I am trying to modify the 5_Simulation/particles example so that it runs in headless mode.
I took out calls from OpenGL, I make them manually in a loop, I set
bUseOpenGL to false everywhere,
In particles.cpp
int
main(int argc, char **argv)
numParticles = NUM_PARTICLES;
uint gridDim = GRID_SIZE;
gridSize.x = gridSize.y = gridSize.z = gridDim;
printf("grid: %d x %d x %d = %d cells\n", gridSize.x, gridSize.y, gridSize.z, gridSize.x*gridSize.y*gridSize.z);
printf("particles: %d\n", numParticles);
//initGL(&argc, argv);
cudaInit(argc, argv);
initParticleSystem(numParticles, gridSize, false);
initParams();
for (int i=0;i<1000;i++){
display();
exit(0);
void display()
psystem->setIterations(iterations);
psystem->setDamping(damping);
psystem->setGravity(-gravity);
psystem->setCollideSpring(collideSpring);
psystem->setCollideDamping(collideDamping);
psystem->setCollideShear(collideShear);
psystem->setCollideAttraction(collideAttraction);
psystem->update(timestep);
psystem->dumpParticles();
In particleSystem.cpp method dumpParticles(),
void
ParticleSystem::dumpParticles()
uint start = 0;
uint count = 16384;
// debug
copyArrayFromDevice(m_hPos, 0, &m_cuda_posvbo_resource, sizeof(float)*4*count);
copyArrayFromDevice(m_hVel, m_dVel, 0, sizeof(float)*4*count);
for (uint i=start; i<start+count; i++)
xfile << m_hPos[i*4+0] << ":";
yfile << m_hPos[i*4+1] << ":";
zfile << m_hPos[i*4+2] << ":";
xfile << std::endl;
yfile << std::endl;
zfile << std::endl;
The first copyArrayFromDevice call fails with
CUDA error at particleSystem_cuda.cu:90 code=400(cudaErrorInvalidResourceHandle) "cudaGraphicsMapResources(1, cuda_vbo_resource, 0)"
Any ideas why this could be?
Note: if I enable initGL call and set bUseOpenGL to true everything works fine.
I am using Jetson Nano,
R32 (release), REVISION: 4.4, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_21:14:42_PDT_2019
Cuda compilation tools, release 10.2, V10.2.89
