Docker instantiation failed with error: 500 Server Error: Internal Server Error ("could not select device driver "" with capabilities: [[gpu]]")
please i have a problem when i run the command
tlt detectnet_v2 --help
I get this error:
Docker instantiation failed with error: 500 Server Error: Internal Server Error ("could not select device driver" "with capabilities: [[gpu]]")
I tried to solve it with the reinstatement of Nvidia driver but without success “Installation Guide — NVIDIA Cloud Native Technologies documentation
any suggestions please
thank you
Can you run below successfully?
$ tlt info
$ tlt --help
yes, successfully
Can you share more log about tlt detectnet_v2 --help?
What is the result of “$ nvidia-smi” ?
Thanks for the info.
Could you double check Transfer Learning Toolkit — Transfer Learning Toolkit 3.0 documentation ?
BTW, there is a similar topic Docker: Error response from daemon: could not select device driver "" with capabilities: [[gpu]] - #4 by ocutrxvisiontech.
I solved the problem by resetting everything
@sylia, could you please tell me what do you do reset.
https://docs.nvidia.com/metropolis/TLT/tlt-user-guide/text/requirements_and_installation.html
