Hello. I’ve generate a new API key to log in, but I found that the tao commands could not be used and return the 500 Server Error message as the picture below.
When I ran tao mulitask_classification train --help, I got the error message Docker pull failed. 500 Server Error: Internal Server Error (“Head “https://nvcr.io/v2/nvidia/tao/tao-toolkit-tf/manifests/v3.22.05-tf1.15.5-py3”: unauthorized: authentication required”)
How should I do to deal with that problem ?
Thank you for your help in advance.
Can you share the log of
$ tao info --help
How about
$ tao info --verbose
~/.tao_mounts.json wasn't found. Falling back to obtain mount points and docker configs from ~/.tlt_mounts.json.
Please note that this will be deprecated going forward.
Configuration of the TAO Toolkit Instance
dockers:
nvidia/tao/tao-toolkit-tf:
v3.22.05-tf1.15.5-py3:
docker_registry: nvcr.io
tasks:
1. augment
2. bpnet
3. classification
4. dssd
5. faster_rcnn
6. emotionnet
7. efficientdet
8. fpenet
9. gazenet
10. gesturenet
11. heartratenet
12. lprnet
13. mask_rcnn
14. multitask_classification
15. retinanet
16. ssd
17. unet
18. yolo_v3
19. yolo_v4
20. yolo_v4_tiny
21. converter
v3.22.05-tf1.15.4-py3:
tasks:
1. detectnet_v2
nvidia/tao/tao-toolkit-pyt:
v3.22.05-py3:
tasks:
1. speech_to_text
2. speech_to_text_citrinet
3. speech_to_text_conformer
4. action_recognition
5. pointpillars
6. pose_classification
7. spectro_gen
8. vocoder
v3.21.11-py3:
tasks:
1. text_classification
2. question_answering
3. token_classification
4. intent_slot_classification
5. punctuation_and_capitalization
nvidia/tao/tao-toolkit-lm:
v3.22.05-py3:
tasks:
1. n_gram
format_version: 2.0
toolkit_version: 3.22.05
published_date: 05/25/2022
More, please update the tao launcher.
From https://docs.nvidia.com/tao/tao-toolkit/text/tao_toolkit_quick_start_guide.html
Installing TAO Launcher
Once you have installed the required pre-requisites.
- Install the CLI launcher via the quick start script downloaded with the getting_started NGC package from here
bash setup/quickstart_launcher.sh --install
- You can also use this script to update the launcher to the latest version of TAO Toolkit by running the following command
bash setup/quickstart_launcher.sh --upgrade
Still cannot pull even I log in
Can you share the result of
$ cat /root/.docker/config.json
It seems like that the API key cannot be updated. The API key in /root/.docker/config.json is different than my generated key.
It is not the reason.
Can you docker pull under
