Took me a bit to figure this out with my own code, but I replicated it with the ‘parameterized_tesselated_example.py’ file from the examples.
When you try to sample with any a subset of parameters, similar to what is done in the three_fin example for monitors, you get the following error:
File "parameterized_tesselated_example.py", line 47, in <module>
s = geo.sample_boundary(nr_points=1000000, parameterization = subset_ranges)
File "/modulus/modulus/geometry/geometry.py", line 474, in sample_boundary
File "/modulus/modulus/geometry/geometry.py", line 475, in <listcomp>
curve.approx_area(parameterization, criteria=closed_boundary_criteria)
File "/modulus/modulus/geometry/curve.py", line 134, in approx_area
computed_criteria = criteria(s, p)
File "/modulus/modulus/geometry/geometry.py", line 466, in boundary_criteria
return self.boundary_criteria(invar, criteria=criteria, params=params)
File "/modulus/modulus/geometry/geometry.py", line 387, in boundary_criteria
sdf_normal_plus = self.sdf(
File "/modulus/modulus/geometry/discrete_geometry.py", line 59, in sdf
computed_sdf = f(
File "/modulus/modulus/geometry/tessellation.py", line 115, in sdf
minx, maxx, miny, maxy, minz, maxz = _find_mins_maxs(points)
File "/modulus/modulus/geometry/tessellation.py", line 251, in _find_mins_maxs
minx = float(np.min(points[:, 0]))
File "<__array_function__ internals>", line 180, in amin
File "/opt/conda/lib/python3.8/site-packages/numpy/core/fromnumeric.py", line 2916, in amin
return _wrapreduction(a, np.minimum, 'min', axis, None, out,
File "/opt/conda/lib/python3.8/site-packages/numpy/core/fromnumeric.py", line 86, in _wrapreduction
return ufunc.reduce(obj, axis, dtype, out, **passkwargs)
ValueError: zero-size array to reduction operation minimum which has no identity
Here is my modified version of the example file which replicates the problem:
import glob
import numpy as np
from modulus.geometry.tessellation import Tessellation
from modulus.geometry.discrete_geometry import DiscreteGeometry
from modulus.utils.io.vtk import var_to_polyvtk
from modulus.geometry.parameterization import Parameterization, Parameter
if __name__ == "__main__":
# make geometry for each bracket
bracket_files = glob.glob("./bracket_stl/*.stl")
bracket_files.sort()
brackets = []
radius = []
width = []
for f in bracket_files:
# get param values
radius.append(float(f.split("_")[3]))
width.append(float(f.split("_")[5][:-4]))
# make geometry
brackets.append(Tessellation.from_stl(f))
# make discretely parameterized geometry
parameterization = Parameterization(
Parameter("radius"): np.array(radius)[:, None],
Parameter("width"): np.array(width)[:, None],
subset_ranges = {
Parameter("radius"): 0.2,
Parameter("width"):1.0
geo = DiscreteGeometry(brackets, parameterization)
print(parameterization)
print(subset_ranges)
# sample geometry over entire parameter range
s = geo.sample_boundary(nr_points=1000000)
var_to_polyvtk(s, "parameterized_bracket_boundary")
s = geo.sample_interior(nr_points=1000000)
var_to_polyvtk(s, "parameterized_bracket_interior")
var_to_polyvtk(s, "subset_sample")
I tried this one, a version that makes a secondary parameter set based on the first:
Parameter("radius"): np.array([[radius[0]]]),
Parameter("width"): np.array([[width[0]]]),
and multiple other versions to test how I structured the input, but I keep getting the same error.
Let me know if you need any other information
*Edit: There is a workaround… it is to sample the entire discrete geometry range and then filter the returned values
