Does the 900-13448-0020-000 Jetson Nano Module effectively supports MIPI-DSI ?
When I look into the module datasheet, it explicitly mentions that is is supported.
When I look into the Jetson Nano page Jetson Nano | NVIDIA Developer it doesn’t explicitly mention that it supports MIPI-DSI.
And when I look into Arrow’s description it doesn’t mention it in the Display interface section https://www.arrow.com/en/products/900-13448-0020-000/nvidia
Can someone enlighten me about this please ?
Thanks in advance.
I think my question was not clear enough as the answer doesn’t feel right:
I’m not planning on using the devkit but the module (PN: 900-13448-0020-000).
The module’s Datasheet says that MIPI-DSI is supported
I don’t know why the answer is not “feel right” to you. The “devkit” itself does not have a DSI connector. Thus, that topic I posted is also using a module with his own custom board.
And their “module” is same as what you are talking about here.
Thanks for your feedback. I edited my first message because I realized the “devkit” has nothing to do with my question.
I should have asked “Which one of these three links provide the correct information about MIPI-DSI on the Jetson Nano ?”, then uploaded the images of my previous message.
The answer I was expecting was something like “the presentation page information is the one to follow” or “the datasheet’s information is up to date, thus trustworthy”.
With your insights I can only suppose that the Jetson Nano module supports DSI display. I’ll find it out myself.
