Error running tao container image
• Hardware (T4/V100/Xavier/Nano/etc)
T4
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
v3.22.05
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I am running the newest version of TAO on a T4 machine - everything was working fine until today when suddently i am getting the below error:
Simple command to reproduce: “docker run nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.5-py3
Error happens on my RTX3060 machine as well.
Trying to run a training session from the launcher with “tao classification …” causes the container to exit instantly.
Did something change?
br, Mathias
I can reproduce this issue. Checking ongoing.
Please try below workaround.
$ docker run --runtime=nvidia -it --rm --entrypoint “” nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.5-py3 /bin/bash
The 2nd workaround is for uses who want to use tao launcher instead of “docker run”.
Step:
  1. Add "entrypoint": "" to ~/.tao_mounts.json
    "DockerOptions":{
          "entrypoint": "" ,
          "shm_size": "16G",
  1. Modify lib/python3.6/site-packages/tao/components/docker_handler/docker_handler.py . This file should be available when you install nvidia-tao.
VALID_DOCKER_ARGS = [“user”, “ports”, “shm_size”, “ulimits”, “privileged”, “network”]
to
VALID_DOCKER_ARGS = [“user”, “ports”, “shm_size”, “ulimits”, “privileged”, “network”, “entrypoint”]
Thanks for the swift reply,
Workarounds are good,
/M
