I am trying to train detectNet with your jupyter notebook. I got the same error with both my custom data and the data I downloaded (from the links inside the notebook).
I ran docker login nvcr.io and logged in successfully, but then I ran the command
jupyter notebook --ip 0.0.0.0 --allow-root --port 8888
without docker pull or docker run…
error is printed below
• Hardware GeForce RTX 2080 Ti
• Network Type Detectnet_v2
• TLT Version format_version: 2.0
toolkit_version: 4.0.1
published_date: 03/06/2023
4.0.0-tf1.15.5: docker_registry: nvcr.io
• Training spec file
nanovel_detectnet_v2_train_resnet18_kitti.txt (3.7 KB)
• How to reproduce the issue ?
!tao detectnet_v2 train -e $SPECS_DIR/nanovel_detectnet_v2_train_resnet18_kitti.txt \
-r $USER_EXPERIMENT_DIR/experiment_dir_unpruned \
-k $KEY \
-n resnet18_detector \
--gpus $NUM_GPUS
This is the error I got:
tensorflow.python.framework.errors_impl.InternalError: CUDA runtime implicit initialization on GPU:0 failed. Status: the provided PTX was compiled with an unsupported toolchain.
Telemetry data couldn't be sent, but the command ran successfully.
[WARNING]: <urlopen error [Errno -2] Name or service not known>
File "<frozen iva.detectnet_v2.training.utilities>", line 143, in get_singular_monitored_session
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1104, in __init__
Thanks for your help
