Hello I have a pc that can use gpu, but I couldn’t run a docker there that use the gpu. How can I run gpu using containers?
Dockerfile:
FROM nvcr.io/nvidia/tensorflow:21.12-tf2-py3
Comands to build Image and run container:
sudo docker build --tag=solonvidiatensorflow:latest .
sudo docker run --tty --detach --name container_nvidiatensorflow solonvidiatensorflow:latest
If I run:
a)
a.1)
nvidia-smi:
Fri Jun 24 16:10:44 2022
| NVIDIA-SMI 495.29.05 Driver Version: 495.29.05 CUDA Version: 11.5 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:01:00.0 On | N/A |
| 0% 41C P0 28W / 200W | 278MiB / 6078MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1705 G /usr/lib/xorg/Xorg 175MiB |
| 0 N/A N/A 1838 G /usr/bin/gnome-shell 27MiB |
| 0 N/A N/A 2435 G …AAAAAAAAA= --shared-files 71MiB |
a.2)
sudo docker exec container_nvidiatensorflow nvidia-smi:
OCI runtime exec failed: exec failed: unable to start container process: exec: “nvidia-smi”: executable file not found in $PATH: unknown
b)
b.1)
python3 -c “import tensorflow as tf ; print('Num GPUs Available: ', len(tf.config.list_physical_devices(‘GPU’)))”:
2022-06-24 17:11:33.019941: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-06-24 17:11:33.038839: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-06-24 17:11:33.038983: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
Num GPUs Available: 1
b.2)
sudo docker exec container_nvidiatensorflow python3 -c “import tensorflow as tf ; print('Num GPUs Available: ', len(tf.config.list_physical_devices(‘GPU’)))”:
2022-06-24 21:21:30.820790: W tensorflow/stream_executor/platform/default/dso_loader.cc:65] Could not load dynamic library ‘libcuda.so.1’; dlerror: libcuda.so.1: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda/extras/CUPTI/lib64:/usr/local/cuda/compat/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64
2022-06-24 21:21:30.820806: W tensorflow/stream_executor/cuda/cuda_driver.cc:269] failed call to cuInit: UNKNOWN ERROR (303)
2022-06-24 21:21:30.820816: I tensorflow/stream_executor/cuda/cuda_diagnostics.cc:163] no NVIDIA GPU device is present: /dev/nvidia0 does not exist
Num GPUs Available: 0
c)
c.1)
python3 -c “import tensorflow as tf ; print(tf.test.gpu_device_name())”
2022-06-24 17:14:26.986965: I tensorflow/core/platform/cpu_feature_guard.cc:151] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX2 AVX512F FMA
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2022-06-24 17:14:27.016277: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-06-24 17:14:27.035709: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-06-24 17:14:27.035852: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-06-24 17:14:27.307803: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-06-24 17:14:27.307963: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-06-24 17:14:27.308069: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:939] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2022-06-24 17:14:27.308173: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1525] Created device /device:GPU:0 with 4948 MB memory: → device: 0, name: NVIDIA GeForce GTX 1060 6GB, pci bus id: 0000:01:00.0, compute capability: 6.1
/device:GPU:0
c.2)
sudo docker exec container_nvidiatensorflow python3 -c “import tensorflow as tf ; print(tf.test.gpu_device_name())”:
2022-06-24 21:22:29.321447: W tensorflow/stream_executor/platform/default/dso_loader.cc:65] Could not load dynamic library ‘libcuda.so.1’; dlerror: libcuda.so.1: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda/extras/CUPTI/lib64:/usr/local/cuda/compat/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64
2022-06-24 21:22:29.321463: W tensorflow/stream_executor/cuda/cuda_driver.cc:269] failed call to cuInit: UNKNOWN ERROR (303)
2022-06-24 21:22:29.321477: I tensorflow/stream_executor/cuda/cuda_diagnostics.cc:163] no NVIDIA GPU device is present: /dev/nvidia0 does not exist
If you need further information just ask me
Thanks in advance!
