I am trying to train action recognition net inside TAO toolkit container by following the nvidia blog for ActionRecognitionNet.
I have started the container using the following command in my personal machine:
docker run --net=host -ti -v /var/run/docker.sock:/var/run/docker.sock --gpus=all -e DISPLAY=$DISPLAY nvcr.io/nvidia/tao/tao-toolkit-pyt:v3.21.11-py3
Inside this, I was able to successfully follow the jupyter notebook as mentioned in the blog up till the training part. When i run the following command
tao action_recognition train
-e /workspace/specs/train_rgb_3d_finetune.yaml
-r $RESULTS_DIR/rgb_3d_ptm
-k $KEY
model_config.rgb_pretrained_model_path=$RESULTS_DIR/pretrained/actionrecognitionnet_vtrainable_v1.0/resnet18_3d_rgb_hmdb5_32.tlt
model_config.rgb_pretrained_num_classes=5
I am getting error:
** File “/opt/conda/bin/tao”, line 8, in **
** sys.exit(main())**
** File “/opt/conda/lib/python3.8/site-packages/tlt/entrypoint/entrypoint.py”, line 113, in main**
** local_instance.launch_command(**
** File “/opt/conda/lib/python3.8/site-packages/tlt/components/instance_handler/local_instance.py”, line 296, in launch_command**
** docker_logged_in(required_registry=self.task_map[task].docker_registry)**
** File “/opt/conda/lib/python3.8/site-packages/tlt/components/instance_handler/utils.py”, line 129, in docker_logged_in**
** data = load_config_file(docker_config)**
** File “/opt/conda/lib/python3.8/site-packages/tlt/components/instance_handler/utils.py”, line 64, in load_config_file**
** assert os.path.exists(config_path), (**
AssertionError: Config path must be a valid unix path. No file found at: /root/.docker/config.json. Did you run docker login?
Note that I am able to do docker login nvcr.io in my system but cant do the same inside this container. Because when I try to do so I get the error as:
root@predator:/workspace/tlt/samples# docker login nvcr.io
bash: docker: command not found
• Hardware Platform (Jetson / GPU) 1050Ti
• DeepStream Version 6.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 470.42.01
• Issue Type( questions, new requirements, bugs) bug
