I have a Xavier NX, 16GB eMMC, L4T 32.7.3(Jetpack 4.6.3).
I try to enable disk encryption with a read-only filesystem using overlayfs.
I was able to enable disk encryption after following instructions from the thread Topic 276275.
To enable read-only mode I use a script from the repository.
https://github.com/forecr/jetson_overlayroot
I tested both procedures independently and they work.
The problem occurs when I want to combine both procedures. First, I encrypt the disk, then run the script to enable read-only.
Below is a screenshot of the system startup process.
As you can see, the system startup process ends in emergency mode.
I also tried editing the /etc/overlayroot.conf file:
overlayroot=“/dev/mapper/cryp_root”
overlayroot_cfgdisk=“enabled”
Unfortunately, this approach also did not work with an error message.
However, the system starts but does not have read-only mode enabled.
I appreciate any help in solving my problem.
