running the following command
jetson-containers run --volume /home/kkk/apps:/ppp -it --rm $(autotag kairin/jetson-containers:l4t-pytorch-jetpack-tensorrt_llm-0.12-r36.4.0) /bin/bash
gives me the following list.
is there a better way to show packages from the above containers are properly installed?
╭─kkk at kkkORIN in ~/apps 25-02-08 - 13:32:15
╰─○ jetson-containers run --volume /home/kkk/apps:/ppp -it --rm $(autotag kairin/jetson-containers:l4t-pytorch-jetpack-tensorrt_llm-0.12-r36.4.0) /bin/bash
zsh: correct '/home/kkk/apps:/ppp' to '/home/kkk/apps/ppp' [nyae]? n
Namespace(packages=['kairin/jetson-containers:l4t-pytorch-jetpack-tensorrt_llm-0.12-r36.4.0'], prefer=['local', 'registry', 'build'], disable=[''], user='dustynv', output='/tmp/autotag', quiet=False, verbose=False)
-- L4T_VERSION=36.4.3 JETPACK_VERSION=6.2 CUDA_VERSION=12.8
-- Finding compatible container image for ['kairin/jetson-containers:l4t-pytorch-jetpack-tensorrt_llm-0.12-r36.4.0']
V4L2_DEVICES:
### DISPLAY environmental variable is already set: ":0"
localuser:root being added to access control list
+ docker run --runtime nvidia -it --rm --network host --shm-size=8g --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /home/kkk/apps/data:/data -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro --device /dev/snd -e PULSE_SERVER=unix:/run/user/1000/pulse/native -v /run/user/1000/pulse:/run/user/1000/pulse --device /dev/bus/usb -e DISPLAY=:0 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth --device /dev/i2c-0 --device /dev/i2c-1 --device /dev/i2c-2 --device /dev/i2c-3 --device /dev/i2c-4 --device /dev/i2c-5 --device /dev/i2c-6 --device /dev/i2c-7 --device /dev/i2c-8 --device /dev/i2c-9 -v /run/jtop.sock:/run/jtop.sock --name jetson_container_20250208_133248 --volume /home/kkk/apps:/ppp -it --rm kairin/jetson-containers:l4t-pytorch-jetpack-tensorrt_llm-0.12-r36.4.0 /bin/bash
root@kkkORIN:/# apt list --installed
Listing... Done
adduser/now 3.118ubuntu5 all [installed,local]
adwaita-icon-theme/now 41.0-1ubuntu1 all [installed,local]
apt-transport-https/now 2.4.13 all [installed,local]
apt/now 2.4.13 arm64 [installed,local]
autoconf/now 2.71-2 all [installed,local]
automake/now 1:1.16.5-1.3 all [installed,local]
autotools-dev/now 20220109.1 all [installed,local]
base-files/now 12ubuntu4.7 arm64 [installed,local]
base-passwd/now 3.5.52build1 arm64 [installed,local]
bash/now 5.1-6ubuntu1.1 arm64 [installed,local]
binutils-aarch64-linux-gnu/now 2.38-4ubuntu2.6 arm64 [installed,local]
binutils-common/now 2.38-4ubuntu2.6 arm64 [installed,local]
binutils/now 2.38-4ubuntu2.6 arm64 [installed,local]
bsdutils/now 1:2.37.2-4ubuntu3.4 arm64 [installed,local]
build-essential/now 12.9ubuntu3 arm64 [installed,local]
bzip2/now 1.0.8-5build1 arm64 [installed,local]
ca-certificates/now 20240203~22.04.1 all [installed,local]
cmake-data/now 3.22.1-1ubuntu1.22.04.2 all [installed,local]
cmake/now 3.22.1-1ubuntu1.22.04.2 arm64 [installed,local]
coreutils/now 8.32-4.1ubuntu1.2 arm64 [installed,local]
cpp-11/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
cpp/now 4:11.2.0-1ubuntu1 arm64 [installed,local]
cuda-cccl-12-6/now 12.6.37-1 arm64 [installed,local]
cuda-command-line-tools-12-6/now 12.6.1-1 arm64 [installed,local]
cuda-compiler-12-6/now 12.6.1-1 arm64 [installed,local]
cuda-crt-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-cudart-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-cudart-dev-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-cuobjdump-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-cupti-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-cupti-dev-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-cuxxfilt-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-documentation-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-driver-dev-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-gdb-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-libraries-12-6/now 12.6.1-1 arm64 [installed,local]
cuda-libraries-dev-12-6/now 12.6.1-1 arm64 [installed,local]
cuda-nsight-compute-12-6/now 12.6.1-1 arm64 [installed,local]
cuda-nvcc-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-nvdisasm-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-nvml-dev-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-nvprune-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-nvrtc-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-nvrtc-dev-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-nvtx-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-nvvm-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-profiler-api-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-sanitizer-12-6/now 12.6.68-1 arm64 [installed,local]
cuda-toolkit-12-6-config-common/now 12.6.68-1 all [installed,local]
cuda-toolkit-12-6/now 12.6.1-1 arm64 [installed,local]
cuda-toolkit-12-config-common/now 12.6.68-1 all [installed,local]
cuda-toolkit-12/now 12.6.1-1 arm64 [installed,local]
cuda-toolkit-config-common/now 12.6.68-1 all [installed,local]
cuda-toolkit/now 12.6.1-1 arm64 [installed,local]
cuda-tools-12-6/now 12.6.1-1 arm64 [installed,local]
cuda-visual-tools-12-6/now 12.6.1-1 arm64 [installed,local]
curl/now 7.81.0-1ubuntu1.18 arm64 [installed,local]
dash/now 0.5.11+git20210903+057cd650a4ed-3build1 arm64 [installed,local]
dbus-user-session/now 1.12.20-2ubuntu4.1 arm64 [installed,local]
dbus/now 1.12.20-2ubuntu4.1 arm64 [installed,local]
dconf-gsettings-backend/now 0.40.0-3 arm64 [installed,local]
dconf-service/now 0.40.0-3 arm64 [installed,local]
debconf/now 1.5.79ubuntu1 all [installed,local]
debianutils/now 5.5-1ubuntu2 arm64 [installed,local]
dh-elpa-helper/now 2.0.9ubuntu1 all [installed,local]
diffutils/now 1:3.8-0ubuntu2 arm64 [installed,local]
dirmngr/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
distro-info-data/now 0.52ubuntu0.7 all [installed,local]
dpkg-dev/now 1.21.1ubuntu2.3 all [installed,local]
dpkg/now 1.21.1ubuntu2.3 arm64 [installed,local]
e2fsprogs/now 1.46.5-2ubuntu1.2 arm64 [installed,local]
emacsen-common/now 3.0.4 all [installed,local]
file/now 1:5.41-3ubuntu0.1 arm64 [installed,local]
findutils/now 4.8.0-1ubuntu3 arm64 [installed,local]
fontconfig-config/now 2.13.1-4.2ubuntu5 all [installed,local]
fontconfig/now 2.13.1-4.2ubuntu5 arm64 [installed,local]
fonts-dejavu-core/now 2.37-2build1 all [installed,local]
g++-11/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
g++/now 4:11.2.0-1ubuntu1 arm64 [installed,local]
gcc-11-base/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
gcc-11/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
gcc-12-base/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
gcc/now 4:11.2.0-1ubuntu1 arm64 [installed,local]
gdb/now 12.1-0ubuntu1~22.04.2 arm64 [installed,local]
gds-tools-12-6/now 1.11.1.6-1 arm64 [installed,local]
gfortran-11/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
gfortran/now 4:11.2.0-1ubuntu1 arm64 [installed,local]
gir1.2-atk-1.0/now 2.36.0-3build1 arm64 [installed,local]
gir1.2-atspi-2.0/now 2.44.0-3 arm64 [installed,local]
gir1.2-freedesktop/now 1.72.0-1 arm64 [installed,local]
gir1.2-gdkpixbuf-2.0/now 2.42.8+dfsg-1ubuntu0.3 arm64 [installed,local]
gir1.2-glib-2.0/now 1.72.0-1 arm64 [installed,local]
gir1.2-gst-plugins-base-1.0/now 1.20.1-1ubuntu0.2 arm64 [installed,local]
gir1.2-gstreamer-1.0/now 1.20.3-0ubuntu1 arm64 [installed,local]
gir1.2-gtk-2.0/now 2.24.33-2ubuntu2.1 arm64 [installed,local]
gir1.2-gtk-3.0/now 3.24.33-1ubuntu2.2 arm64 [installed,local]
gir1.2-gudev-1.0/now 1:237-2build1 arm64 [installed,local]
gir1.2-harfbuzz-0.0/now 2.7.4-1ubuntu3.1 arm64 [installed,local]
gir1.2-packagekitglib-1.0/now 1.2.5-2ubuntu2 arm64 [installed,local]
gir1.2-pango-1.0/now 1.50.6+ds-2ubuntu1 arm64 [installed,local]
git-man/now 1:2.34.1-1ubuntu1.11 all [installed,local]
git/now 1:2.34.1-1ubuntu1.11 arm64 [installed,local]
gnupg-l10n/now 2.2.27-3ubuntu2.1 all [installed,local]
gnupg-utils/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
gnupg/now 2.2.27-3ubuntu2.1 all [installed,local]
gpg-agent/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
gpg-wks-client/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
gpg-wks-server/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
gpg/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
gpgconf/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
gpgsm/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
gpgv/now 2.2.27-3ubuntu2.1 arm64 [installed,local]
grep/now 3.7-1build1 arm64 [installed,local]
gtk-update-icon-cache/now 3.24.33-1ubuntu2.2 arm64 [installed,local]
gzip/now 1.10-4ubuntu4.1 arm64 [installed,local]
hicolor-icon-theme/now 0.17-2 all [installed,local]
hostname/now 3.23ubuntu2 arm64 [installed,local]
humanity-icon-theme/now 0.6.16 all [installed,local]
ibverbs-providers/now 39.0-1 arm64 [installed,local]
icu-devtools/now 70.1-2 arm64 [installed,local]
init-system-helpers/now 1.62 all [installed,local]
iso-codes/now 4.9.0-1 all [installed,local]
libacl1/now 2.3.1-1 arm64 [installed,local]
libaom3/now 3.3.0-1 arm64 [installed,local]
libapparmor1/now 3.0.4-2ubuntu2.4 arm64 [installed,local]
libappstream4/now 0.15.2-2 arm64 [installed,local]
libapt-pkg6.0/now 2.4.13 arm64 [installed,local]
libarchive-dev/now 3.6.0-1ubuntu1.1 arm64 [installed,local]
libarchive13/now 3.6.0-1ubuntu1.1 arm64 [installed,local]
libargon2-1/now 0~20171227-0.3 arm64 [installed,local]
libasan6/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
libasound2-data/now 1.2.6.1-1ubuntu1 all [installed,local]
libasound2/now 1.2.6.1-1ubuntu1 arm64 [installed,local]
libassuan0/now 2.5.5-1build1 arm64 [installed,local]
libatk-bridge2.0-0/now 2.38.0-3 arm64 [installed,local]
libatk-bridge2.0-dev/now 2.38.0-3 arm64 [installed,local]
libatk1.0-0/now 2.36.0-3build1 arm64 [installed,local]
libatk1.0-data/now 2.36.0-3build1 all [installed,local]
libatk1.0-dev/now 2.36.0-3build1 arm64 [installed,local]
libatlas-base-dev/now 3.10.3-12ubuntu1 arm64 [installed,local]
libatlas3-base/now 3.10.3-12ubuntu1 arm64 [installed,local]
libatomic1/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libatspi2.0-0/now 2.44.0-3 arm64 [installed,local]
libatspi2.0-dev/now 2.44.0-3 arm64 [installed,local]
libattr1/now 1:2.5.1-1build1 arm64 [installed,local]
libaudit-common/now 1:3.0.7-1build1 all [installed,local]
libaudit1/now 1:3.0.7-1build1 arm64 [installed,local]
libavahi-client3/now 0.8-5ubuntu5.2 arm64 [installed,local]
libavahi-common-data/now 0.8-5ubuntu5.2 arm64 [installed,local]
libavahi-common3/now 0.8-5ubuntu5.2 arm64 [installed,local]
libavcodec-dev/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libavcodec58/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libavformat-dev/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libavformat58/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libavutil-dev/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libavutil56/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libbabeltrace1/now 1.5.8-2build1 arm64 [installed,local]
libbinutils/now 2.38-4ubuntu2.6 arm64 [installed,local]
libblkid-dev/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
libblkid1/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
libbluray2/now 1:1.3.1-1 arm64 [installed,local]
libboost-regex1.74.0/now 1.74.0-14ubuntu3 arm64 [installed,local]
libbrotli-dev/now 1.0.9-2build6 arm64 [installed,local]
libbrotli1/now 1.0.9-2build6 arm64 [installed,local]
libbsd0/now 0.11.5-1 arm64 [installed,local]
libbz2-1.0/now 1.0.8-5build1 arm64 [installed,local]
libc-bin/now 2.35-0ubuntu3.8 arm64 [installed,local]
libc-dev-bin/now 2.35-0ubuntu3.8 arm64 [installed,local]
libc6-dev/now 2.35-0ubuntu3.8 arm64 [installed,local]
libc6/now 2.35-0ubuntu3.8 arm64 [installed,local]
libcairo-gobject2/now 1.16.0-5ubuntu2 arm64 [installed,local]
libcairo-script-interpreter2/now 1.16.0-5ubuntu2 arm64 [installed,local]
libcairo2-dev/now 1.16.0-5ubuntu2 arm64 [installed,local]
libcairo2/now 1.16.0-5ubuntu2 arm64 [installed,local]
libcanberra-gtk3-0/now 0.30-10ubuntu1.22.04.1 arm64 [installed,local]
libcanberra-gtk3-module/now 0.30-10ubuntu1.22.04.1 arm64 [installed,local]
libcanberra0/now 0.30-10ubuntu1.22.04.1 arm64 [installed,local]
libcap-ng0/now 0.7.9-2.2build3 arm64 [installed,local]
libcap2-bin/now 1:2.44-1ubuntu0.22.04.1 arm64 [installed,local]
libcap2/now 1:2.44-1ubuntu0.22.04.1 arm64 [installed,local]
libcbor0.8/now 0.8.0-2ubuntu1 arm64 [installed,local]
libcc1-0/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libchromaprint1/now 1.5.1-2 arm64 [installed,local]
libcodec2-1.0/now 1.0.1-3 arm64 [installed,local]
libcolord2/now 1.4.6-1 arm64 [installed,local]
libcom-err2/now 1.46.5-2ubuntu1.2 arm64 [installed,local]
libcrypt-dev/now 1:4.4.27-1 arm64 [installed,local]
libcrypt1/now 1:4.4.27-1 arm64 [installed,local]
libcryptsetup12/now 2:2.4.3-1ubuntu1.2 arm64 [installed,local]
libctf-nobfd0/now 2.38-4ubuntu2.6 arm64 [installed,local]
libctf0/now 2.38-4ubuntu2.6 arm64 [installed,local]
libcublas-12-6/now 12.6.1.4-1 arm64 [installed,local]
libcublas-dev-12-6/now 12.6.1.4-1 arm64 [installed,local]
libcudla-12-6/now 12.6.68-1 arm64 [installed,local]
libcudla-dev-12-6/now 12.6.68-1 arm64 [installed,local]
libcudnn9-cuda-12/now 9.4.0.58-1 arm64 [installed,local]
libcudnn9-dev-cuda-12/now 9.4.0.58-1 arm64 [installed,local]
libcudnn9-samples/now 9.4.0.58-1 all [installed,local]
libcufft-12-6/now 11.2.6.59-1 arm64 [installed,local]
libcufft-dev-12-6/now 11.2.6.59-1 arm64 [installed,local]
libcufile-12-6/now 1.11.1.6-1 arm64 [installed,local]
libcufile-dev-12-6/now 1.11.1.6-1 arm64 [installed,local]
libcups2/now 2.4.1op1-1ubuntu4.11 arm64 [installed,local]
libcurand-12-6/now 10.3.7.68-1 arm64 [installed,local]
libcurand-dev-12-6/now 10.3.7.68-1 arm64 [installed,local]
libcurl3-gnutls/now 7.81.0-1ubuntu1.18 arm64 [installed,local]
libcurl4/now 7.81.0-1ubuntu1.18 arm64 [installed,local]
libcusolver-12-6/now 11.6.4.69-1 arm64 [installed,local]
libcusolver-dev-12-6/now 11.6.4.69-1 arm64 [installed,local]
libcusparse-12-6/now 12.5.3.3-1 arm64 [installed,local]
libcusparse-dev-12-6/now 12.5.3.3-1 arm64 [installed,local]
libdatrie-dev/now 0.2.13-2 arm64 [installed,local]
libdatrie1/now 0.2.13-2 arm64 [installed,local]
libdav1d5/now 0.9.2-1 arm64 [installed,local]
libdb5.3/now 5.3.28+dfsg1-0.8ubuntu3 arm64 [installed,local]
libdbus-1-3/now 1.12.20-2ubuntu4.1 arm64 [installed,local]
libdbus-1-dev/now 1.12.20-2ubuntu4.1 arm64 [installed,local]
libdconf1/now 0.40.0-3 arm64 [installed,local]
libdebconfclient0/now 0.261ubuntu1 arm64 [installed,local]
libdebuginfod-common/now 0.186-1build1 all [installed,local]
libdebuginfod1/now 0.186-1build1 arm64 [installed,local]
libdeflate-dev/now 1.10-2 arm64 [installed,local]
libdeflate0/now 1.10-2 arm64 [installed,local]
libdevmapper1.02.1/now 2:1.02.175-2.1ubuntu4 arm64 [installed,local]
libdouble-conversion3/now 3.1.7-4 arm64 [installed,local]
libdpkg-perl/now 1.21.1ubuntu2.3 all [installed,local]
libdrm-amdgpu1/now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,local]
libdrm-common/now 2.4.113-2~ubuntu0.22.04.1 all [installed,local]
libdrm-dev/now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,local]
libdrm-etnaviv1/now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,local]
libdrm-freedreno1/now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,local]
libdrm-nouveau2/now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,local]
libdrm-radeon1/now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,local]
libdrm-tegra0/now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,local]
libdrm2/now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,local]
libdw-dev/now 0.186-1build1 arm64 [installed,local]
libdw1/now 0.186-1build1 arm64 [installed,local]
libedit2/now 3.1-20210910-1build1 arm64 [installed,local]
libegl-dev/now 1.4.0-1 arm64 [installed,local]
libegl-mesa0/now 23.2.1-1ubuntu3.1~22.04.2 arm64 [installed,local]
libegl1-mesa-dev/now 23.2.1-1ubuntu3.1~22.04.2 arm64 [installed,local]
libegl1/now 1.4.0-1 arm64 [installed,local]
libeigen3-dev/now 3.4.0-2ubuntu2 all [installed,local]
libelf-dev/now 0.186-1build1 arm64 [installed,local]
libelf1/now 0.186-1build1 arm64 [installed,local]
libepoxy-dev/now 1.5.10-1 arm64 [installed,local]
libepoxy0/now 1.5.10-1 arm64 [installed,local]
liberror-perl/now 0.17029-1 all [installed,local]
libevdev2/now 1.12.1+dfsg-1 arm64 [installed,local]
libevent-2.1-7/now 2.1.12-stable-1build3 arm64 [installed,local]
libevent-core-2.1-7/now 2.1.12-stable-1build3 arm64 [installed,local]
libevent-dev/now 2.1.12-stable-1build3 arm64 [installed,local]
libevent-extra-2.1-7/now 2.1.12-stable-1build3 arm64 [installed,local]
libevent-openssl-2.1-7/now 2.1.12-stable-1build3 arm64 [installed,local]
libevent-pthreads-2.1-7/now 2.1.12-stable-1build3 arm64 [installed,local]
libexpat1-dev/now 2.4.7-1ubuntu0.4 arm64 [installed,local]
libexpat1/now 2.4.7-1ubuntu0.4 arm64 [installed,local]
libext2fs2/now 1.46.5-2ubuntu1.2 arm64 [installed,local]
libfabric1/now 1.11.0-3 arm64 [installed,local]
libffi-dev/now 3.4.2-4 arm64 [installed,local]
libffi8/now 3.4.2-4 arm64 [installed,local]
libfido2-1/now 1.10.0-1 arm64 [installed,local]
libflac8/now 1.3.3-2ubuntu0.2 arm64 [installed,local]
libfontconfig-dev/now 2.13.1-4.2ubuntu5 arm64 [installed,local]
libfontconfig1-dev/now 2.13.1-4.2ubuntu5 arm64 [installed,local]
libfontconfig1/now 2.13.1-4.2ubuntu5 arm64 [installed,local]
libfreetype-dev/now 2.11.1+dfsg-1ubuntu0.2 arm64 [installed,local]
libfreetype6-dev/now 2.11.1+dfsg-1ubuntu0.2 arm64 [installed,local]
libfreetype6/now 2.11.1+dfsg-1ubuntu0.2 arm64 [installed,local]
libfribidi-dev/now 1.0.8-2ubuntu3.1 arm64 [installed,local]
libfribidi0/now 1.0.8-2ubuntu3.1 arm64 [installed,local]
libgbm-dev/now 23.2.1-1ubuntu3.1~22.04.2 arm64 [installed,local]
libgbm1/now 23.2.1-1ubuntu3.1~22.04.2 arm64 [installed,local]
libgcc-11-dev/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
libgcc-s1/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libgcrypt20/now 1.9.4-3ubuntu3 arm64 [installed,local]
libgdbm-compat4/now 1.23-1 arm64 [installed,local]
libgdbm6/now 1.23-1 arm64 [installed,local]
libgdk-pixbuf-2.0-0/now 2.42.8+dfsg-1ubuntu0.3 arm64 [installed,local]
libgdk-pixbuf-2.0-dev/now 2.42.8+dfsg-1ubuntu0.3 arm64 [installed,local]
libgdk-pixbuf2.0-bin/now 2.42.8+dfsg-1ubuntu0.3 arm64 [installed,local]
libgdk-pixbuf2.0-common/now 2.42.8+dfsg-1ubuntu0.3 all [installed,local]
libgfortran-11-dev/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
libgfortran5/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libgif7/now 5.1.9-2ubuntu0.1 arm64 [installed,local]
libgirepository-1.0-1/now 1.72.0-1 arm64 [installed,local]
libgl-dev/now 1.4.0-1 arm64 [installed,local]
libgl1-mesa-dri/now 23.2.1-1ubuntu3.1~22.04.2 arm64 [installed,local]
libgl1/now 1.4.0-1 arm64 [installed,local]
libglapi-mesa/now 23.2.1-1ubuntu3.1~22.04.2 arm64 [installed,local]
libgles-dev/now 1.4.0-1 arm64 [installed,local]
libgles1/now 1.4.0-1 arm64 [installed,local]
libgles2/now 1.4.0-1 arm64 [installed,local]
libglew-dev/now 2.2.0-4 arm64 [installed,local]
libglew2.2/now 2.2.0-4 arm64 [installed,local]
libglib2.0-0/now 2.72.4-0ubuntu2.3 arm64 [installed,local]
libglib2.0-bin/now 2.72.4-0ubuntu2.3 arm64 [installed,local]
libglib2.0-data/now 2.72.4-0ubuntu2.3 all [installed,local]
libglib2.0-dev-bin/now 2.72.4-0ubuntu2.3 arm64 [installed,local]
libglib2.0-dev/now 2.72.4-0ubuntu2.3 arm64 [installed,local]
libglu1-mesa-dev/now 9.0.2-1 arm64 [installed,local]
libglu1-mesa/now 9.0.2-1 arm64 [installed,local]
libglvnd-core-dev/now 1.4.0-1 arm64 [installed,local]
libglvnd-dev/now 1.4.0-1 arm64 [installed,local]
libglvnd0/now 1.4.0-1 arm64 [installed,local]
libglx-dev/now 1.4.0-1 arm64 [installed,local]
libglx-mesa0/now 23.2.1-1ubuntu3.1~22.04.2 arm64 [installed,local]
libglx0/now 1.4.0-1 arm64 [installed,local]
libgme0/now 0.6.3-2 arm64 [installed,local]
libgmp10/now 2:6.2.1+dfsg-3ubuntu1 arm64 [installed,local]
libgnutls30/now 3.7.3-4ubuntu1.5 arm64 [installed,local]
libgomp1/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libgpg-error0/now 1.43-3 arm64 [installed,local]
libgraphite2-3/now 1.3.14-1build2 arm64 [installed,local]
libgraphite2-dev/now 1.3.14-1build2 arm64 [installed,local]
libgsm1/now 1.0.19-1 arm64 [installed,local]
libgssapi-krb5-2/now 1.19.2-2ubuntu0.4 arm64 [installed,local]
libgstreamer-gl1.0-0/now 1.20.1-1ubuntu0.2 arm64 [installed,local]
libgstreamer-plugins-base1.0-0/now 1.20.1-1ubuntu0.2 arm64 [installed,local]
libgstreamer-plugins-base1.0-dev/now 1.20.1-1ubuntu0.2 arm64 [installed,local]
libgstreamer-plugins-good1.0-0/now 1.20.3-0ubuntu1.1 arm64 [installed,local]
libgstreamer-plugins-good1.0-dev/now 1.20.3-0ubuntu1.1 arm64 [installed,local]
libgstreamer1.0-0/now 1.20.3-0ubuntu1 arm64 [installed,local]
libgstreamer1.0-dev/now 1.20.3-0ubuntu1 arm64 [installed,local]
libgtk-3-0/now 3.24.33-1ubuntu2.2 arm64 [installed,local]
libgtk-3-common/now 3.24.33-1ubuntu2.2 all [installed,local]
libgtk-3-dev/now 3.24.33-1ubuntu2.2 arm64 [installed,local]
libgtk2.0-0/now 2.24.33-2ubuntu2.1 arm64 [installed,local]
libgtk2.0-common/now 2.24.33-2ubuntu2.1 all [installed,local]
libgtk2.0-dev/now 2.24.33-2ubuntu2.1 arm64 [installed,local]
libgtkglext1-dev/now 1.2.0-11 arm64 [installed,local]
libgtkglext1/now 1.2.0-11 arm64 [installed,local]
libgudev-1.0-0/now 1:237-2build1 arm64 [installed,local]
libgudev-1.0-dev/now 1:237-2build1 arm64 [installed,local]
libharfbuzz-dev/now 2.7.4-1ubuntu3.1 arm64 [installed,local]
libharfbuzz-gobject0/now 2.7.4-1ubuntu3.1 arm64 [installed,local]
libharfbuzz-icu0/now 2.7.4-1ubuntu3.1 arm64 [installed,local]
libharfbuzz0b/now 2.7.4-1ubuntu3.1 arm64 [installed,local]
libhogweed6/now 3.7.3-1build2 arm64 [installed,local]
libhwasan0/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libhwloc-dev/now 2.7.0-2ubuntu1 arm64 [installed,local]
libhwloc-plugins/now 2.7.0-2ubuntu1 arm64 [installed,local]
libhwloc15/now 2.7.0-2ubuntu1 arm64 [installed,local]
libibverbs-dev/now 39.0-1 arm64 [installed,local]
libibverbs1/now 39.0-1 arm64 [installed,local]
libice-dev/now 2:1.0.10-1build2 arm64 [installed,local]
libice6/now 2:1.0.10-1build2 arm64 [installed,local]
libicu-dev/now 70.1-2 arm64 [installed,local]
libicu70/now 70.1-2 arm64 [installed,local]
libidn2-0/now 2.3.2-2build1 arm64 [installed,local]
libinput-bin/now 1.20.0-1ubuntu0.3 arm64 [installed,local]
libinput10/now 1.20.0-1ubuntu0.3 arm64 [installed,local]
libip4tc2/now 1.8.7-1ubuntu5.2 arm64 [installed,local]
libisl23/now 0.24-2build1 arm64 [installed,local]
libitm1/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libjbig-dev/now 2.1-3.1ubuntu0.22.04.1 arm64 [installed,local]
libjbig0/now 2.1-3.1ubuntu0.22.04.1 arm64 [installed,local]
libjpeg-dev/now 8c-2ubuntu10 arm64 [installed,local]
libjpeg-turbo8-dev/now 2.1.2-0ubuntu1 arm64 [installed,local]
libjpeg-turbo8/now 2.1.2-0ubuntu1 arm64 [installed,local]
libjpeg8-dev/now 8c-2ubuntu10 arm64 [installed,local]
libjpeg8/now 8c-2ubuntu10 arm64 [installed,local]
libjs-jquery-ui/now 1.13.1+dfsg-1 all [installed,local]
libjs-jquery/now 3.6.0+dfsg+~3.5.13-1 all [installed,local]
libjs-sphinxdoc/now 4.3.2-1 all [installed,local]
libjs-underscore/now 1.13.2~dfsg-2 all [installed,local]
libjson-c5/now 0.15-3~ubuntu1.22.04.2 arm64 [installed,local]
libjsoncpp25/now 1.9.5-3 arm64 [installed,local]
libk5crypto3/now 1.19.2-2ubuntu0.4 arm64 [installed,local]
libkeyutils1/now 1.6.1-2ubuntu3 arm64 [installed,local]
libkmod2/now 29-1ubuntu1 arm64 [installed,local]
libkrb5-3/now 1.19.2-2ubuntu0.4 arm64 [installed,local]
libkrb5support0/now 1.19.2-2ubuntu0.4 arm64 [installed,local]
libksba8/now 1.6.0-2ubuntu0.2 arm64 [installed,local]
liblapack-dev/now 3.10.0-2ubuntu1 arm64 [installed,local]
liblapack3/now 3.10.0-2ubuntu1 arm64 [installed,local]
liblapacke-dev/now 3.10.0-2ubuntu1 arm64 [installed,local]
liblapacke/now 3.10.0-2ubuntu1 arm64 [installed,local]
liblcms2-2/now 2.12~rc1-2build2 arm64 [installed,local]
libldap-2.5-0/now 2.5.18+dfsg-0ubuntu0.22.04.2 arm64 [installed,local]
liblept5/now 1.82.0-3build1 arm64 [installed,local]
libleptonica-dev/now 1.82.0-3build1 arm64 [installed,local]
libllvm14/now 1:14.0.0-1ubuntu1.1 arm64 [installed,local]
libllvm15/now 1:15.0.7-0ubuntu0.22.04.3 arm64 [installed,local]
liblsan0/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libltdl-dev/now 2.4.6-15build2 arm64 [installed,local]
libltdl7/now 2.4.6-15build2 arm64 [installed,local]
liblz4-1/now 1.9.3-2build2 arm64 [installed,local]
liblzma-dev/now 5.2.5-2ubuntu1 arm64 [installed,local]
liblzma5/now 5.2.5-2ubuntu1 arm64 [installed,local]
liblzo2-2/now 2.10-2build3 arm64 [installed,local]
libmagic-mgc/now 1:5.41-3ubuntu0.1 arm64 [installed,local]
libmagic1/now 1:5.41-3ubuntu0.1 arm64 [installed,local]
libmd0/now 1.0.4-1build1 arm64 [installed,local]
libmd4c0/now 0.4.8-1 arm64 [installed,local]
libmount-dev/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
libmount1/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
libmp3lame0/now 3.100-3build2 arm64 [installed,local]
libmpc3/now 1.2.1-2build1 arm64 [installed,local]
libmpdec3/now 2.5.1-2build2 arm64 [installed,local]
libmpfr6/now 4.1.0-3build3 arm64 [installed,local]
libmpg123-0/now 1.29.3-1build1 arm64 [installed,local]
libmtdev1/now 1.1.6-1build4 arm64 [installed,local]
libncurses6/now 6.3-2ubuntu0.1 arm64 [installed,local]
libncursesw6/now 6.3-2ubuntu0.1 arm64 [installed,local]
libnettle8/now 3.7.3-1build2 arm64 [installed,local]
libnghttp2-14/now 1.43.0-1ubuntu0.2 arm64 [installed,local]
libnl-3-200/now 3.5.0-0.1 arm64 [installed,local]
libnl-3-dev/now 3.5.0-0.1 arm64 [installed,local]
libnl-route-3-200/now 3.5.0-0.1 arm64 [installed,local]
libnl-route-3-dev/now 3.5.0-0.1 arm64 [installed,local]
libnorm1/now 1.5.9+dfsg-2 arm64 [installed,local]
libnpp-12-6/now 12.3.1.54-1 arm64 [installed,local]
libnpp-dev-12-6/now 12.3.1.54-1 arm64 [installed,local]
libnpth0/now 1.6-3build2 arm64 [installed,local]
libnsl-dev/now 1.3.0-2build2 arm64 [installed,local]
libnsl2/now 1.3.0-2build2 arm64 [installed,local]
libnuma-dev/now 2.0.14-3ubuntu2 arm64 [installed,local]
libnuma1/now 2.0.14-3ubuntu2 arm64 [installed,local]
libnvfatbin-12-6/now 12.6.68-1 arm64 [installed,local]
libnvfatbin-dev-12-6/now 12.6.68-1 arm64 [installed,local]
libnvjitlink-12-6/now 12.6.68-1 arm64 [installed,local]
libnvjitlink-dev-12-6/now 12.6.68-1 arm64 [installed,local]
libogg0/now 1.3.5-0ubuntu3 arm64 [installed,local]
libomp-14-dev/now 1:14.0.0-1ubuntu1.1 arm64 [installed,local]
libomp-dev/now 1:14.0-55~exp2 arm64 [installed,local]
libomp5-14/now 1:14.0.0-1ubuntu1.1 arm64 [installed,local]
libopenblas-dev/now 0.3.20+ds-1 arm64 [installed,local]
libopenblas-pthread-dev/now 0.3.20+ds-1 arm64 [installed,local]
libopenblas0-pthread/now 0.3.20+ds-1 arm64 [installed,local]
libopenblas0/now 0.3.20+ds-1 arm64 [installed,local]
libopengl-dev/now 1.4.0-1 arm64 [installed,local]
libopengl0/now 1.4.0-1 arm64 [installed,local]
libopenjp2-7/now 2.4.0-6ubuntu0.1 arm64 [installed,local]
libopenmpi-dev/now 4.1.2-2ubuntu1 arm64 [installed,local]
libopenmpi3/now 4.1.2-2ubuntu1 arm64 [installed,local]
libopenmpt0/now 0.6.1-1 arm64 [installed,local]
libopus0/now 1.3.1-0.1build2 arm64 [installed,local]
liborc-0.4-0/now 1:0.4.32-2ubuntu0.1 arm64 [installed,local]
liborc-0.4-dev-bin/now 1:0.4.32-2ubuntu0.1 arm64 [installed,local]
liborc-0.4-dev/now 1:0.4.32-2ubuntu0.1 arm64 [installed,local]
libp11-kit0/now 0.24.0-6build1 arm64 [installed,local]
libpackagekit-glib2-18/now 1.2.5-2ubuntu2 arm64 [installed,local]
libpam-modules-bin/now 1.4.0-11ubuntu2.4 arm64 [installed,local]
libpam-modules/now 1.4.0-11ubuntu2.4 arm64 [installed,local]
libpam-runtime/now 1.4.0-11ubuntu2.4 all [installed,local]
libpam-systemd/now 249.11-0ubuntu3.12 arm64 [installed,local]
libpam0g/now 1.4.0-11ubuntu2.4 arm64 [installed,local]
libpango-1.0-0/now 1.50.6+ds-2ubuntu1 arm64 [installed,local]
libpango1.0-dev/now 1.50.6+ds-2ubuntu1 arm64 [installed,local]
libpangocairo-1.0-0/now 1.50.6+ds-2ubuntu1 arm64 [installed,local]
libpangoft2-1.0-0/now 1.50.6+ds-2ubuntu1 arm64 [installed,local]
libpangoxft-1.0-0/now 1.50.6+ds-2ubuntu1 arm64 [installed,local]
libpciaccess-dev/now 0.16-3 arm64 [installed,local]
libpciaccess0/now 0.16-3 arm64 [installed,local]
libpcre16-3/now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,local]
libpcre2-16-0/now 10.39-3ubuntu0.1 arm64 [installed,local]
libpcre2-32-0/now 10.39-3ubuntu0.1 arm64 [installed,local]
libpcre2-8-0/now 10.39-3ubuntu0.1 arm64 [installed,local]
libpcre2-dev/now 10.39-3ubuntu0.1 arm64 [installed,local]
libpcre2-posix3/now 10.39-3ubuntu0.1 arm64 [installed,local]
libpcre3-dev/now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,local]
libpcre32-3/now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,local]
libpcre3/now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,local]
libpcrecpp0v5/now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,local]
libperl5.34/now 5.34.0-3ubuntu1.3 arm64 [installed,local]
libpgm-5.3-0/now 5.3.128~dfsg-2 arm64 [installed,local]
libpixman-1-0/now 0.40.0-1ubuntu0.22.04.1 arm64 [installed,local]
libpixman-1-dev/now 0.40.0-1ubuntu0.22.04.1 arm64 [installed,local]
libpmix-dev/now 4.1.2-2ubuntu1 arm64 [installed,local]
libpmix2/now 4.1.2-2ubuntu1 arm64 [installed,local]
libpng-dev/now 1.6.37-3build5 arm64 [installed,local]
libpng16-16/now 1.6.37-3build5 arm64 [installed,local]
libpolkit-agent-1-0/now 0.105-33 arm64 [installed,local]
libpolkit-gobject-1-0/now 0.105-33 arm64 [installed,local]
libpostproc-dev/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libpostproc55/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libprocps8/now 2:3.3.17-6ubuntu2.1 arm64 [installed,local]
libpsl5/now 0.21.0-1.2build2 arm64 [installed,local]
libpthread-stubs0-dev/now 0.4-1build2 arm64 [installed,local]
libpython3-dev/now 3.10.6-1~22.04.1 arm64 [installed,local]
libpython3-stdlib/now 3.10.6-1~22.04.1 arm64 [installed,local]
libpython3.10-dev/now 3.10.12-1~22.04.6 arm64 [installed,local]
libpython3.10-minimal/now 3.10.12-1~22.04.6 arm64 [installed,local]
libpython3.10-stdlib/now 3.10.12-1~22.04.6 arm64 [installed,local]
libpython3.10/now 3.10.12-1~22.04.6 arm64 [installed,local]
libqt5core5a/now 5.15.3+dfsg-2ubuntu0.2 arm64 [installed,local]
libqt5dbus5/now 5.15.3+dfsg-2ubuntu0.2 arm64 [installed,local]
libqt5gui5/now 5.15.3+dfsg-2ubuntu0.2 arm64 [installed,local]
libqt5network5/now 5.15.3+dfsg-2ubuntu0.2 arm64 [installed,local]
libqt5opengl5/now 5.15.3+dfsg-2ubuntu0.2 arm64 [installed,local]
libqt5widgets5/now 5.15.3+dfsg-2ubuntu0.2 arm64 [installed,local]
librabbitmq4/now 0.10.0-1ubuntu2 arm64 [installed,local]
librdmacm1/now 39.0-1 arm64 [installed,local]
libreadline8/now 8.1.2-1 arm64 [installed,local]
librhash0/now 1.4.2-1ubuntu1 arm64 [installed,local]
librsvg2-2/now 2.52.5+dfsg-3ubuntu0.2 arm64 [installed,local]
librtmp1/now 2.4+20151223.gitfa8646d.1-2build4 arm64 [installed,local]
libsasl2-2/now 2.1.27+dfsg2-3ubuntu1.2 arm64 [installed,local]
libsasl2-modules-db/now 2.1.27+dfsg2-3ubuntu1.2 arm64 [installed,local]
libseccomp2/now 2.5.3-2ubuntu2 arm64 [installed,local]
libselinux1-dev/now 3.3-1build2 arm64 [installed,local]
libselinux1/now 3.3-1build2 arm64 [installed,local]
libsemanage-common/now 3.3-1build2 all [installed,local]
libsemanage2/now 3.3-1build2 arm64 [installed,local]
libsensors-config/now 1:3.6.0-7ubuntu1 all [installed,local]
libsensors5/now 1:3.6.0-7ubuntu1 arm64 [installed,local]
libsepol-dev/now 3.3-1build1 arm64 [installed,local]
libsepol2/now 3.3-1build1 arm64 [installed,local]
libshine3/now 3.1.1-2 arm64 [installed,local]
libsigsegv2/now 2.13-1ubuntu3 arm64 [installed,local]
libsm-dev/now 2:1.2.3-1build2 arm64 [installed,local]
libsm6/now 2:1.2.3-1build2 arm64 [installed,local]
libsmartcols1/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
libsnappy1v5/now 1.1.8-1build3 arm64 [installed,local]
libsndfile1/now 1.0.31-2ubuntu0.1 arm64 [installed,local]
libsodium23/now 1.0.18-1build2 arm64 [installed,local]
libsource-highlight-common/now 3.1.9-4.1build2 all [installed,local]
libsource-highlight4v5/now 3.1.9-4.1build2 arm64 [installed,local]
libsoxr0/now 0.1.3-4build2 arm64 [installed,local]
libspeex1/now 1.2~rc1.2-1.1ubuntu3 arm64 [installed,local]
libsqlite3-0/now 3.37.2-2ubuntu0.3 arm64 [installed,local]
libsrt1.4-gnutls/now 1.4.4-4 arm64 [installed,local]
libss2/now 1.46.5-2ubuntu1.2 arm64 [installed,local]
libssh-4/now 0.9.6-2ubuntu0.22.04.3 arm64 [installed,local]
libssh-gcrypt-4/now 0.9.6-2ubuntu0.22.04.3 arm64 [installed,local]
libssl3/now 3.0.2-0ubuntu1.18 arm64 [installed,local]
libstdc++-11-dev/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
libstdc++6/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libstemmer0d/now 2.2.0-1build1 arm64 [installed,local]
libswresample-dev/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libswresample3/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libswscale-dev/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libswscale5/now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,local]
libsystemd0/now 249.11-0ubuntu3.12 arm64 [installed,local]
libtasn1-6/now 4.18.0-4build1 arm64 [installed,local]
libtbb-dev/now 2021.5.0-7ubuntu2 arm64 [installed,local]
libtbb12/now 2021.5.0-7ubuntu2 arm64 [installed,local]
libtbb2/now 2020.3-1ubuntu3 arm64 [installed,local]
libtbbmalloc2/now 2021.5.0-7ubuntu2 arm64 [installed,local]
libtdb1/now 1.4.5-2build1 arm64 [installed,local]
libtesseract-dev/now 4.1.1-2.1build1 arm64 [installed,local]
libtesseract4/now 4.1.1-2.1build1 arm64 [installed,local]
libthai-data/now 0.1.29-1build1 all [installed,local]
libthai-dev/now 0.1.29-1build1 arm64 [installed,local]
libthai0/now 0.1.29-1build1 arm64 [installed,local]
libtheora0/now 1.1.1+dfsg.1-15ubuntu4 arm64 [installed,local]
libtiff-dev/now 4.3.0-6ubuntu0.10 arm64 [installed,local]
libtiff5/now 4.3.0-6ubuntu0.10 arm64 [installed,local]
libtiffxx5/now 4.3.0-6ubuntu0.10 arm64 [installed,local]
libtinfo6/now 6.3-2ubuntu0.1 arm64 [installed,local]
libtirpc-common/now 1.3.2-2ubuntu0.1 all [installed,local]
libtirpc-dev/now 1.3.2-2ubuntu0.1 arm64 [installed,local]
libtirpc3/now 1.3.2-2ubuntu0.1 arm64 [installed,local]
libtmglib-dev/now 3.10.0-2ubuntu1 arm64 [installed,local]
libtmglib3/now 3.10.0-2ubuntu1 arm64 [installed,local]
libtsan0/now 11.4.0-1ubuntu1~22.04 arm64 [installed,local]
libtwolame0/now 0.4.0-2build2 arm64 [installed,local]
libubsan1/now 12.3.0-1ubuntu1~22.04 arm64 [installed,local]
libucx0/now 1.12.1~rc2-1 arm64 [installed,local]
libudev-dev/now 249.11-0ubuntu3.12 arm64 [installed,local]
libudev1/now 249.11-0ubuntu3.12 arm64 [installed,local]
libudfread0/now 1.1.2-1 arm64 [installed,local]
libunistring2/now 1.0-1 arm64 [installed,local]
libunwind-dev/now 1.3.2-2build2.1 arm64 [installed,local]
libunwind8/now 1.3.2-2build2.1 arm64 [installed,local]
libuuid1/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
libuv1/now 1.43.0-1ubuntu0.1 arm64 [installed,local]
libv4l-0/now 1.22.1-2build1 arm64 [installed,local]
libv4l-dev/now 1.22.1-2build1 arm64 [installed,local]
libv4l2rds0/now 1.22.1-2build1 arm64 [installed,local]
libv4lconvert0/now 1.22.1-2build1 arm64 [installed,local]
libva-drm2/now 2.14.0-1 arm64 [installed,local]
libva-x11-2/now 2.14.0-1 arm64 [installed,local]
libva2/now 2.14.0-1 arm64 [installed,local]
libvdpau1/now 1.4-3build2 arm64 [installed,local]
libvorbis0a/now 1.3.7-1build2 arm64 [installed,local]
libvorbisenc2/now 1.3.7-1build2 arm64 [installed,local]
libvorbisfile3/now 1.3.7-1build2 arm64 [installed,local]
libvpx7/now 1.11.0-2ubuntu2.3 arm64 [installed,local]
libwacom-common/now 2.2.0-1 all [installed,local]
libwacom9/now 2.2.0-1 arm64 [installed,local]
libwayland-bin/now 1.20.0-1ubuntu0.1 arm64 [installed,local]
libwayland-client0/now 1.20.0-1ubuntu0.1 arm64 [installed,local]
libwayland-cursor0/now 1.20.0-1ubuntu0.1 arm64 [installed,local]
libwayland-dev/now 1.20.0-1ubuntu0.1 arm64 [installed,local]
libwayland-egl1/now 1.20.0-1ubuntu0.1 arm64 [installed,local]
libwayland-server0/now 1.20.0-1ubuntu0.1 arm64 [installed,local]
libwebp7/now 1.2.2-2ubuntu0.22.04.2 arm64 [installed,local]
libwebpmux3/now 1.2.2-2ubuntu0.22.04.2 arm64 [installed,local]
libx11-6/now 2:1.7.5-1ubuntu0.3 arm64 [installed,local]
libx11-data/now 2:1.7.5-1ubuntu0.3 all [installed,local]
libx11-dev/now 2:1.7.5-1ubuntu0.3 arm64 [installed,local]
libx11-xcb-dev/now 2:1.7.5-1ubuntu0.3 arm64 [installed,local]
libx11-xcb1/now 2:1.7.5-1ubuntu0.3 arm64 [installed,local]
libx264-163/now 2:0.163.3060+git5db6aa6-2build1 arm64 [installed,local]
libx264-dev/now 2:0.163.3060+git5db6aa6-2build1 arm64 [installed,local]
libx265-199/now 3.5-2 arm64 [installed,local]
libxau-dev/now 1:1.0.9-1build5 arm64 [installed,local]
libxau6/now 1:1.0.9-1build5 arm64 [installed,local]
libxcb-dri2-0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-dri3-0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-glx0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-icccm4/now 0.4.1-1.1build2 arm64 [installed,local]
libxcb-image0/now 0.4.0-2 arm64 [installed,local]
libxcb-keysyms1/now 0.4.0-1build3 arm64 [installed,local]
libxcb-present0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-randr0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-render-util0/now 0.3.9-1build3 arm64 [installed,local]
libxcb-render0-dev/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-render0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-shape0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-shm0-dev/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-shm0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-sync1/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-util1/now 0.4.0-1build2 arm64 [installed,local]
libxcb-xfixes0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-xinerama0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-xinput0/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb-xkb1/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb1-dev/now 1.14-3ubuntu3 arm64 [installed,local]
libxcb1/now 1.14-3ubuntu3 arm64 [installed,local]
libxcomposite-dev/now 1:0.4.5-1build2 arm64 [installed,local]
libxcomposite1/now 1:0.4.5-1build2 arm64 [installed,local]
libxcursor-dev/now 1:1.2.0-2build4 arm64 [installed,local]
libxcursor1/now 1:1.2.0-2build4 arm64 [installed,local]
libxdamage-dev/now 1:1.1.5-2build2 arm64 [installed,local]
libxdamage1/now 1:1.1.5-2build2 arm64 [installed,local]
libxdmcp-dev/now 1:1.1.3-0ubuntu5 arm64 [installed,local]
libxdmcp6/now 1:1.1.3-0ubuntu5 arm64 [installed,local]
libxext-dev/now 2:1.3.4-1build1 arm64 [installed,local]
libxext6/now 2:1.3.4-1build1 arm64 [installed,local]
libxfixes-dev/now 1:6.0.0-1 arm64 [installed,local]
libxfixes3/now 1:6.0.0-1 arm64 [installed,local]
libxft-dev/now 2.3.4-1 arm64 [installed,local]
libxft2/now 2.3.4-1 arm64 [installed,local]
libxi-dev/now 2:1.8-1build1 arm64 [installed,local]
libxi6/now 2:1.8-1build1 arm64 [installed,local]
libxine2-bin/now 1.2.11-2 arm64 [installed,local]
libxine2-dev/now 1.2.11-2 arm64 [installed,local]
libxinerama-dev/now 2:1.1.4-3 arm64 [installed,local]
libxinerama1/now 2:1.1.4-3 arm64 [installed,local]
libxkbcommon-dev/now 1.4.0-1 arm64 [installed,local]
libxkbcommon-x11-0/now 1.4.0-1 arm64 [installed,local]
libxkbcommon0/now 1.4.0-1 arm64 [installed,local]
libxml2-utils/now 2.9.13+dfsg-1ubuntu0.4 arm64 [installed,local]
libxml2/now 2.9.13+dfsg-1ubuntu0.4 arm64 [installed,local]
libxmlb2/now 0.3.6-2build1 arm64 [installed,local]
libxmu-dev/now 2:1.1.3-3 arm64 [installed,local]
libxmu-headers/now 2:1.1.3-3 all [installed,local]
libxmu6/now 2:1.1.3-3 arm64 [installed,local]
libxnvctrl0/now 510.47.03-0ubuntu1 arm64 [installed,local]
libxrandr-dev/now 2:1.5.2-1build1 arm64 [installed,local]
libxrandr2/now 2:1.5.2-1build1 arm64 [installed,local]
libxrender-dev/now 1:0.9.10-1build4 arm64 [installed,local]
libxrender1/now 1:0.9.10-1build4 arm64 [installed,local]
libxshmfence1/now 1.3-1build4 arm64 [installed,local]
libxt-dev/now 1:1.2.1-1 arm64 [installed,local]
libxt6/now 1:1.2.1-1 arm64 [installed,local]
libxtst-dev/now 2:1.2.3-1build4 arm64 [installed,local]
libxtst6/now 2:1.2.3-1build4 arm64 [installed,local]
libxvidcore-dev/now 2:1.3.7-1 arm64 [installed,local]
libxvidcore4/now 2:1.3.7-1 arm64 [installed,local]
libxxf86vm1/now 1:1.1.4-1build3 arm64 [installed,local]
libxxhash0/now 0.8.1-1 arm64 [installed,local]
libyaml-0-2/now 0.2.2-1build2 arm64 [installed,local]
libzmq5/now 4.3.4-2 arm64 [installed,local]
libzstd1/now 1.4.8+dfsg-3build1 arm64 [installed,local]
libzvbi-common/now 0.2.35-19 all [installed,local]
libzvbi0/now 0.2.35-19 arm64 [installed,local]
linux-libc-dev/now 5.15.0-122.132 arm64 [installed,local]
locales-all/now 2.35-0ubuntu3.8 arm64 [installed,local]
locales/now 2.35-0ubuntu3.8 all [installed,local]
login/now 1:4.8.1-2ubuntu2.2 arm64 [installed,local]
logsave/now 1.46.5-2ubuntu1.2 arm64 [installed,local]
lsb-base/now 11.1.0ubuntu4 all [installed,local]
lsb-release/now 11.1.0ubuntu4 all [installed,local]
lto-disabled-list/now 24 all [installed,local]
m4/now 1.4.18-5ubuntu2 arm64 [installed,local]
make/now 4.3-4.1build1 arm64 [installed,local]
mawk/now 1.3.4.20200120-3 arm64 [installed,local]
media-types/now 7.0.0 all [installed,local]
mount/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
nano/now 6.2-1 arm64 [installed,local]
ncurses-base/now 6.3-2ubuntu0.1 all [installed,local]
ncurses-bin/now 6.3-2ubuntu0.1 arm64 [installed,local]
nsight-compute-2024.3.1/now 2024.3.1.2-1 arm64 [installed,local]
ocl-icd-libopencl1/now 2.2.14-3 arm64 [installed,local]
openmpi-bin/now 4.1.2-2ubuntu1 arm64 [installed,local]
openmpi-common/now 4.1.2-2ubuntu1 all [installed,local]
openssh-client/now 1:8.9p1-3ubuntu0.10 arm64 [installed,local]
openssl/now 3.0.2-0ubuntu1.18 arm64 [installed,local]
packagekit/now 1.2.5-2ubuntu2 arm64 [installed,local]
pango1.0-tools/now 1.50.6+ds-2ubuntu1 arm64 [installed,local]
passwd/now 1:4.8.1-2ubuntu2.2 arm64 [installed,local]
patch/now 2.7.6-7build2 arm64 [installed,local]
perl-base/now 5.34.0-3ubuntu1.3 arm64 [installed,local]
perl-modules-5.34/now 5.34.0-3ubuntu1.3 all [installed,local]
perl/now 5.34.0-3ubuntu1.3 arm64 [installed,local]
pinentry-curses/now 1.1.1-1build2 arm64 [installed,local]
pkexec/now 0.105-33 arm64 [installed,local]
pkg-config/now 0.29.2-1ubuntu3 arm64 [installed,local]
policykit-1/now 0.105-33 arm64 [installed,local]
polkitd/now 0.105-33 arm64 [installed,local]
procps/now 2:3.3.17-6ubuntu2.1 arm64 [installed,local]
python-apt-common/now 2.4.0ubuntu4 all [installed,local]
python3-apt/now 2.4.0ubuntu4 arm64 [installed,local]
python3-blinker/now 1.4+dfsg1-0.4 all [installed,local]
python3-cffi-backend/now 1.15.0-1build2 arm64 [installed,local]
python3-cryptography/now 3.4.8-1ubuntu2.2 arm64 [installed,local]
python3-dbus/now 1.2.18-3build1 arm64 [installed,local]
python3-distro/now 1.7.0-1 all [installed,local]
python3-distutils/now 3.10.8-1~22.04 all [installed,local]
python3-gi/now 3.42.1-0ubuntu1 arm64 [installed,local]
python3-httplib2/now 0.20.2-2 all [installed,local]
python3-importlib-metadata/now 4.6.4-1 all [installed,local]
python3-jeepney/now 0.7.1-3 all [installed,local]
python3-jwt/now 2.3.0-1ubuntu0.2 all [installed,local]
python3-keyring/now 23.5.0-1 all [installed,local]
python3-launchpadlib/now 1.10.16-1 all [installed,local]
python3-lazr.restfulclient/now 0.14.4-1 all [installed,local]
python3-lazr.uri/now 1.0.6-2 all [installed,local]
python3-lib2to3/now 3.10.8-1~22.04 all [installed,local]
python3-minimal/now 3.10.6-1~22.04.1 arm64 [installed,local]
python3-more-itertools/now 8.10.0-2 all [installed,local]
python3-numpy/now 1:1.21.5-1ubuntu22.04.1 arm64 [installed,local]
python3-oauthlib/now 3.2.0-1ubuntu0.1 all [installed,local]
python3-pip/now 22.0.2+dfsg-1ubuntu0.4 all [installed,local]
python3-pkg-resources/now 59.6.0-1.2ubuntu0.22.04.2 all [installed,local]
python3-pyparsing/now 2.4.7-1 all [installed,local]
python3-secretstorage/now 3.3.1-1 all [installed,local]
python3-setuptools/now 59.6.0-1.2ubuntu0.22.04.2 all [installed,local]
python3-six/now 1.16.0-3ubuntu1 all [installed,local]
python3-software-properties/now 0.99.22.9 all [installed,local]
python3-wadllib/now 1.3.6-1 all [installed,local]
python3-wheel/now 0.37.1-2ubuntu0.22.04.1 all [installed,local]
python3-zipp/now 1.0.0-3ubuntu0.1 all [installed,local]
python3/now 3.10.6-1~22.04.1 arm64 [installed,local]
qv4l2/now 1.22.1-2build1 arm64 [installed,local]
readline-common/now 8.1.2-1 all [installed,local]
rpcsvc-proto/now 1.4.2-0ubuntu6 arm64 [installed,local]
sed/now 4.8-1ubuntu2 arm64 [installed,local]
sensible-utils/now 0.0.17 all [installed,local]
shared-mime-info/now 2.1-2 arm64 [installed,local]
software-properties-common/now 0.99.22.9 all [installed,local]
sound-theme-freedesktop/now 0.8-2ubuntu1 all [installed,local]
sshpass/now 1.09-1 arm64 [installed,local]
systemd-sysv/now 249.11-0ubuntu3.12 arm64 [installed,local]
sysvinit-utils/now 3.01-1ubuntu1 arm64 [installed,local]
tar/now 1.34+dfsg-1ubuntu0.1.22.04.2 arm64 [installed,local]
time/now 1.9-0.1build2 arm64 [installed,local]
tzdata/now 2024a-0ubuntu0.22.04.1 all [installed,local]
ubuntu-keyring/now 2021.03.26 all [installed,local]
ubuntu-mono/now 20.10-0ubuntu2 all [installed,local]
ucf/now 3.0043 all [installed,local]
unzip/now 6.0-26ubuntu3.2 arm64 [installed,local]
usrmerge/now 25ubuntu2 all [installed,local]
util-linux/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
uuid-dev/now 2.37.2-4ubuntu3.4 arm64 [installed,local]
v4l-utils/now 1.22.1-2build1 arm64 [installed,local]
wayland-protocols/now 1.25-1 all [installed,local]
wget/now 1.21.2-2ubuntu1.1 arm64 [installed,local]
x11-common/now 1:7.7+23ubuntu2 all [installed,local]
x11proto-dev/now 2021.5-1 all [installed,local]
xkb-data/now 2.33-1 all [installed,local]
xorg-sgml-doctools/now 1:1.11-1.1 all [installed,local]
xtrans-dev/now 1.4.0-1 all [installed,local]
xz-utils/now 5.2.5-2ubuntu1 arm64 [installed,local]
zip/now 3.0-12build2 arm64 [installed,local]
zlib1g-dev/now 1:1.2.11.dfsg-2ubuntu9.2 arm64 [installed,local]
zlib1g/now 1:1.2.11.dfsg-2ubuntu9.2 arm64 [installed,local]
root@kkkORIN:/#
it did not run a build command i assume is because the following are still present in my “docker images”
dustynv/tensorrt_llm 0.12-r36.4.0 725bd34b8924 2 months ago 18.5GB
nvcr.io/nvidia/l4t-jetpack r36.4.0 51f1e16a5dd9 3 months ago 9.83GB
dustynv/l4t-pytorch r36.4.0 71721487f205 4 months ago 12.6GB
╭─kkk at kkkORIN in ~/apps 25-02-08 - 13:37:50
╰─○ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
kairin/jetson-containers latest-r36.4.3-build-essential 99f10edee4ac 31 hours ago 976MB
comf5/jetson-containers latest-r36.4.3-cu126 adf4aed7cba5 32 hours ago 14.5GB
comf5/jetson-containers latest-r36.4.3-cu126-comfyui adf4aed7cba5 32 hours ago 14.5GB
comf5/jetson-containers latest-r36.4.3-cu126-manifold 55deb36250df 32 hours ago 13.1GB
comf5/jetson-containers latest-r36.4.3-cu126-vhacdx afc2ddf7150c 32 hours ago 13GB
comf5/jetson-containers latest-r36.4.3-cu126-tinycudann e009380fe524 32 hours ago 12.3GB
comf6/jetson-containers latest-r36.4.3-cu126-numpy 69fda10c44cb 32 hours ago 923MB
comf6/jetson-containers latest-r36.4.3-cu126-cmake 469d5e2aced9 32 hours ago 867MB
comf6/jetson-containers latest-r36.4.3-cu126-python 14aec248a58e 32 hours ago 804MB
comf5/jetson-containers latest-r36.4.3-cu126-polyscope a80e6172b591 34 hours ago 12.1GB
comf5/jetson-containers latest-r36.4.3-cu126-ninja 61d7a28b303f 34 hours ago 12.1GB
comf6/jetson-containers latest-r36.4.3-cu126-ninja 61d7a28b303f 34 hours ago 12.1GB
comf5/jetson-containers latest-r36.4.3-cu126-ffmpeg e05d5a3c0b52 34 hours ago 12GB
comf6/jetson-containers latest-r36.4.3-cu126-ffmpeg e05d5a3c0b52 34 hours ago 12GB
comf6/jetson-containers latest-r36.4.3-cu126-torch 3643d99a823a 34 hours ago 11.8GB
comf5/jetson-containers latest-r36.4.3-cu126-torch 3643d99a823a 34 hours ago 11.8GB
comf5/jetson-containers latest-r36.4.3-cu126-diffusers eb2afa480a46 34 hours ago 11.8GB
comf6/jetson-containers latest-r36.4.3-cu126-diffusers eb2afa480a46 34 hours ago 11.8GB
comf5/jetson-containers latest-r36.4.3-cu126-torchao 5c440025826b 34 hours ago 11.6GB
comf6/jetson-containers latest-r36.4.3-cu126-torchao 5c440025826b 34 hours ago 11.6GB
comf5/jetson-containers latest-r36.4.3-cu126-xformers 6af534174393 34 hours ago 11.6GB
comf6/jetson-containers latest-r36.4.3-cu126-xformers 6af534174393 34 hours ago 11.6GB
comf5/jetson-containers latest-r36.4.3-cu126-bitsandbytes 125fe1825fec 34 hours ago 11GB
comf6/jetson-containers latest-r36.4.3-cu126-bitsandbytes 125fe1825fec 34 hours ago 11GB
comf5/jetson-containers latest-r36.4.3-cu126-triton 6ea02e47206d 34 hours ago 10.8GB
comf6/jetson-containers latest-r36.4.3-cu126-triton 6ea02e47206d 34 hours ago 10.8GB
comf5/jetson-containers latest-r36.4.3-cu126-transformers a03449d0fc9d 34 hours ago 10.3GB
comf6/jetson-containers latest-r36.4.3-cu126-transformers a03449d0fc9d 34 hours ago 10.3GB
comf6/jetson-containers latest-r36.4.3-cu126-rust db31071f60c0 34 hours ago 10.2GB
comf5/jetson-containers latest-r36.4.3-cu126-rust db31071f60c0 34 hours ago 10.2GB
comf5/jetson-containers latest-r36.4.3-cu126-huggingface_hub 79017616fe80 34 hours ago 8.73GB
comf6/jetson-containers latest-r36.4.3-cu126-huggingface_hub 79017616fe80 34 hours ago 8.73GB
comf5/jetson-containers latest-r36.4.3-cu126-opencv 72fe427baf0a 34 hours ago 8.72GB
comf6/jetson-containers latest-r36.4.3-cu126-opencv 72fe427baf0a 34 hours ago 8.72GB
comf5/jetson-containers latest-r36.4.3-cu126-torchaudio a67ff3e14c94 34 hours ago 8.11GB
comf6/jetson-containers latest-r36.4.3-cu126-torchaudio a67ff3e14c94 34 hours ago 8.11GB
comf5/jetson-containers latest-r36.4.3-cu126-jetson-inference_main d4d1de598854 34 hours ago 13.8GB
comf5/jetson-containers latest-r36.4.3-cu126-gstreamer 71dcd2960400 34 hours ago 12.7GB
comf5/jetson-containers latest-r36.4.3-cu126-tensorrt e8daba556079 34 hours ago 11.1GB
comf5/jetson-containers latest-r36.4.3-cu126-torchvision 0dfb91650945 34 hours ago 8.09GB
comf6/jetson-containers latest-r36.4.3-cu126-torchvision 0dfb91650945 34 hours ago 8.09GB
comf5/jetson-containers latest-r36.4.3-cu126-pytorch 997e2d5bde69 34 hours ago 8.07GB
comf5/jetson-containers latest-r36.4.3-cu126-pytorch_2.5 997e2d5bde69 34 hours ago 8.07GB
comf6/jetson-containers latest-r36.4.3-cu126-pytorch_2.5 997e2d5bde69 34 hours ago 8.07GB
comf5/jetson-containers latest-r36.4.3-cu126-onnx bd1d87f3ecd4 34 hours ago 7.15GB
comf6/jetson-containers latest-r36.4.3-cu126-onnx bd1d87f3ecd4 34 hours ago 7.15GB
comf5/jetson-containers latest-r36.4.3-cu126-cmake 50ec6e9b7d20 34 hours ago 7.11GB
comf5/jetson-containers latest-r36.4.3-cu126-numpy c3aae2c1a3bc 34 hours ago 7.05GB
comf5/jetson-containers latest-r36.4.3-cu126-python f411644ddaa7 34 hours ago 6.99GB
comf5/jetson-containers latest-r36.4.3-cu126-cudnn a2c5e4298913 34 hours ago 6.92GB
comf5/jetson-containers latest-r36.4.3-cu126-cudnn_9.4 a2c5e4298913 34 hours ago 6.92GB
comf6/jetson-containers latest-r36.4.3-cu126-cudnn a2c5e4298913 34 hours ago 6.92GB
comf5/jetson-containers latest-r36.4.3-cu126-cuda_12.6 79212e4629fa 34 hours ago 5.92GB
comf6/jetson-containers latest-r36.4.3-cu126-cuda_12.6 79212e4629fa 34 hours ago 5.92GB
comf5/jetson-containers latest-r36.4.3-cu126-pip_cache_cu126 0c698369babd 34 hours ago 734MB
comf6/jetson-containers latest-r36.4.3-cu126-pip_cache 0c698369babd 34 hours ago 734MB
comf6/jetson-containers latest-r36.4.3-cu126-pip_cache_cu126 0c698369babd 34 hours ago 734MB
comf4/jetson-containers latest-r36.4.3 ebbc8ed414b7 3 days ago 1.33GB
comf4/jetson-containers latest-r36.4.3-ffmpeg ebbc8ed414b7 3 days ago 1.33GB
ffmpeg r36.4.3 f5657a282772 3 days ago 1.05GB
ffmpeg r36.4.3-ffmpeg f5657a282772 3 days ago 1.05GB
comf5/jetson-containers latest-r36.4.3-cu126-build-essential c78dc9bda5a3 3 days ago 734MB
comf6/jetson-containers latest-r36.4.3-cu126-build-essential c78dc9bda5a3 3 days ago 734MB
ffmpeg r36.4.3-build-essential c78dc9bda5a3 3 days ago 734MB
haminawireless/opencv latest c4a9162bada9 4 days ago 288MB
dustynv/awq r36.4.0 0340f6fe56ac 5 days ago 12.4GB
dustynv/mlc r36.4.0 cc5b6be6b081 7 days ago 14.2GB
dustynv/llama_cpp r36.4.0 0d8066b1a9a4 7 days ago 8.3GB
dustynv/ollama main-r36.4.0 106156aed7a0 8 days ago 3.95GB
dustynv/ollama r36.4.0 7829cba6119a 8 days ago 6.03GB
ubuntu 22.04 560582227a09 13 days ago 69.2MB
nvcr.io/nvidia/cuda-dl-base 25.01-cuda12.8-devel-ubuntu24.04 5c74a4dcc35d 2 weeks ago 9.7GB
moby/buildkit buildx-stable-1 1ba5a86e6415 2 weeks ago 209MB
nvcr.io/nvidia/pytorch 25.01-py3-igpu f31f25265258 2 weeks ago 10.8GB
dustynv/vllm 0.6.6.post1-r36.4.0 c54cee5e99bf 3 weeks ago 14.4GB
dustynv/nanodb r36.4.0 042160c2c8df 3 weeks ago 15.1GB
dustynv/comfyui r36.4.0 92b71a6683ae 5 weeks ago 18.9GB
python 3.10.16 926dcac5aa27 2 months ago 1.01GB
dustynv/opencv r36.3.0 46f4eaa32881 3 months ago 10.7GB
kairin/jetson-containers l4t-pytorch-jetpack-tensorrt_llm-0.12-r36.4.0 71721487f205 4 months ago 12.6GB
nvcr.io/nvidia/l4t-cuda 12.6.11-runtime 0efb2f2b7fad 5 months ago 2.09GB
dustynv/jetson-inference r36.2.0 b2583c97b9b1 7 months ago 14.8GB
╭─kkk at kkkORIN in ~/apps 25-02-08 - 13:37:53
