Object Detection using TAO DetectNet_v2. Run TAO training stopped
• Hardware (GeForce 3080Ti)
• Network Type (Detectnet_v2)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(detectnet_v2_train_resnet18_kitti.txt)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
When I use detectnet_v2.ipynb to train data, I have a errr, Please help me.
detectnet_v2_train_resnet18_kitti.txt (5.4 KB)
log.txt (52.3 KB)
Please double check.
And also monitor the “$nvidia-smi” to check the GPU memory consumption.
When th docker stop, th nvidi-smi is:
Please double check.?
Could you tell me whic file to check?
I mean you can run again to double confirm.
Before running again, please run below in terminal.
$ nvidia-smi --query-gpu=memory.used,memory.total --format=csv -i 0 -l 1
I test it many times, but still have this error, the ‘nvidia-smi --query-gpu=memory.used,memory.total --format=csv -i 0 -l 1’ result is:
When I run tao training, it shows this error.
You can ignore. It is not an error.
Can you share more info?
  • What is the $NUM_GPUS
  • Can you share the log when try to run again with a new folder " -r $USER_EXPERIMENT_DIR/new_folder " ?
$NUM_GPUS=1
log.txt (52.7 KB)
Please open a terminal to debug as below.
$ tao detectnet_v2 run /bin/bash
then
# detectnet_v2 train xxx
The log is:
log.txt (45.9 KB)
Please use a new folder and share the log. Thanks a lot.
 -r tao-experiments/detectnet_v2/experiment_dir_unpruned_new
OK, this is the log, thank you very much
log.txt (49.6 KB)
but there is a question, a few days later, this tao training is success, but when I want to try again today, it has this error.
OK, thanks for the info. May I know that if you ever know below change and workaround?
This had solved my error, thank you very much.
But when I meet this similar problem, where can I find this answer?
You can create a topic in this forum. Thanks.
