Does TX2 support 4K60fps H.265 with YUV4:2:2 color space directly without change it to 4:2:0?
If not, what is the max. video resolution that TX2 can encode with YUV4:2:2 color space?
Regards,
Andy
Regards,
Andy
On TX2, we support YUV420 10-bit in H265 encoding. YUV422 is not supported.
Hi DaneLLL,
Thanks for the reply.
It is too bad that TX2/AGX Xavier doesn’t support YUV422 H265 encoding even with 256/512 core Pascal/Tensor GPU cores.
Based on Wikipedia, GP107 (640 Pascal) has NVENC engine and can support YUV422 H265 encoding.
However, I need a part with less power consumption than GP107.
Which device support YUV422 H265 encoding with the lowest power?
I understand you may not able to answer my question. If that is the case, can you provide a correct group for me to ask?
Regards,
Andy
Hi adong,
For dGPU product information, please check:
