I’m trying to get cuda working on a clean WSL2/Ubuntu install on Win11. I’m running nvidia-smi from the ubuntu shell to check gpu health and finding it works immediately after the install but starts failing after that with a “couldn’t communicate with the NVIDIA driver” error.
Although I’ve seen many threads reporting this error message, I haven’t seen reproduction steps or solutions. I think I’ve identified how to repro this problem, which suggests a resource conflict with docker-desktop.
I installed recent nvidia drivers (528.24) for windows
I (re)installed the latest Ubuntu (2204.1.8.0) from Microsoft Store.
I run nvidia-smi from my ubuntu shell, and it successfully finds the gpu.
$ nvidia-smi
| NVIDIA-SMI 525.85.05 Driver Version: 528.24 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:01:00.0 On | N/A |
| 0% 38C P8 10W / 200W | 353MiB / 8192MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 23 G /Xwayland N/A |
I run wsl --shutdown from the powershell to bounce WSL, open a new ubuntu shell, and now the command fails:
$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Failed to properly shut down NVML: Driver Not Loaded
WSL also reports docker desktop running. Note I’m not running any containers, the service just starts in the background.
PS C:\Users\Jim> wsl -l -v
NAME STATE VERSION
* docker-desktop-data Stopped 2
Ubuntu Running 2
docker-desktop Running 2
I disable the docker desktop service, reboot, and confirm WSL is no longer running it:
NAME STATE VERSION
Ubuntu Running 2
docker-desktop Stopped 2
Now nvidia-smi starts working reliably. I bring up new shells, shut down and restart wsl, and it consistently sees the gpu.
$ nvidia-smi
Thu Feb 9 13:32:59 2023
| | | MIG M. |
| 0% 38C P8 12W / 200W | 459MiB / 8192MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Some resource seems to be in contention, with docker grabbing it away from ubuntu, but I don’t understand what. How do I get these to coexist happily?
