Document runtime library requirements of TensorRT
Would it be possible to document the runtime library requirements of TensorRT? In other words, exactly what other libraries are needed by TensorRT at runtime? I can think of CuDNN, CuBLAS, NVRTC. Are there others? What versions are needed?
I cannot find this information via readelf -d libnvinfer.so | grep NEEDED, since it’s not exposed.
Motivation: some advanced build systems (e.g. Bazel) need to model the dependencies explicitly to make them available at runtime. In this case, it’s not possible to install these libraries under /usr/local/cuda nor is it possible to put them all in a folder and set the LD_LIBRARY_PATH to that folder.
Hi ,
We recommend you to check the supported features from the below link.
You can refer below link for all the supported operators list.
For unsupported operators, you need to create a custom plugin to support the operation
