugs) : questions
I want to use new nvstreammux element.
But I sometimes get this message, when I run this command to use new nvstreammux on dGPU(DS6.0、DS6.1) and Jetson(DS6.0、DS6.1) .
What does the message「[ERROR push 317] push failed [-5]」 mean?
I run this command in the docker container.
- nvcr.io/nvidia/deepstream:6.0.1-devel
- nvcr.io/nvidia/deepstream-l4t:6.0-samples
- nvcr.io/nvidia/deepstream:6.1-devel
- nvcr.io/nvidia/deepstream-l4t:6.1.1-samples
command (If you cannot reproduce it, run it again and again.)
USE_NEW_NVSTREAMMUX=yes gst-launch-1.0 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_0 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12" ! mux.sink_0 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_1 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_1 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_2 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_2 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_3 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_3 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_4 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_4 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_5 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_5 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_6 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_6 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_7 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_7 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_8 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_8 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_9 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_9 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_10 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_10 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_11 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_11 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_12 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_12 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_13 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_13 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_14 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_14 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 name=source_15 ! tee ! queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12"! mux.sink_15 \
nvstreammux name=mux batch-size=16 ! \
nvstreamdemux name=demux \
demux.src_0 ! fakesink async=false
DeepStream 6.0 output (dGPU)
max_fps_dur 8.33333e+06 min_fps_dur 2e+08
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:26.270019690
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
