in Jetpack 6.x, we can not generate ota package for orin nx super mode.
I see the new Jetpack 7.2 come out, and does this support super mode ota in Orin NX?
hello 854053437,
may I have confirmation, are you going to enable super mode via OTA?
you have to re-flash a target with the board configuration file, such as.. jetson-orin-nano-devkit-super or jetson-orin-nano-devkit-super-maxn to enable super mode.
No, our board is already flashed super mode and for our need we want to make ota package in spuer mode.
hello 854053437,
all right, may I know what’s your base version for running OTA update?
please also check JetPack SDK Downloads and Notes Archive | NVIDIA Developer to have r39.2 OTA tool applied.
let me share you some sample pipelines for r39.2 → r39.2 OTA payload creation.
for instance,
export BASE_BSP=/path/to/R39.2.0/Linux_for_Tegra
export TARGET_BSP=/path/to/R39.2.0/Linux_for_Tegra
cd ${TARGET_BSP}
sudo -E ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 -S 14GiB jetson-orin-nano-devkit-super R39-2
the base version is the same as target version, we just want to ota the super mode when we changed kernel
you may give it a try with the sample pipelines above for confirmation.
Hi, Jerry
I tried, but it never stop when generate ota package, after 30 minutes, it still in the process like
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra234-p3768-0000+p3767-0003-nv.dtb to rootfs... done.
Making system.img...
populating rootfs from /HDD/xinhao/orinnx/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
here is my cmd
sudo -E ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh --external-device nvme0n1 jetson-orin-nano-devkit R36-4
it seems will creat many ota package
But in xavier nx and agx xavier. the ota package get very soon, less than 10 min
Hi, Jerry
over one hour, I get the ota package. And I used it in our board which has flashed super mode, it gets below err
sudo ./nv_ota_start.sh /program/disk/ota_payload_package.tar.gz
Command: ./nv_ota_start.sh /program/disk/ota_payload_package.tar.gz
/usr/bin/efibootmgr
/usr/bin/efibootdump
/usr/sbin/nvme
Current rootfs is on /dev/nvme0n1
init_ota_log /ota_log
Creating log dir at /ota_log
Create log file at /ota_log/ota_19700101-080854.log
OTA_LOG_FILE=/ota_log/ota_19700101-080854.log
Extract /program/disk/ota_payload_package.tar.gz
update_nv_boot_control_in_rootfs /ota_work
3767-000-0000--1--jetson-orin-nano-devkit-super-
TNSPEC 3767-301-0000-G.1-1-1-jetson-orin-nano-devkit-super-
COMPATIBLE_SPEC 3767-000-0000--1--jetson-orin-nano-devkit-super-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Info: Write TegraPlatformCompatSpec with 3767-000-0000--1--jetson-orin-nano-devkit-super-.
Info: The esp is already mounted to /boot/efi.
check_prerequisites
decompress_ota_package ota_package.tar /ota_work
decompress_ota_package: start at Thu Jan 1 08:09:22 AM CST 1970
Sha1 checksum for /ota_work/ota_package.tar (0938d9757141857e246a28421f77cebdcfa79fec) matches
decompress_ota_package: end at Thu Jan 1 08:09:36 AM CST 1970
nv_ota_update_implement.sh
Command: nv_ota_update_implement.sh
check_target_board /ota_work TARGET_BOARD
The board name in OTA package(jetson-orin-nano-devkit) does not match current board(jetson-orin-nano-devkit-super)
Failed to run "check_target_board /ota_work TARGET_BOARD"
As of JetPack 6.x, Orin NX Super mode OTA packages are not supported by the standard OTA tools. Super mode changes the board configuration and power/clock tables, which the A/B OTA payload tooling did not handle in JP6.
JetPack 7.2 is primarily for Orin Nano Super / Thor platforms, and the release notes do not list Super mode OTA support for Orin NX either. The general guidance from NVIDIA remains: Super mode must be enabled at flash time with the correct board config (jetson-orin-nano-devkit-super or super-maxn).
Practical options:
1. Continue using full reflash for Super mode updates rather than A/B OTA. Use a recovery partition or USB/SD boot for field updates.
2. Generate a non-Super-mode OTA package for regular rootfs updates, and only reflash when the board config itself must change.
3. File an NVIDIA developer support request asking whether Super mode OTA is on the roadmap for Orin NX. The more customers request it, the more likely it gets prioritized.
Always verify by checking the JetPack 7.2 release notes and the L4T OTA documentation for the exact sentence on Orin NX Super mode before committing to a production update strategy.
hello 854053437,
please refer to below, it’ll create multi_specs OTA payloads.
for instance, $OUT/Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_board_specs.conf
you may further revise ota_board_specs.conf to shrink the targets.
according to the failure messages, does not match current board.
let me share you an example, here’s board spec from ota_board_specs.conf of each board spec OTA payloads.
jetson_orin_nano_devkit_super_maxn_ota_r36_spec=(
# External device
# orin-nx-super-maxn 16GB
'boardid=3767;fab=000;boardsku=0000;boardrev=;fuselevel_s=1;chiprev=;chipsku=00:00:00:D3;board=jetson-orin-nano-devkit-super-maxn;rootdev=nvme0n1p1;bup_type=bl;signed_img_dir='"${SIGNED_IMG_DIR}"''
# orin-nx-super-maxn 8GB
'boardid=3767;fab=000;boardsku=0001;boardrev=;fuselevel_s=1;chiprev=;chipsku=00:00:00:D4;board=jetson-orin-nano-devkit-super-maxn;rootdev=nvme0n1p1;bup_type=bl;signed_img_dir='"${SIGNED_IMG_DIR}"''
Hi, Jerry
I find the solution, and after apply the patch in ota tools, I can generate and ota my super mode board successfully!
How to generate OTA payload for custom baords:
And I find that in Jetpack 7.2, the ota tools has upgraded like this patch
Thanks for help!
