Docker build + sudden repository change
I have been working on troubleshooting an Open3D build process over the past days : Unusual undefined references coming from arm_neon.h when compiling Open3D with CUDA - #3 by manbehindthemadness
This morning when I arrived in the office I was surprised when the jetpack install stopped working without any local changes. Last night before I left it was installing without issue and progressing into the build, today it errors out with:
Fetched 3841 MB in 5min 52s (10.9 MB/s)
Selecting previously unselected package nvidia-l4t-core.
(Reading database … 34973 files and directories currently installed.)
Preparing to unpack …/nvidia-l4t-core_35.1.0-20220825113828_arm64.deb …
Pre-installing… skip compatibility checking.
Unpacking nvidia-l4t-core (35.1.0-20220825113828) …
dpkg: error processing archive /var/cache/apt/archives/nvidia-l4t-core_35.1.0-20220825113828_arm64.deb (–unpack):
unable to make backup link of ā€˜./usr/lib/aarch64-linux-gnu/tegra/ld.so.conf’ before installing new version: Invalid cross-device link
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I decided to pull a few other images out and see if I have missed something; however, the problem is the same… Am I crazy?
Orin AGX (host)
Linux Artax 5.10.104-tegra #1 SMP PREEMPT Wed Aug 10 20:17:07 PDT 2022 aarch64 aarch64 aarch64 GNU/Linux
ā€œ20.04.5 LTS (Focal Fossa)ā€
using nvcr.io/nvidia/l4t-base:r35.1.0 for the docker build.
(Build details can be found in the linked post above)
I’m not too concerned about the error, what I really need is a sanity check. Are these images static?
root@bc2716280878:/usr/lib/aarch64-linux-gnu/tegra# mount
overlay on / type overlay (rw,relatime,lowerdir=/var/lib/docker/overlay2/l/UBHAPCMVUMILHE6HZUANB2YQQE:/var/lib/docker/overlay2/l/DNEBS5QAKGNHEDPR6DNFRLOUUR:/var/lib/docker/overlay2/l/U3Y2CTZZJLF5TIDFKOUMAF7PTF:/var/lib/docker/overlay2/l/SKMA5ENI7PILK3JERPCWBRVTHF:/var/lib/docker/overlay2/l/OBRXYCEKNKN5KLTKKOU7AWOHAQ:/var/lib/docker/overlay2/l/3HZ3HKSJLA5HU7AGTX5QIOSNNB:/var/lib/docker/overlay2/l/3D3ALVI3OXHJRB5YBPMATAQI3Q:/var/lib/docker/overlay2/l/2AKXGQXK6PUAS4W3B6OZD65RWZ:/var/lib/docker/overlay2/l/GMPE4KUVTC54KAI3ILGJXRDNFI:/var/lib/docker/overlay2/l/R2J2ZHOABZYBXWCLXC5BTC2MVF:/var/lib/docker/overlay2/l/VRQVUB56LHOICTHF4WP4OZZIBK,upperdir=/var/lib/docker/overlay2/e84ef810cd291ead3a06511cfcef3735e522e94cd257fcd48a89ca5f4f822a23/diff,workdir=/var/lib/docker/overlay2/e84ef810cd291ead3a06511cfcef3735e522e94cd257fcd48a89ca5f4f822a23/work)
tmpfs on /dev type tmpfs (rw,nosuid,size=65536k,mode=755)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666)
shm on /dev/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=65536k)
/dev/nvme0n1p1 on /etc/hostname type ext4 (rw,relatime)
/dev/nvme0n1p1 on /etc/hosts type ext4 (rw,relatime)
/dev/nvme0n1p1 on /etc/resolv.conf type ext4 (rw,relatime)
/dev/nvme0n1p1 on /usr/lib/firmware/tegra19x type ext4 (ro,nosuid,nodev,relatime)
tmpfs on /sys/fs/cgroup type tmpfs (rw,nosuid,nodev,noexec,relatime,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (ro,nosuid,nodev,noexec,relatime,xattr,name=systemd)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (ro,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (ro,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/memory type cgroup (ro,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/blkio type cgroup (ro,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/cpuset type cgroup (ro,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/devices type cgroup (ro,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/pids type cgroup (ro,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/perf_event type cgroup (ro,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (ro,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/freezer type cgroup (ro,nosuid,nodev,noexec,relatime,freezer)
/dev/nvme0n1p1 on /etc/vulkansc/icd.d/nvidia_icd_vksc.json type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/libgstnvexifmeta.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/libgstnvivameta.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/libnvsample_cudaprocess.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvdrmvideosink.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra-egl/nvidia.json type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libGLX_nvidia.so.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libVkLayer_json_gen.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libVkSCLayer_khronos_validation.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libdrm.so.2 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libgstnvdsseimeta.so.1.0.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libjetsonpower.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvargus.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketclient.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketserver.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_fdmap.so.1.0.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so.1.0.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so.1.0.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcam_imageencoder.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcameratools.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcamerautils.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcamlog.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcamv4l2.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcapture.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcolorutil.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcucompat.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvcuvidv4l2.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvdc.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvddk_2d_v2.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvddk_vic.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvdecode2eglimage.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvdla_runtime.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so.1.0.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnveglstream_camconsumer.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnveglstreamproducer.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnveventlib.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvexif.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvfnet.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvfnetstoredefog.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvfnetstorehdfx.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvfusacap.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvfusacapinterface.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgbm.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_boot.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_camera.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_force.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_generic.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_gpucompute.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_graphics.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_il.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_spincircle.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_tbc.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgov_ui.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvgstreamer-1.0.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so.1.0.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-allocator.so.1 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-gbm.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-wayland.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glcore.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glsi.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glvkspirv.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-kms.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-ptxjitcompiler.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-rmapi-tegra.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-rtcore.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-tls.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-vksc-core.so.35.1.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvidia-vulkan-producer.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvimp.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvisp.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvisp_utils.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvisppg.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvll.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia2d.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_2d.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_dla.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_ide_parser.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_ide_sci.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_iep_sci.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_ijpd_sci.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_ijpe_sci.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_iofa_sci.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_isp_ext.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_sci_overlay.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_tensor.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmedialdc.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmm.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmm_contentpipe.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmm_parser.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmm_utils.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_image.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_utils.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvodm_imager.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvofsdk.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvoggopus.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvomx.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvomxilclient.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvos.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvosd.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvparser.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvphs.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvphsd.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvpva.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvpva_algorithms.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvpvaintf.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvpvaumd.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvrm_chip.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvrm_host1x.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvrm_mem.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvrm_stream.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvrm_surface.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvrm_sync.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvscibuf.so.1 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvscicommon.so.1 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvscievent.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvsciipc.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvscistream.so.1 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvscisync.so.1 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvsocsys.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvtracebuf.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvtvmr.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvtvmr_2d.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvv4l2.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvv4lconvert.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvvic.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvvideo.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libnvvideoencode_ppe.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libsensors.hal-client.nvs.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libsensors.l4t.no_fusion.nvs.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libsensors_hal.nvs.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libtegrav4l2.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libtegrawfd.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvargus.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvcuvidvideocodec.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvvideocodec.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libvulkan.so.1.3.203 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/libvulkansc.so.1.0.10 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/firmware/tegra19x/nvhost_nvdec040_ns.fw type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/firmware/tegra23x/nvhost_nvdec050_desc_prod.bin type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/EGLWLInputEventExample type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/EGLWLMockNavigation type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/LayerManagerControl type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/desktop-shell.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/drm-backend.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/fullscreen-shell.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/gl-renderer.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/hmi-controller.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/ivi-controller.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/ivi-shell.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/libilmClient.so.2.2.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/libilmCommon.so.2.2.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/libilmControl.so.2.2.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/libilmInput.so.2.2.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/libweston-6.so.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/libweston-desktop-6.so.0 type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/simple-weston-client type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/spring-tool type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/wayland-backend.so type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-calibrator type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-clickdot type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-cliptest type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-content-protection type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-debug type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-desktop-shell type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-dnd type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-eventdemo type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-flower type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-fullscreen type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-image type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-info type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-ivi-shell-user-interface type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-keyboard type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-launch type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-multi-resource type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-output-mode type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-resizor type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-scaler type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-screenshooter type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-dmabuf-egldevice type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-egl type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-shm type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-touch type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-smoke type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-stacking type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-subsurfaces type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-terminal type ext4 (ro,nosuid,nodev,relatime)
/dev/nvme0n1p1 on /usr/lib/aarch64-linux-gnu/tegra/weston/weston-transformed type ext4 (ro,nosuid,nodev,relatime)
devpts on /dev/console type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666)
proc on /proc/bus type proc (ro,nosuid,nodev,noexec,relatime)
proc on /proc/fs type proc (ro,nosuid,nodev,noexec,relatime)
proc on /proc/irq type proc (ro,nosuid,nodev,noexec,relatime)
proc on /proc/sys type proc (ro,nosuid,nodev,noexec,relatime)
proc on /proc/sysrq-trigger type proc (ro,nosuid,nodev,noexec,relatime)
tmpfs on /proc/asound type tmpfs (ro,relatime)
tmpfs on /proc/keys type tmpfs (rw,nosuid,size=65536k,mode=755)
tmpfs on /proc/timer_list type tmpfs (rw,nosuid,size=65536k,mode=755)
tmpfs on /proc/sched_debug type tmpfs (rw,nosuid,size=65536k,mode=755)
tmpfs on /proc/scsi type tmpfs (ro,relatime)
tmpfs on /sys/firmware type tmpfs (ro,relatime)
Have you executed any apt upgrade commands? Since we have a new r35.2 release recently.
If not, could you share the steps to reproduce this issue?
[EDIT]
This was the example I was using to reproduce the problem; However, I just re-ran and now it’s working fine… O_o
[END]
Yes, quite simply in fact.
Create file Dockerfile.example with the contents:
ARG BASE_IMAGE=nvcr.io/nvidia/l4t-base:r35.1.0
FROM nvcr.io/nvidia/l4t-base:r35.1.0
ENV DEBIAN_FRONTEND=noninteractive
ENV TZ=America/Los_Angeles
ENV SUDO=command
ENV UDEV=1
RUN echo ā€œdeb https://repo.download.nvidia.com/jetson/t194 r35.1 mainā€ >> /etc/apt/sources.list.d/nvidia-l4t-apt-source.list &&
apt-key adv --fetch-key http://repo.download.nvidia.com/jetson/jetson-ota-public.asc &&
mkdir -p /opt/nvidia/l4t-packages/ &&
touch /opt/nvidia/l4t-packages/.nv-l4t-disable-boot-fw-update-in-preinstall &&
# rm -fdr /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf &&
apt-get update && apt-get install -y --assume-yes --verbose-versions --allow-change-held-packages -o Dpkg::Options::=ā€œā€“force-confdefā€
nvidia-jetpack
Then run with:
docker build --progress plain --build-arg BASE_IMAGE=nvcr.io/nvidia/l4t-base:r35.1.0 -t example:focal -f Dockerfile.example .
Yes, I have verified that everything is fine now, please disregard…Weird…
Ok, so it came back. but after running a diff on the setups I realized it fails when we: export DOCKER_BUILDKIT=0
The variable was sneaking in from a pre-setup script.
[EDIT]
This answer has proven incorrect as the issue re-surfaced this morning using the example above. Tested after a fresh reboot and new session to ensure no unexpected environment variables were present. I performed a docker system prune prior to running the test to doubly prove that nothing else was interfering.
[END]
This issue is reproducible using this method:
ENV SUDO=command
ENV UDEV=1
nvidia-jetpack
Then run with:
Thanks for the testing.
We are going to reproduce this issue. Will keep you updated.
One more question, which BSP version you used for Orin (outside of the container)?
By BSP do you mean ā€œbroad support packageā€, ā€œbulk synchronous productionā€ or ā€œbilateral systematic processingā€?
Sorry for the unclear statement.
BSP means the Linux version installed by JetPack.
You can get this information with the following command (without container).
$ cat /etc/nv_tegra_release
Haha, all good, Acronyms are out of control these days. Here is the info:
R35 (release), REVISION: 1.0, GCID: 31346300, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 25 18:41:45 UTC 2022
can confirm that this issue still persists.
Just ran into the same problem. In my build scripts I needed to install nvidia-l4t-multimedia into a container because there was one component missing at the time of this script’s development. The build succeeded after I removed this step, it is now unnecessary for some reason.
Interesting, The only way I have had success is by cloning the whole image locally and removing the read only mount-points (not exactly the best solution)
Have you tried not installing the core package?
I have not, I was more confused about the sudden change, I have several months of work for my company in many scripts, having them suddenly stop working was alarming.
I know that feel bro
We can reproduce this issue with l4t-base:r35.2.1 as well.
Also try to install nvidia-l4t-core outside of the container but it works well.
It looks like this depends on the environment of the container.
Why do you think this issue is caused by the sudden repository changes?
Just want to gather more information in case we are missing something.
Well, I have been building against the image for some time with no issues, I keep these procedures on file so I can build various things around the lab, then suddenly they all stopped working whilst I was attempting to iron out an Open3D build process.
I have discovered that the read only mount points issued around the tegra install directory seem to be the culprit. Exporting the l4t base image, reloading and removing them causes builds to proceed without issue; however l, this involves setting up a local docker repo and probably isn’t the most graceful of solutions.
