I set up a WSL2 environment to run neural network training and I tried to install Cuda 11.7 for this. But if I run “nvidia-smi” it all looks messed up and I don’t know how to continue. While loading my neural network I also get errors.
libEGL warning: failed to open /dev/dri/renderD128: Permission denied
Unable to initialize EGL
Do I get the errors because of the messed up drivers? Am I supposed to set up a whole new WSL2 system? I am pretty new to all of this stuff so I am pretty sure I did a mistake at any point, but I don’t know where and how to fix it.
Here is the nvidia-smi and nvcc --version output:
kiropro@DESKTOP-JC8EGB7:~/PoseCNN-PyTorch$ nvidia-smi
Tue Feb 21 15:20:39 2023
| NVIDIA-SMI 525.89.02 Driver Version: 528.49 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:01:00.0 On | Off |
| 0% 34C P8 15W / 450W | 1323MiB / 24564MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 27 G /Xwayland N/A |
kiropro@DESKTOP-JC8EGB7:~/PoseCNN-PyTorch$ nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Jun__8_16:49:14_PDT_2022
Cuda compilation tools, release 11.7, V11.7.99
Build cuda_11.7.r11.7/compiler.31442593_0
When I try to install the graphic driver from Nvidia directly I get following messages which indicate that CUDA 11.7 should be installed:
kiropro@DESKTOP-JC8EGB7:~$ sudo apt-get -y install cuda
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
cuda is already the newest version (11.7.1-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
EDIT: As I have read 11.7 should be installed, nvidia-smi only shows what my graphic card is capable of, so that should be alright. But still I am confused about the error in the first box and the different NIVIDIA-SMI (525.89.02) driver version and Driver Version (528.49) in the nvidia-smi command
