After installing the network card driver and DPDK environment, start the dpdk-helloword program, and load the mlx5 program to report an error(安装完网卡驱动和DPDK环境后启动dpdk-helloword程序,加载mlx5程序报错)。
Q:
- What is DevX, can I turn off the function?(DevX是什么功能,我能关闭它吗?)
- How to turn off DevX and what is the impact of it(怎么关闭,关闭了有什么影响?)
- Is there any other solution?(是否有其他解决方案?)
INFO:
- NIC model: mcx653106A-ECAT (‘MT28908 Family [ConnectX-6] 101b’ if=ib0 drv=mlx5_core unused=)
- drivers: MLNX_OFED_LINUX-5.5-1.0.3.2-rhel8.4-x86_64
- dpdk version: dpdk-21.11
- ibstat:
CA ‘mlx5_3’
CA type: MT4123
Number of ports: 1
Firmware version: 20.32.1010
Hardware version: 0
Node GUID: 0x043f720300fea761
System image GUID: 0x043f720300fea760
Port 1:
State: Down
Physical state: Polling
Rate: 10
Base lid: 65535
LMC: 0
SM lid: 0
Capability mask: 0x2651e848
Port GUID: 0x043f720300fea761
Link layer: InfiniBand
- OS: CentOS Linux release 8.4.2105 4.18.0-305.3.1.el8.x86_64
- install ofed command: ./mlnxofedinstall --upstream-libs --dpdk --add-kernel-support
ERR INFO:
EAL: Probe PCI driver: mlx5_pci (15b3:101b) device: 0000:5e:00.0 (socket 0)
mlx5_common: probe device “0000:5e:00.0”.
mlx5_common: RTE_MEM is selected.
mlx5_common: Checking device “mlx5_3”…
mlx5_common: Checking device “mlx5_2”…
mlx5_common: Checking device “mlx5_1”…
mlx5_common: Checking device “mlx5_0”…
mlx5_common: Dev information matches for device “mlx5_0”.
mlx5_common: DevX is supported.
mlx5_common: initialized B-tree 0x1003e9dc1 with table 0x1003e7500
EAL: Mem event callback ‘MLX5_MEM_EVENT_CB:(nil)’ registered
mlx5_common: Netlink socket send buffer: 212992
mlx5_common: Netlink socket recv buffer: 212992
mlx5_net: Checking device “mlx5_3”
mlx5_net: Checking device “mlx5_2”
mlx5_net: Checking device “mlx5_1”
mlx5_net: Checking device “mlx5_0”
mlx5_net: PCI information matches for device “mlx5_0”
mlx5_net: No E-Switch support detected.
mlx5_net: naming Ethernet device “0000:5e:00.0”
mlx5_common: Failed to create TIS using DevX
mlx5_net: Failed to TIS 0 for bonding device mlx5_0.
mlx5_net: TIS allocation failure
mlx5_net: probe of PCI device 0000:5e:00.0 aborted after encountering an error: Cannot allocate memory
mlx5_common: Failed to load driver mlx5_eth
EAL: Mem event callback ‘MLX5_MEM_EVENT_CB:(nil)’ unregistered
mlx5_common: freeing B-tree 0x1003e9dc1 with table 0x1003e7500
EAL: Requested device 0000:5e:00.0 cannot be used
EAL: PCI device 0000:5e:00.1 on NUMA socket 0
EAL: probe driver: 15b3:101b mlx5_pci
EAL: Probe PCI driver: mlx5_pci (15b3:101b) device: 0000:5e:00.1 (socket 0)
mlx5_common: probe device “0000:5e:00.1”.
mlx5_common: Dev information matches for device “mlx5_1”.
mlx5_net: PCI information matches for device “mlx5_1”
mlx5_net: naming Ethernet device “0000:5e:00.1”
mlx5_net: Failed to TIS 0 for bonding device mlx5_1.
mlx5_net: probe of PCI device 0000:5e:00.1 aborted after encountering an error: Cannot allocate memory
EAL: Requested device 0000:5e:00.1 cannot be used
EAL: PCI device 0000:af:00.0 on NUMA socket 1
EAL: Probe PCI driver: mlx5_pci (15b3:101b) device: 0000:af:00.0 (socket 1)
mlx5_common: probe device “0000:af:00.0”.
