I have a H.264 RTSP stream. The GOP of H.264 encoding is 10 - there is an I-frame in every 10 frames. Does nv4l2decoder support of parsing the stream and decoding I-frame only without having to decoding every frame?
If yes, does it mean nv4l2decoder can decode 10x number of streams at 1/10 frame rate?
For example, if nv4l2decoder can decode 10 streams @ 1080p, 30fps with all frame decoding, with I-frame decoding only, it can decode 100 streams @ 1080p, 3fps.
You may configure the property in nvv4l2decoder and give it a try:
skip-frames : Type of frames to skip during decoding
flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
Enum "SkipFrame" Default: 0, "decode_all"
(0): decode_all - Decode all frames
(1): decode_non_ref - Decode non-ref frames
(2): decode_key - decode key frames
We have sample config for 8 1080p30 sources on Jetson Nano:
deepstream_sdk_v4.0.2_jetson\samples\configs\deepstream-app\source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
Suggest you run this first.
@DaneLLL, thanks for help. Where can I find the sample code or example design with skip-frame for nvv4l2decoder?
You may go to
and run
$ deepstream-app -c source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
And modify interval=4 to different values for a try.
