Object was never used (type <class 'tensorflow.python.framework.ops.Tensor'>)
Everything worked fine for me locally.
But I had to transfer the entire environment and model to another computer.
After I did this, I did all the operations again
I logged into docker, I downloaded the docker image, set the environment variables.
And to start training, I first converted the data to tfrecords and this also went well, but when I start training I get:
2022-02-18 10:21:47,895 [INFO] root: Registry: ['nvcr.io']
2022-02-18 10:21:47,999 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.4-py3
2022-02-18 10:21:48,073 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/dima/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
2022-02-18 08:21:55,717 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-02-18 08:21:56,318 [INFO] iva.common.logging.logging: Log file already exists at /workspace/tao-experiments/exp/tcn_d1_finetune1/status.json
2022-02-18 08:21:56,318 [INFO] __main__: Loading experiment spec at /workspace/tao-experiments/specs/trafficcamnet_finetune.txt.
2022-02-18 08:21:56,319 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/tao-experiments/specs/trafficcamnet_finetune.txt
2022-02-18 08:22:07,106 [INFO] __main__: Cannot iterate over exactly 161273 samples with a batch size of 2; each epoch will therefore take one extra step.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was *not* compiled. Compile it manually.
  warnings.warn('No training configuration found in save file: '
2022-02-18 08:22:16,639 [INFO] iva.detectnet_v2.objectives.bbox_objective: Default L1 loss function will be used.
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
input_1 (InputLayer)            (None, 3, 544, 960)  0
conv1 (Conv2D)                  (None, 64, 272, 480) 9472        input_1[0][0]
bn_conv1 (BatchNormalization)   (None, 64, 272, 480) 256         conv1[0][0]
activation_1 (Activation)       (None, 64, 272, 480) 0           bn_conv1[0][0]
block_1a_conv_1 (Conv2D)        (None, 64, 136, 240) 36928       activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 136, 240) 256         block_1a_conv_1[0][0]
block_1a_relu_1 (Activation)    (None, 64, 136, 240) 0           block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D)        (None, 64, 136, 240) 36928       block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 136, 240) 4160        activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 136, 240) 256         block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 136, 240) 256         block_1a_conv_shortcut[0][0]
add_1 (Add)                     (None, 64, 136, 240) 0           block_1a_bn_2[0][0]
        block_1a_bn_shortcut[0][0]
block_1a_relu (Activation)      (None, 64, 136, 240) 0           add_1[0][0]
block_1b_conv_1 (Conv2D)        (None, 64, 136, 240) 36928       block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 136, 240) 256         block_1b_conv_1[0][0]
block_1b_relu_1 (Activation)    (None, 64, 136, 240) 0           block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D)        (None, 64, 136, 240) 36928       block_1b_relu_1[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 136, 240) 256         block_1b_conv_2[0][0]
add_2 (Add)                     (None, 64, 136, 240) 0           block_1b_bn_2[0][0]
        block_1a_relu[0][0]
block_1b_relu (Activation)      (None, 64, 136, 240) 0           add_2[0][0]
block_2a_conv_1 (Conv2D)        (None, 128, 68, 120) 73856       block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 68, 120) 512         block_2a_conv_1[0][0]
block_2a_relu_1 (Activation)    (None, 128, 68, 120) 0           block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D)        (None, 128, 68, 120) 147584      block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 68, 120) 8320        block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 68, 120) 512         block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 68, 120) 512         block_2a_conv_shortcut[0][0]
add_3 (Add)                     (None, 128, 68, 120) 0           block_2a_bn_2[0][0]
        block_2a_bn_shortcut[0][0]
block_2a_relu (Activation)      (None, 128, 68, 120) 0           add_3[0][0]
block_2b_conv_1 (Conv2D)        (None, 128, 68, 120) 147584      block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 68, 120) 512         block_2b_conv_1[0][0]
block_2b_relu_1 (Activation)    (None, 128, 68, 120) 0           block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D)        (None, 128, 68, 120) 147584      block_2b_relu_1[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 68, 120) 512         block_2b_conv_2[0][0]
add_4 (Add)                     (None, 128, 68, 120) 0           block_2b_bn_2[0][0]
        block_2a_relu[0][0]
block_2b_relu (Activation)      (None, 128, 68, 120) 0           add_4[0][0]
block_3a_conv_1 (Conv2D)        (None, 256, 34, 60)  295168      block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 34, 60)  1024        block_3a_conv_1[0][0]
block_3a_relu_1 (Activation)    (None, 256, 34, 60)  0           block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D)        (None, 256, 34, 60)  590080      block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 34, 60)  33024       block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 34, 60)  1024        block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 34, 60)  1024        block_3a_conv_shortcut[0][0]
add_5 (Add)                     (None, 256, 34, 60)  0           block_3a_bn_2[0][0]
        block_3a_bn_shortcut[0][0]
block_3a_relu (Activation)      (None, 256, 34, 60)  0           add_5[0][0]
block_3b_conv_1 (Conv2D)        (None, 256, 34, 60)  590080      block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 34, 60)  1024        block_3b_conv_1[0][0]
block_3b_relu_1 (Activation)    (None, 256, 34, 60)  0           block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D)        (None, 256, 34, 60)  590080      block_3b_relu_1[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 34, 60)  1024        block_3b_conv_2[0][0]
add_6 (Add)                     (None, 256, 34, 60)  0           block_3b_bn_2[0][0]
        block_3a_relu[0][0]
block_3b_relu (Activation)      (None, 256, 34, 60)  0           add_6[0][0]
block_4a_conv_1 (Conv2D)        (None, 512, 34, 60)  1180160     block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 34, 60)  2048        block_4a_conv_1[0][0]
block_4a_relu_1 (Activation)    (None, 512, 34, 60)  0           block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D)        (None, 512, 34, 60)  2359808     block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 34, 60)  131584      block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 34, 60)  2048        block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 34, 60)  2048        block_4a_conv_shortcut[0][0]
add_7 (Add)                     (None, 512, 34, 60)  0           block_4a_bn_2[0][0]
        block_4a_bn_shortcut[0][0]
block_4a_relu (Activation)      (None, 512, 34, 60)  0           add_7[0][0]
block_4b_conv_1 (Conv2D)        (None, 512, 34, 60)  2359808     block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 34, 60)  2048        block_4b_conv_1[0][0]
block_4b_relu_1 (Activation)    (None, 512, 34, 60)  0           block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D)        (None, 512, 34, 60)  2359808     block_4b_relu_1[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 34, 60)  2048        block_4b_conv_2[0][0]
add_8 (Add)                     (None, 512, 34, 60)  0           block_4b_bn_2[0][0]
        block_4a_relu[0][0]
block_4b_relu (Activation)      (None, 512, 34, 60)  0           add_8[0][0]
output_bbox (Conv2D)            (None, 28, 34, 60)   14364       block_4b_relu[0][0]
output_cov (Conv2D)             (None, 7, 34, 60)    3591        block_4b_relu[0][0]
Total params: 11,213,283
Trainable params: 11,194,083
Non-trainable params: 19,200
2022-02-18 08:22:16,675 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-02-18 08:22:16,675 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-02-18 08:22:16,675 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-02-18 08:22:16,675 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 12, io threads: 24, compute threads: 12, buffered batches: 4
2022-02-18 08:22:16,676 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 161273, number of sources: 1, batch size per gpu: 2, steps: 80637
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2022-02-18 08:22:16,718 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
ERROR:tensorflow:==================================
Object was never used (type <class 'tensorflow.python.framework.ops.Tensor'>):
<tf.Tensor 'IsVariableInitialized_308:0' shape=() dtype=bool>
If you want to mark it as used call its "mark_used()" method.
It was originally created here:
  File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/utilities.py", line 143, in get_singular_monitored_session  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1104, in __init__
    stop_grace_period_secs=stop_grace_period_secs)  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 727, in __init__
    self._sess = self._coordinated_creator.create_session()  File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/hooks/hooks.py", line 285, in begin  File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/tf_should_use.py", line 198, in wrapped
    return _add_should_use_warning(fn(*args, **kwargs))
2022-02-18 08:22:23,814 [ERROR] tensorflow: ==================================
2022-02-18 10:22:24,729 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
I also saw that I have two tao-toolkit images, but locally I have only one.
This is nvcr.io/nvidia/tao/tao-toolkit-tf/v3.21.11-tf1.15.4-py3
I also saw that when I am using !tao detectnet_v2 train <args> nvcr.io/nvidia/tao/tao-toolkit-pyt:v3.21.11-py3 is called.
I think nvcr.io/nvidia/tao/tao-toolkit-tf/v3.21.11-tf1.15.4-py3 must be called
If you run detectnet_v2 or faster_rcnn network, nvcr.io/nvidia/tao/tao-toolkit-tf/v3.21.11-tf1.15.4-py3 is needed.
If you run other object networks, nvcr.io/nvidia/tao/tao-toolkit-tf/v3.21.11-tf1.15.5-py3 is needed.
You can download it from TAO Toolkit for Computer Vision | NVIDIA NGC
More info is as below.
$ tao info --verbose
dockers:
                v3.21.11-tf1.15.5-py3:
                        docker_registry: nvcr.io
                        tasks:
                                1. augment
                                2. bpnet
                                3. classification
                                4. dssd
                                5. emotionnet
                                6. efficientdet
                                7. fpenet
                                8. gazenet
                                9. gesturenet
                                10. heartratenet
                                11. lprnet
                                12. mask_rcnn
                                13. multitask_classification
                                14. retinanet
                                15. ssd
                                16. unet
                                17. yolo_v3
                                18. yolo_v4
                                19. yolo_v4_tiny
                                20. converter
                v3.21.11-tf1.15.4-py3:
                        tasks:
                                1. detectnet_v2
                                2. faster_rcnn
                v3.21.11-py3:
                        tasks:
                                1. speech_to_text
                                2. speech_to_text_citrinet
                                3. text_classification
                                4. question_answering
                                5. token_classification
                                6. intent_slot_classification
                                7. punctuation_and_capitalization
                                8. spectro_gen
                                9. vocoder
                                10. action_recognition
        nvidia/tao/tao-toolkit-lm:
                v3.21.08-py3:
                        tasks:
                                1. n_gram
format_version: 2.0
toolkit_version: 3.21.11
published_date: 11/08/2021
I am using nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.4-py3 and I still getting this error
And I found more information about the exception:
tensorflow.python.framework.errors_impl.InternalError: CUDA runtime implicit initialization on GPU:0 failed. Status: the provided PTX was compiled with an unsupported toolchain.
Can you share full log about the new error?
More, what’s the gpu you are using?
And what’s the output of nvidia-smi ?
