Failure to call to cuInit in nvidia-docker2
PROBLEM:
tensorflow:latest-gpu docker image tf.config not detecting GPU
failed call to cuInit in nvidia-docker2
docker run --env TF_ENABLE_ONEDNN_OPTS=0 -it --rm tensorflow/tensorflow:latest-gpu  python -c "import tensorflow as tf; print(\"Num GPUs Available: \", len(tf.config.list_physical_devices('GPU')))"
2023-05-06 09:45:58.721496: I tensorflow/core/platform/cpu_feature_guard.cc:182] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: AVX2 AVX_VNNI FMA, in other operations, rebuild TensorFlow with the appropriate compiler flags.
2023-05-06 09:45:59.416662: E tensorflow/compiler/xla/stream_executor/cuda/cuda_driver.cc:266] failed call to cuInit: UNKNOWN ERROR (34)
Num GPUs Available: 0
Docker GPU is detectable:
docker run --rm --gpus all nvidia/cuda:12.0.0-base-ubuntu20.04 nvidia-smi
Sat May 6 09:39:11 2023
| NVIDIA-SMI 530.41.03 Driver Version: 530.41.03 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4090 L… Off| 00000000:01:00.0 Off | N/A |
| N/A 42C P0 32W / N/A| 6MiB / 16376MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
running on:
- Asus ROG STRIX 18 with RTX 4090
- Ubuntu 22.04 LTS
specs
  • installed
    • nvidia-driver-530
    • nvidia-cuda-toolkit
    • nvidia-container-toolkit-base
    • docker
    • nvidia-docker2
diagnostics
hardware:
cat /proc/cpuinfo | grep "model name" -m 1
model name : 13th Gen Intel(R) Core™ i9-13980HX
dmidecode -t 2
SMBIOS 3.5.0
Base Board Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: G834JY
lspci | grep -e VGA
0000:00:02.0 VGA compatible controller: Intel Corporation Device a788 (rev 04)
0000:01:00.0 VGA compatible controller: NVIDIA Corporation Device 2757 (rev a1)
nvidia-settings -q CUDACores -t
9728
nvidia-smi
Sat May 6 12:17:10 2023
| | | MIG M. |
| N/A 39C P0 N/A / N/A| 6MiB / 16376MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2783 G /usr/lib/xorg/Xorg 4MiB |
software:
lsmod | grep nvidia
nvidia_wmi_ec_backlight 16384 0
nvidia_uvm 1433600 0
nvidia_drm 77824 2
nvidia_modeset 1273856 3 nvidia_drm
nvidia 55750656 99 nvidia_uvm,nvidia_modeset
drm_kms_helper 200704 3 drm_display_helper,nvidia_drm,i915
drm 581632 19 drm_kms_helper,drm_display_helper,nvidia,drm_buddy,nvidia_drm,i915,ttm
wmi 32768 4 nvidia_wmi_ec_backlight,asus_wmi,wmi_bmof,mfd_aaeon
docker version
Version: 23.0.5
API version: 1.42
OS/Arch: linux/amd64
nvcc --version
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Thu_Nov_18_09:45:30_PST_2021
Cuda compilation tools, release 11.5, V11.5.119
Build cuda_11.5.r11.5/compiler.30672275_0
Did you manage to solve it? because i have the exact same problem as yours and i can’t find any solution…
You’re missing the --gpus all option in the docker command.
