Does nvmultiurisrcbin or nvurisrcbin not work in jetson?
Is it the same as the environment below?
Environment Details
  • Device: Jetson Orin AGX 32GB
  • JetPack Version: 6.0+b106
  • DeepStream Version: 6.4
  • Operating System: Ubuntu-based (JetPack)
  • Input Source: RTSP Streams
And I’m using an AvermediaD315 board.
We are working on JetPack 7.1
I need to make sure that the code works in deepstream-6.4.
Because all my personal codes were configured based on deepstream-6.4.
Does the deepstream-6.4 sample code in the jetson environment not work?
Why do you think so? The DeepStream 6.4 SDK is verified on JetPack 6.0 DP before released. It can work.
Thank you.
I will judge that there is no problem.
I’ll have to check if there’s another way.
