I have written a program to capture faces from webcam and recognize it. The program is an extension/modification of the example http://dlib.net/dnn_face_recognition_ex.cpp.html. When it runs in Desktop, there is no memory leak. Here is the code:
#include <dlib/opencv.h>
#include <opencv2/highgui/highgui.hpp>
#include <dlib/image_processing/frontal_face_detector.h>
#include <dlib/image_processing/render_face_detections.h>
#include <dlib/image_processing.h>
#include <dlib/gui_widgets.h>
#include <dlib/dnn.h>
#include <dlib/clustering.h>
#include <dlib/string.h>
#include <dlib/image_io.h>
#include <iostream>
#include <string>
using namespace dlib;
using namespace std;
// The next bit of code defines a ResNet network. It's basically copied
// and pasted from the dnn_imagenet_ex.cpp example, except we replaced the loss
// layer with loss_metric and made the network somewhat smaller. Go read the introductory
// dlib DNN examples to learn what all this stuff means.
// Also, the dnn_metric_learning_on_images_ex.cpp example shows how to train this network.
// The dlib_face_recognition_resnet_model_v1 model used by this example was trained using
// essentially the code shown in dnn_metric_learning_on_images_ex.cpp except the
// mini-batches were made larger (35x15 instead of 5x5), the iterations without progress
// was set to 10000, the jittering you can see below in jitter_image() was used during
// training, and the training dataset consisted of about 3 million images instead of 55.
// Also, the input layer was locked to images of size 150.
template <template <int,template<typename>class,int,typename> class block, int N, template<typename>class BN, typename SUBNET>
using residual = add_prev1<block<N,BN,1,tag1<SUBNET>>>;
using residual_down = add_prev2<avg_pool<2,2,2,2,skip1<tag2<block<N,BN,2,tag1<SUBNET>>>>>>;
template <int N, template <typename> class BN, int stride, typename SUBNET>
using block = BN<con<N,3,3,1,1,relu<BN<con<N,3,3,stride,stride,SUBNET>>>>>;
template <int N, typename SUBNET> using ares = relu<residual<block,N,affine,SUBNET>>;
template <int N, typename SUBNET> using ares_down = relu<residual_down<block,N,affine,SUBNET>>;
template <typename SUBNET> using alevel0 = ares_down<256,SUBNET>;
template <typename SUBNET> using alevel1 = ares<256,ares<256,ares_down<256,SUBNET>>>;
template <typename SUBNET> using alevel2 = ares<128,ares<128,ares_down<128,SUBNET>>>;
template <typename SUBNET> using alevel3 = ares<64,ares<64,ares<64,ares_down<64,SUBNET>>>>;
template <typename SUBNET> using alevel4 = ares<32,ares<32,ares<32,SUBNET>>>;
using anet_type = loss_metric<fc_no_bias<128,avg_pool_everything<
alevel0<
alevel1<
alevel2<
alevel3<
alevel4<
max_pool<3,3,2,2,relu<affine<con<32,7,7,2,2,
input_rgb_image_sized<150>
std::vector<matrix<rgb_pixel>> jitter_image(
const matrix<rgb_pixel>& img
void GetFilesInDirectory(std::vector<string> &out, const string &directory)
#ifdef WINDOWS
HANDLE dir;
WIN32_FIND_DATA file_data;
if ((dir = FindFirstFile((directory + "/*").c_str(), &file_data)) == INVALID_HANDLE_VALUE)
return; /* No files found */
do {
const string file_name = file_data.cFileName;
const string full_file_name = directory + "/" + file_name;
const bool is_directory = (file_data.dwFileAttributes & FILE_ATTRIBUTE_DIRECTORY) != 0;
if (file_name[0] == '.')
continue;
if (is_directory)
continue;
out.push_back(full_file_name);
} while (FindNextFile(dir, &file_data));
FindClose(dir);
#else
DIR *dir;
class dirent *ent;
class stat st;
dir = opendir(directory.c_str());
while ((ent = readdir(dir)) != NULL) {
const string file_name = ent->d_name;
continue;
if (stat(full_file_name.c_str(), &st) == -1)
continue;
const bool is_directory = (st.st_mode & S_IFDIR) != 0;
if (is_directory)
continue;
out.push_back(file_name);
closedir(dir);
#endif
} // GetFilesInDirectory
int main()
try
std::vector<string> names;
GetFilesInDirectory(names,"./faces/template");
for(int i=0; i<names.size(); i++) cout<< names[i]<<endl;
cv::VideoCapture cap(0);
if (!cap.isOpened())
cerr << "Unable to connect to camera" << endl;
return 1;
image_window win;
// Load face detection and pose estimation models.
frontal_face_detector detector = get_frontal_face_detector();
// We will also use a face landmarking model to align faces to a standard pose: (see face_landmark_detection_ex.cpp for an introduction)
shape_predictor sp;
deserialize("shape_predictor_5_face_landmarks.dat") >> sp;
// And finally we load the DNN responsible for face recognition.
anet_type net;
deserialize("dlib_face_recognition_resnet_model_v1.dat") >> net;
printf("loading done!\n\n");
std::vector<matrix<rgb_pixel>> templates;
matrix<rgb_pixel> temp;
for(int i=1; i<names.size(); i+=2)
printf("i : %d\n",i);
load_image(temp, names[i]);
printf("debug 0\n");
for (auto face : detector(temp))
auto shape = sp(temp, face);
printf("debug 1\n");
matrix<rgb_pixel> face_chip;
extract_image_chip(temp, get_face_chip_details(shape,150,0.25), face_chip);
templates.push_back(move(face_chip));
std::vector<matrix<float,0,1>> template_descriptors = net(templates);
// Grab and process frames until the main window is closed by the user.
while(!win.is_closed())
// Grab a frame
cv::Mat temp;
//for(int i=0; i<5; i++) cap>> temp;
if (!cap.read(temp))
cout<<"image not found!\n";
continue;
// Turn OpenCV's Mat into something dlib can deal with. Note that this just
// wraps the Mat object, it doesn't copy anything. So cimg is only valid as
// long as temp is valid. Also don't do anything to temp that would cause it
// to reallocate the memory which stores the image as that will make cimg
// contain dangling pointers. This basically means you shouldn't modify temp
// while using cimg.
// cv_image<bgr_pixel> img(temp);
array2d<rgb_pixel> img;
assign_image(img, dlib::cv_image<bgr_pixel>(temp));
win.clear_overlay();
win.set_image(img);
// Run the face detector on the image of our action heroes, and for each face extract a
// copy that has been normalized to 150x150 pixels in size and appropriately rotated
// and centered.
std::vector<matrix<rgb_pixel>> faces;
std::vector<rectangle> rects = detector(img);
for (auto face : rects)
auto shape = sp(img, face);
extract_image_chip(img, get_face_chip_details(shape,150,0.25), face_chip);
faces.push_back(move(face_chip));
// Also put some boxes on the faces so we can see that the detector is finding
// them.
win.add_overlay(face);
if (faces.size() == 0)
cout << "No faces found in image!" << endl;
//return 1;
else
// This call asks the DNN to convert each face image in faces into a 128D vector.
// In this 128D vector space, images from the same person will be close to each other
// but vectors from different people will be far apart. So we can use these vectors to
// identify if a pair of images are from the same person or from different people.
std::vector<matrix<float,0,1>> face_descriptors = net(faces);
// In particular, one simple thing we can do is face clustering. This next bit of code
// creates a graph of connected faces and then uses the Chinese whispers graph clustering
// algorithm to identify how many people there are and which faces belong to whom.
std::vector<sample_pair> edges;
for (size_t i = 0; i < face_descriptors.size(); ++i)
for (size_t j = 0; j < template_descriptors.size(); ++j)
cout<<"i : "<<i<<" j : "<<j<<endl;
// Faces are connected in the graph if they are close enough. Here we check if
// the distance between two face descriptors is less than 0.6, which is the
// decision threshold the network was trained to use. Although you can
// certainly use any other threshold you find useful.
if (length(face_descriptors[i]-template_descriptors[j]) < 0.5)
string temp = names[j+j] + "found!!";
win.add_overlay(dlib::image_window::overlay_rect(rects[i], rgb_pixel(0,255,0),temp));
cout<< "face no: "<<i<<" similar to : " <<names[j+j]<<endl;
std::vector<unsigned long> labels;
const auto num_clusters = chinese_whispers(edges, labels);
// This will correctly indicate that there are 4 people in the image.
cout << "number of people found in the image: "<< num_clusters << endl;
// Now let's display the face clustering results on the screen. You will see that it
// correctly grouped all the faces.
std::vector<image_window> win_clusters(num_clusters);
for (size_t cluster_id = 0; cluster_id < num_clusters; ++cluster_id)
std::vector<matrix<rgb_pixel>> temp;
for (size_t j = 0; j < labels.size(); ++j)
if (cluster_id == labels[j])
temp.push_back(faces[j]);
win_clusters[cluster_id].set_title("face cluster " + cast_to_string(cluster_id));
win_clusters[cluster_id].set_image(tile_images(temp));
// Finally, let's print one of the face descriptors to the screen.
cout << "face descriptor for one face: " << trans(face_descriptors[0]) << endl;
// It should also be noted that face recognition accuracy can be improved if jittering
// is used when creating face descriptors. In particular, to get 99.38% on the LFW
// benchmark you need to use the jitter_image() routine to compute the descriptors,
// like so:
//matrix<float,0,1> face_descriptor = mean(mat(net(jitter_image(faces[0]))));
//cout << "jittered face descriptor for one face: " << trans(face_descriptor) << endl;
// If you use the model without jittering, as we did when clustering the bald guys, it
// gets an accuracy of 99.13% on the LFW benchmark. So jittering makes the whole
// procedure a little more accurate but makes face descriptor calculation slower.
// Display it all on the screen
//win.clear_overlay();
//win.set_image(cimg);
//win.add_overlay(render_face_detections(shapes));
catch(serialization_error& e)
cout << "You need dlib's default face landmarking model file to run this example." << endl;
cout << "You can get it from the following URL: " << endl;
cout << " http://dlib.net/files/shape_predictor_68_face_landmarks.dat.bz2" << endl;
cout << endl << e.what() << endl;
catch(exception& e)
cout << e.what() << endl;
// All this function does is make 100 copies of img, all slightly jittered by being
// zoomed, rotated, and translated a little bit differently.
thread_local random_cropper cropper;
cropper.set_chip_dims(150,150);
cropper.set_randomly_flip(true);
cropper.set_max_object_size(0.99999);
cropper.set_background_crops_fraction(0);
cropper.set_min_object_size(0.97);
cropper.set_translate_amount(0.02);
cropper.set_max_rotation_degrees(3);
std::vector<mmod_rect> raw_boxes(1), ignored_crop_boxes;
raw_boxes[0] = shrink_rect(get_rect(img),3);
std::vector<matrix<rgb_pixel>> crops;
for (int i = 0; i < 100; ++i)
cropper(img, raw_boxes, temp, ignored_crop_boxes);
crops.push_back(move(temp));
return crops;
But when the same code runs on both Jetson Xavier or Nano, the memory increases gradually. I have discovered that when I commented the line
// assign_image(img, dlib::cv_image<bgr_pixel>(temp));
there is no memory leak, but it also stops face recognition. I wonder if there is any bug or compatibility issue with dlib and Jetpack. I have compiled dlib without cuda also but the problem still persists.
My dlib version is 19.7 and Jetpack version is 4.2
