NVIDIA Jetson Xavier NX
DeepStream Version5.0
Jetpack 4.4.1 [L4T 32.4.4]
TensorRT: 7.1.3.0
CUDA: 10.2.89
cuDNN: 8.0.0.180
Visionworks: 1.6.0.501
OpenCV: 4.1.1 compiled CUDA: NO
VPI: 0.4.4
Vulkan: 1.2.70
I am a newbie to Deepstream and face recognition technology overall. I have a project i want to work on, it is about Face Recognition System using Deepstream.
It includes 3 parts:
*Facial recognition
*Tensorrt Pruned and Quantization
*DeepStream.
Please can you guide where i can start from? I am will to learn everything related to this project. Thank you in advance.
Do you have a face recognition model?
Usually, this includes a detector and a classifier.
You will need to first locate a face within an image, and then recognize the identity.
We don’t have any face related model in our deepstream SDK.
So please start with training a model with the TLT toolkit and your own face database:
TLT can also help you do the pruning.
After that, please following below sample to deploy it with Deepstream.
Sample apps to demonstrate how to deploy models trained with TAO on DeepStream
Thank you a lot.
About the facial recognition model, which one do you recommend? I want to use an .mp4 video file as a test file.
The choice is a tradeoff between performance and accuracy.
Usually, you can check the table and find the most accurate one under the acceptable fps.
i dont mind about performance when it is more than enough accuracy
is facenet_keras.h5 supported by TLT?
Sorry that only NVIDIA pre-trained models from NGC are currently supported.
