• Hardware Platform (Jetson / GPU) - Jetson Nano
• DeepStream Version - 6.0.1
• JetPack Version (valid for Jetson only) - 4.6.3
• TensorRT Version - 8.4
• NVIDIA GPU Driver Version (valid for GPU only) - 10.2
• Issue Type( questions, new requirements, bugs) - this is regarding doubts for deepstream-test5-app for smart record event in storing local event ,i have done successfully compile deepstream -test5-app but when i set smart-record = 2 which is storing in local disk and this is ok fine but video which is storing continuously if i set total duration of the video and one more thing i am also wanted to know about where is it triggering smart record start and stop event.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://admin:Sieora123@192.168.1.108:554/cam/realmonitor?channel=1&subtype=0
num-sources=1
select-rtp-protocol=4
gpu-id=0
enable the record
nvbuf-memory-type=0
to store in local or cloud
smart-record = 2
smart-rec-container = 0
smart-rec-duration = 15
store only first five seconds
smart-rec-interval = 5
smart-rec-file-prefix=record.mp4
smart-rec-dir-path=record
smart-rec-cache=300
[sink0]
enable=1
type=2
#1=mp4 2=mkv
container=3
#1=h264 2=h265 3=mpeg4
only SW mpeg4 is supported right now.
codec=3
sync=1
bitrate=2000000
output-file=output.mp4
source-id=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
Set muxer output width and height
width=1920
height=1080
#enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
If set to TRUE, system timestamp will be attached as ntp timestamp
If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
attach-sys-ts-as-ntp=1
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
model-engine-file = Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
labelfile-path= Primary_Detector/labels.txt
config-file = Primary_Detector/config_infer_primary_nano.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
