Discrepancy in NVIDIA-SMI and Driver Version, CUDA Installation Issues
Hello NVIDIA Community,
I’m encountering some unusual behavior with my NVIDIA driver and CUDA installation on RHEL 8, and I’m hoping someone can provide some insight or guidance.
Current Setup
  • Operating System: RHEL 8
  • GPU: NVIDIA A40
Issue Description
  1. I installed the recommended Nvidia drivers after selecting my product and OS specs from -Driver Details | NVIDIA. After the successful installation, I run nvidia-smi to get:
    NVIDIA-SMI 535.183.06 Driver Version: 560.28.03 CUDA Version: 12.2
I’m confused by the discrepancy between the NVIDIA-SMI version (535.183.06) and the Driver Version (560.28.03) . Does the output from NVIDIA-SMI version and the Driver Version has to be the same?
2)I’ve attempted to install CUDA 12.6 since driver version said 560 using the following commands from the nvidia-website:
wget https://developer.download.nvidia.com/compute/cuda/12.6.0/local_installers/cuda-repo-rhel8-12-6-local-12.6.0_**560.28.03**-1.x86_64.rpm
sudo rpm -i cuda-repo-rhel8-12-6-local-12.6.0_560.28.03-1.x86_64.rpm
sudo dnf clean all
sudo dnf -y install cuda-toolkit-12-6
The installation was successful but then I got the unsupported display driver / cuda driver
combination error when I try to run a simple cuda test application. So I thought the driver
is actually 535 and thus installed cuda 12.2 which was successful but I got the same error again
3When I try to compile a CUDA program, I get an error suggesting an incompatibility:
unsupported display driver / cuda driver combination
4)Questions
Is the discrepancy between NVIDIA-SMI version and Driver Version normal? If not, what might be causing this?
Could this discrepancy be the reason for the CUDA compilation error?
How can I resolve this issue and successfully compile and run CUDA programs?
Is there a way to ensure that the NVIDIA-SMI version and Driver Version are the same?
Snapshots:
$ nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Tue_Jun_13_19:16:58_PDT_2023
Cuda compilation tools, release 12.2, V12.2.91
Build cuda_12.2.r12.2/compiler.32965470_0
1 ~]$ nvidia-smi
Wed Aug 21 12:43:23 2024
| NVIDIA-SMI 535.183.06 Driver Version: 560.28.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A40 Off | 00000000:17:00.0 Off | 0 |
| 0% 33C P0 80W / 300W | 0MiB / 46068MiB | 0% Default |
| | | N/A |
| 1 NVIDIA A40 Off | 00000000:65:00.0 Off | 0 |
| 0% 33C P0 78W / 300W | 0MiB / 46068MiB | 0% Default |
| | | N/A
Error message while running a simple test cuda file: ~]$ ./cuda_check
Failed to launch kernel (error code system has unsupported display driver / cuda driver combination)!
