Docker instantiation failed with error: 500 when trying to retrain DashCamNet
Docker instantiation failed with error: 500 Server Error: Internal Server Error (“OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: detection error: nvml error: unknown error: unknown”)
• Hardware: RTX 2080
• Network Type: Dashcamnet
• TLT Version: Configuration of the TLT Instance
dockers: [‘nvidia/tlt-streamanalytics’, ‘nvidia/tlt-pytorch’]
format_version: 1.0
tlt_version: 3.0
•Config specs:
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: “/workspace/tlt-experiments/data/tfrecords/kitti_trainval/*”
image_directory_path: “/workspace/tlt-experiments/data/training”
image_extension: “png”
target_class_mapping {
key: “pedestrian”
value: “pedestrian”
key: “person”
value: “pedestrian”
key: “car”
value: “car”
key: “two_wheels”
value: “two_wheels”
key: “head_covered”
value: “head_covered”
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 544
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: “pedestrian”
value {
clustering_config {
clustering_algorithm: DBSCAN
dbscan_confidence_threshold: 0.9
coverage_threshold: 0.00749999983236
dbscan_eps: 0.230000004172
dbscan_min_samples: 0.0500000007451
minimum_bounding_box_height: 20
key: “car”
value: {
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.1
minimum_bounding_box_height: 4
key: “two_wheels”
value: {
clustering_config {
dbscan_eps: 0.1
key: “head_covered”
value: {
clustering_config {
dbscan_eps: 0.1
model_config {
pretrained_model_file: “/workspace/tlt-experiments/detectnet_v2/pretrained_dashcam/tlt_dashcamnet_vunpruned_v1.0/resnet18_dashcamnet.tlt”
num_layers: 18
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: “resnet”
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 30
minimum_detection_ground_truth_overlap {
key: “pedestrian”
value: 0.5
key: “car”
value: 0.699999988079
key: “two_wheels”
value: 0.5
key: “head_covered”
value: 0.5
evaluation_box_config {
key: “pedestrian”
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
key: “car”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: “two_wheels”
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: “head_covered”
value {
minimum_height: 5
minimum_width: 5
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 4.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 8.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 80
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: “pedestrian”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
bbox_min_radius: 1.0
key: “car”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.40000000596
cov_radius_y: 0.40000000596
key: “two_wheels”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: “head_covered”
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.400000154972
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
When running:
!tlt detectnet_v2 train -e $SPECS_DIR/dashcamnet_train_resnet18_kitti.txt
-r $USER_EXPERIMENT_DIR/dashcam_dir_unpruned
-k $KEY
-n dashcam_detector
–gpus $NUM_GPUS}
I get:
Tfrecords were generated successfully, images have been resized offline to 960x544, .png extension.
Can you post the result of
$ nvidia-smi
Running nvidias-smi returns:
Unable to determine the device handle for GPU 0000:01:00.0: Unknown Error
Can you get nvidia-smi work well?
Did you ever install this nvidia driver?
I have the drivers installed and they were working fine, nvidia smi worked fine until I got the error mentioned above. Since then, it has stopped working
It’s solved by restarting the server, but will eventually fail again. I’ve no idea what’s causing it but it is working right now
Thanks for the info. After installing nvidia driver, it is needed to restart.
