I am using Jetson R36.4.4. I checked the latest Jetson 7 BSP, and its nvidia-p2p.c in P2P is no different from that in R36.4.4.
Now I have found that in the demo for RDMA, GitHub - NVIDIA/jetson-rdma-picoevb: Minimal HW-based demo of GPUDirect RDMA on NVIDIA Jetson AGX Xavier running L4T · GitHub, jetson-rdma-picoevb/kernel-module/picoevb-rdma.c at master · NVIDIA/jetson-rdma-picoevb · GitHub, the following is registered:
static void pevb_p2p_free_callback(void *data)
struct pevb_cuda_surface *cusurf = data;
struct pevb_file *pevb_file = cusurf->pevb_file;
mutex_lock(&pevb_file->lock);
if (cusurf->handle >= 0) {
idr_remove(&pevb_file->cuda_surfaces, cusurf->handle);
cusurf->handle = -1;
mutex_unlock(&pevb_file->lock);
nvidia_p2p_free_page_table(cusurf->page_table);
#ifndef NV_BUILD_DGPU
kfree(cusurf->page_table);
#endif
kfree(cusurf);
#endif
Here, the following is freed:
struct pevb_cuda_surface {
struct pevb_file *pevb_file;
u64 va;
u64 offset;
u64 len;
int handle;
struct nvidia_p2p_page_table *page_table;
#endif
It is very clear that this frees struct nvidia_p2p_page_table *page_table;. However, in the MMU notifier system:
nvidia_p2p_mn_invl_range_start → nvidia_p2p_mn_invl_range_start_legacy:
static void nvidia_p2p_mn_invl_range_start_legacy(struct mmu_notifier *mn,
struct mm_struct *mm, unsigned long start, unsigned long end)
struct nvidia_p2p_page_table *page_table = container_of(mn,
struct nvidia_p2p_page_table,
mn);
u64 vaddr = 0;
u64 size = 0;
vaddr = page_table->vaddr;
size = page_table->size;
if (vaddr >= start && vaddr <= end) {
#if LINUX_VERSION_CODE >= KERNEL_VERSION(5, 4, 0)
mmu_notifier_put(&page_table->mn);
#else
mmu_notifier_unregister_no_release(&page_table->mn, page_table->mm);
#endif
page_table->free_callback(page_table->data);
If I register a memory region and, after it has been used, call unmap, there is a gap between mmu_notifier_put(&page_table->mn); and page_table->free_callback(page_table->data);. In other words, page_table->free_callback calls pevb_p2p_free_callback, which frees struct nvidia_p2p_page_table, but in nvidia_p2p_get_pages the following is registered:
(*page_table)->mn.ops = &nvidia_p2p_mmu_ops;
(*page_table)->mm = current->mm;
(*page_table)->free_callback = free_callback;
That is, when the SRCU is later triggered in a kworker, it is very likely to access already-freed memory. Of course, usually on a Jetson AGX Orin, a large amount of kmem-256 will not be allocated, so the historical data in this memory region will be preserved, and thus SRCU can synchronize normally. However, when memory is tight, such a bug will usually manifest as a UAF.
This is bug context:
[ 137.525796] [rdma] CMA allocation completed successfully
[ 137.552831] [rdma] Starting auto transfer mode: 0
[ 209.652256] Unable to handle kernel execute from non-executable memory at virtual address ffff0009a486f660
[ 209.652263] Mem abort info:
[ 209.652264] ESR = 0x000000008600000f
[ 209.652265] EC = 0x21: IABT (current EL), IL = 32 bits
[ 209.652266] SET = 0, FnV = 0
[ 209.652267] EA = 0, S1PTW = 0
[ 209.652268] FSC = 0x0f: level 3 permission fault
[ 209.652269] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000825ee8000
[ 209.652270] [ffff0009a486f660] pgd=180000102cd68003, p4d=180000102cd68003, pud=180000102600e003, pmd=1800001025ee9003, pte=0068000a2486ff07
[ 209.652278] Internal error: Oops: 000000008600000f [#1] PREEMPT_RT SMP
[ 209.652282] Modules linked in: md5 cifs cifs_arc4 cifs_md4 xt_conntrack xt_MASQUERADE bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype iptable_filter nf_tables libcrc32c nfnetlink lzo_rle lzo_compress zram zsmalloc motorcomm(O) ramoops reed_solomon tpm_ftpm_tee spidev tegra_cactmon_mc_all(O) tegra234_aon(O) st_m24(O) at24 mc_hwpm(O) host1x_fence(O) spi_tegra114 xdma(OE) nvidia_p2p(O) ina3221 crct10dif_ce governor_userspace nvidia(O) tegra_drm(O) nvgpu(O) nvethernet(O) tegra234_oc_event(O) nvhost_pva(O) tegra_wmark(O) nvhost_nvdla(O) nvpmodel_clk_cap(O) cec thermal_trip_event(O) tegra_dce(O) nvpps(O) nvhwpm(O) drm_kms_helper tegra_se(O) nvhost_capture(O) tsecriscv(O) host1x_nvhost(O) crypto_engine governor_pod_scaling(O) host1x(O) drm mc_utils(O) nvmap(O) nvsciipc(O) fuse ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc ucsi_ccg typec_ucsi typec nvme nvme_core
[ 209.652346] phy_tegra194_p2u pcie_tegra194
[ 209.652350] CPU: 1 PID: 230 Comm: kworker/1:3 Kdump: loaded Tainted: G OE 5.15.148-rt-tegra #35
[ 209.652353] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS r36.4.4-350c50a6-dirty 03/13/2026
[ 209.652355] Workqueue: rcu_gp srcu_invoke_callbacks
[ 209.652366] pstate: 40400009 (nZcv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 209.652368] pc : 0xffff0009a486f660
[ 209.652371] lr : srcu_invoke_callbacks+0x118/0x1b0
[ 209.652374] sp : ffff80000a72bd30
[ 209.652374] x29: ffff80000a72bd30 x28: 0000000000000000 x27: ffffa02048725300
[ 209.652377] x26: 0000000000000001 x25: ffffa0204ad809f0 x24: ffffa02048725300
[ 209.652378] x23: ffff000fa2bc8580 x22: ffff000fa2bc8540 x21: ffff000fa2bc85a0
[ 209.652380] x20: ffff000fa2bc8658 x19: ffff0009a486f658 x18: 0000000000000000
[ 209.652382] x17: ffff5fef586e5000 x16: ffff800008008000 x15: 0000000000000000
[ 209.652383] x14: 0000000000000000 x13: 0000000000000030 x12: 0101010101010101
[ 209.652385] x11: 7f7f7f7f7f7f7f7f x10: fefefefefefefeff x9 : ffffa0204869f784
[ 209.652387] x8 : 8080808080808080 x7 : 0000000000008080 x6 : ffff00008717ea74
[ 209.652388] x5 : 0000000fffffffe0 x4 : 0000000000000000 x3 : ffff5fef586e5000
[ 209.652390] x2 : ffff000088274d80 x1 : ffff0009a486f660 x0 : ffff0009a486f658
[ 209.652392] Call trace:
[ 209.652393] 0xffff0009a486f660
[ 209.652394] process_one_work+0x200/0x510
[ 209.652398] worker_thread+0x138/0x480
[ 209.652401] kthread+0x194/0x1b0
[ 209.652403] ret_from_fork+0x10/0x20
[ 209.652407] Code: 00001a92 00000000 00000000 00000000 (a486f660)
[ 209.652410] ---[ end trace 0000000000000002 ]---
[ 210.657296] printk: At kmsg_dump, Line 3370
[ 210.657299] printk: At kmsg_dump, Line 3388
[ 210.657300] printk: kmsg_dump: calling dumper pstore_dump
[ 210.660343] printk: kmsg_dump: dumper pstore_dump returned
[ 210.660346] Kernel panic - not syncing:
[ 210.660347] Oops: Fatal exception in interrupt
[ 211.665243] SMP: stopping secondary CPUs
[ 211.665302] Kernel Offset: 0x202040640000 from 0xffff800008000000
[ 211.665303] PHYS_OFFSET: 0x80000000
[ 211.665304] CPU features: 0x0,000005c1,a3332e5a
[ 211.665307] Memory Limit: none
[ 211.665309] printk: At kmsg_dump, Line 3370
[ 211.665310] printk: At kmsg_dump, Line 3388
[ 211.665311] printk: kmsg_dump: calling dumper pstore_dump
[ 211.668376] printk: kmsg_dump: dumper pstore_dump returned
[ 211.668524] ------------[ cut here ]------------
[ 211.668525] WARNING: CPU: 1 PID: 230 at drivers/gpio/gpiolib.c:3340 gpiochip_disable_irq+0x78/0x80
I am only adding my own limited driver; all the official driver code involved is the original code from R36.4.4.
