I am using the following tutorial to implement face recognition on Jetson nano post link
The tutorial uses Dlib and face_recognition library to do the task of face detection and recognition. it fetches 6-7 FPS on Jetson nano, how can I incorporate this tutorial with deepstream as i want to run it for several camera streams.
dlib has its own detection and recognition model.
If you can convert the model into TensorRT, you can just replace the path and parser in a standard pipeline:
If the model doesn’t be fully supported, you can try to insert the dlib implementation into the below sample.
Please noted that the buffer transfer between components is a GPU buffer.
Please check if dlib can accept the GPU buffer or not first.
Below is the TensorRT support matrix for your reference:
We don’t have a face recognition pipeline since there is no face related model in the Deepstream.
To feed multiple sources into Deepstream is easy.
For example, with /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt.
