Doubt regarding supported cameras
Hi, I wanted to know if this list of Jetson Partner Supported Cameras mentioned over at this link are up to date?
We are planning to use this e-consystems 2MP OV2312 Global Shutter RGB-IR Camera Module with Jetson Orin AGX. On the vendor website it is mentioned in the highlights that this camera supports the NVIDIA Jetson series but I am unable to find this same camera on the Jetson Partner Supported Cameras webpage.
hello not_a_bot,
let me check with web page maintainer for confirmation.
you may also contact with sensor vendor for double check.
@JerryChang I meant Orin AGX and not Orin NX. Updated the post to reflect this change
Hi @JerryChang, I would like to know if there is any update on this?
hello not_a_bot,
I’m able to see this is listed within Jetson Partner Supported Cameras page.
please double check this linkage… https://developer.nvidia.com/embedded/jetson-partner-supported-cameras?t-1_image-sensor=OV2312&t-1_partner=e-con%20Systems
