Hi:
I see that document TX2 does not support YUV422 10 bit H.265 encoding, so I use other H.265 encoders to encode YUV422 10 bit. Now I want to decode with TX2.i used gstreamer.but it can not work.(I’ve tried that YUV420 10bit is playable.)
I would like to ask whether TX2 is not supported H.265 YUV422 10bit encode or need to do other settings?
Thank you !
the log nvgstplayer -i 216042210.hevc
nvidia@tegra-ubuntu:~/Documents$ nvgstplayer -i 216042210.hevc
Runtime Commands:
q quit the application
h print help
Up Key, ] goto next track
c restart current track
Down Key, [ goto previous track
spos query for position
sdur query for duration
s seek to position in seconds, eg “s5.120”
v seek to percent of the duration, eg “v54”
f seek by seconds, relative to current position eg “f23.901”
Left Key, < seek backwards by 10 seconds
Right Key, > seek forward by 10 seconds
p pause playback
r start/resume the playback
z stop the playback
i: enter a single URI
1 r
** Message: main:3972 iterating…
** Message: <goto_next_track:910> uriCount: 0, uriTotal: 1
** Message: <on_input:576> pausing
NvMMLiteOpen : Block : BlockType = 279
TVMR: NvMMLiteTVMRDecBlockOpen: 7647: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 279
TVMR: cbBeginSequence: 1179: BeginSequence 3840x2160, bVPR = 0
TVMR: LowCorner Frequency = 345000
TVMR: cbBeginSequence: 1529: DecodeBuffers = 7, pnvsi->eCodec = 10, codec = 9
TVMR: cbBeginSequence: 1600: Display Resolution : (3840x2160)
TVMR: cbBeginSequence: 1601: Display Aspect Ratio : (3840x2160)
TVMR: cbBeginSequence: 1669: ColorFormat : 6
TVMR: cbBeginSequence:1683 ColorSpace = NvColorSpace_YCbCr601
TVMR: cbBeginSequence: 1809: SurfaceLayout = 3
TVMR: cbBeginSequence: 1902: NumOfSurfaces = 14, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 16 LumaBitDepth = 10, ChromaBitDepth = 10, ChromaFormat = 6
TVMR: cbBeginSequence: 1904: BeginSequence ColorPrimaries = 2, TransferCharacteristics = 2, MatrixCoefficients = 2
Allocating new output: 3840x2160 (x 14), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3464: Send OMX_EventPortSettingsChanged : nFrameWidth = 3840, nFrameHeight = 2160
Error by /GstPipeline:player/GstDecodeBin:decodebin0/GstOMXH265Dec-omxh265dec:omxh265dec-omxh265dec0: Could not configure supporting library.
debug info:
/dvs/git/dirty/git-master_linux/external/gstreamer/gst-omx/omx/gstomxvideodec.c(2918): gst_omx_video_dec_loop (): /GstPipeline:player/GstDecodeBin:decodebin0/GstOMXH265Dec-omxh265dec:omxh265dec-omxh265dec0:
Unable to reconfigure output port
** Message: <cb_newpad:2076> creating the pipe for “video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-raw, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]”
Using winsys: x11
TVMR: TVMRFrameStatusReporting: 6132: Closing TVMR Frame Status Thread -------------
TVMR: TVMRVPRFloorSizeSettingThread: 5942: Closing TVMRVPRFloorSizeSettingThread -------------
TVMR: TVMRFrameDelivery: 5982: Closing TVMR Frame Delivery Thread -------------
TVMR: NvMMLiteTVMRDecBlockClose: 7815: Done
