Docker reference error
Getting error:
Docker : invalid reference format
While entering code:
sudo docker run --runtime ispnpp -it --rm --network host \ –volume ~/nvdli-data:/nvdli-nano/data \ --device /dev/video0 \ nvcr.io/nvidia/dli-nano-ai:v2.0.2-r32.7.1
Regarding course: Getting Started with AI on Jetson Nano
This kind of errors are commonly caused by the syntax used to run your docker image, i.e, the syntax you are using in the command itself. I would double check the name of the image you want to run with docker images or docker image ls or even check the syntax of the command you are putting in the shell console.
Jafet Chaves,
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
It should also be --runtime nvidia instead of that (I’m not sure what ispnpp is)
