Generate TFRecords for training dataset
!tao model bpnet dataset_convert
-m ‘train’
-o $DATA_DIR/train
-r $USER_EXPERIMENT_DIR/
–generate_masks
–dataset_spec $DATA_POSE_SPECS_DIR/coco_spec.json
When I was run this command on jupyter ,that error was occured.
2023-09-04 04:29:43,003 [TAO Toolkit] [INFO] root 160: Registry: [‘nvcr.io’]
2023-09-04 04:29:43,569 [TAO Toolkit] [INFO] nvidia_tao_cli.components.instance_handler.local_instance 361: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5
2023-09-04 04:29:43,649 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 275: Printing tty value True
Docker instantiation failed with error: 500 Server Error: Internal Server Error (“failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as ‘csv’
invoking the NVIDIA Container Runtime Hook directly (e.g. specifying the docker --gpus flag) is not supported. Please use the NVIDIA Container Runtime (e.g. specify the --runtime=nvidia flag) instead.: unknown”)
Please teach me how to fix this error
I dawnloaded notebooks from here
https://docs-nvidia-com.translate.goog/tao/tao-toolkit/text/tao_toolkit_quick_start_guide.html?_x_tr_sl=auto&_x_tr_tl=ja&_x_tr_hl=ja&_x_tr_pto=wapp#getting-started
• Hardware (Xavier)
• Network Type (bpnet)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
