Does MIPI DSI on Jetson Nano SoM support “800RGBX1280” ?
In Jetson Nano SoM datasheet, it mentions that MIPI DSI on Jetson Nano SoM supports “1920x960”. But it does not mention whether it support 960 RGB or 1920 RGB,
Hi fdtsaid,
You could also refer to Jetson TX1 document for Jetson Nano.
Do you mean 800x1280 RGB? I think it is supported.
Thank you.
I confirmed the meaning of “800rgb * 1280” from MIPI DSI display provider. It means horizontal has 800 pixels, each pixel is RGB 24bpp, vertical has 1280 lines.
I am not sure whether Jetson Nano support such kind of DSI display.
It should support.
