• Hardware 3090
• Network Type (Yolo_v4)
• TAO
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Hi I am trying to run tao in a docker container (it will build, train, deploy, from a script so assuming tao is installed etc on the PC is not an option so building a docker container I think is the best way). I have looked at this forum post:
but running:
sudo docker run --gpus all -it -v /workspace/tlt-experiments/:/workspace/tlt-experiments -p 8888:8888 nvcr.io/nvidia/tao/tao-toolkit-pyt:v3.21.11-py3 /bin/bash
followed by:
yolo_v4 train
leads to command not found - how can I install this so it works - as I understand if I do pip install nvidia-tao in the container that will run a container within another container which is not what I want?
Could you share the detailed steps?
Which docker did you trigger?
And then how did you trigger tao docker?
More, can you share the "$ nvidia-smi " result of your local PC?
