I’m attempting to work through the TAO toolkit example Jupyter notebook. I’ve followed the instructions for signing up for an NGC account and I tried to log into docker using the instructions provided:
docker login nvcr.io
Username: $oauthtoken
Password: <MY API KEY>
However, I get the following response:
Error response from daemon: Get "https://registry-1.docker.io/v2/": unauthorized: incorrect username or password
The thing is: I already have the TAO docker image pulled (nvcr.io/nvidia/tao/tao-toolkit-tf) however when I try to kick off a model training job using the tao CLI
tao classification train -e $SPECS_DIR/classification_spec.cfg -r $USER_EXPERIMENT_DIR/output \
-k $KEY --gpus 2 \
--init_epoch N
I get this:
AssertionError: Config path must be a valid unix path. No file found at: /home/<user>/.docker/config.json. Did you run docker login?
Get an NGC account and API key:
Go to NGC and click the TAO Toolkit container in the Catalog tab. This message is displayed: “Sign in to access the PULL feature of this repository”.
Enter your Email address and click Next, or click Create an Account.
Choose your organization when prompted for Organization/Team.
Click Sign In.
Log in to the NGC docker registry (nvcr.io) using the command docker login nvcr.io and enter the following credentials:
a. Username: "$oauthtoken"
b. Password: "YOUR_NGC_API_KEY"
Hi Morganh,
Thanks for your help. I followed the instructions exactly as indicated above and it doesn’t work. I’ve tried regenerating the API key a few times just to be sure.
It now is working, inexplicably. I had previously tried several times to reset the API Key, without success. I’m not sure what has changed now, but the issue seems to be resolved. Thanks for your support.
