What’s the problem
I create a VM and attach a VF(ConnectX-5 SRIOV) to it using virt-manager (Reference)
VF should be configured successfully, as I can ping other IPs with it.
I compiled DPDK successfully following this Guide
~/dpdk-23.11$ cat VERSION
23.11.0
Then I compiled DPDK-Pktgen following this Guide
I tried to run pktgen:
$ sudo ./pktgen -l 0,1 -n 4 -a 07:00.0 -- -P -m "[1].0" -T
*** Copyright(c) <2010-2023>, Intel Corporation. All rights reserved.
*** Pktgen created by: Keith Wiles -- >>> Powered by DPDK <<<
EAL: Detected CPU lcores: 16
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
EAL: VFIO support initialized
TELEMETRY: No legacy callbacks, legacy socket not created
!PANIC!: *** Did not find any ports to use ***
EAL: PANIC in pktgen_config_ports():
0: /usr/local/lib/x86_64-linux-gnu/librte_eal.so.24 (rte_dump_stack+0x42) [7fbd3eb7d062]
1: /usr/local/lib/x86_64-linux-gnu/librte_eal.so.24 (__rte_panic+0xd4) [7fbd3eb552a0]
2: ./pktgen (55a87c076000+0x36175) [55a87c0ac175]
3: ./pktgen (55a87c076000+0xb587) [55a87c081587]
4: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0xf3) [7fbd3e776083]
5: ./pktgen (55a87c076000+0xbb7e) [55a87c081b7e]
Aborted
Info of my system
$ ./dpdk-23.11/usertools/dpdk-devbind.py -s
Network devices using kernel driver
0000:01:00.0 'Virtio network device 1041' if=enp1s0 drv=virtio-pci unused=vfio-pci *Active*
0000:07:00.0 'MT416842 BlueField multicore SoC family VF a2d3' if=enp7s0np0 drv=mlx5_core unused=vfio-pci
No 'Baseband' devices detected
No 'Crypto' devices detected
No 'DMA' devices detected
No 'Eventdev' devices detected
No 'Mempool' devices detected
No 'Compress' devices detected
Misc (rawdev) devices using kernel driver
0000:03:00.0 'Virtio block device 1042' drv=virtio-pci unused=vfio-pci
0000:04:00.0 'Virtio block device 1042' drv=virtio-pci unused=vfio-pci
No 'Regex' devices detected
No 'ML' devices detected
$ grep -i huge /proc/meminfo
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
FileHugePages: 0 kB
HugePages_Total: 1024
HugePages_Free: 1023
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 2097152 kB
$ uname -r
5.4.0-174-generic
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.6 LTS
Release: 20.04
Codename: focal
What I tried
Change driver
Reference: This Github Issue
$ sudo ./dpdk-23.11/usertools/dpdk-devbind.py -b vfio-pci 07:00.0
Error: bind failed for 0000:07:00.0 - Cannot bind to driver vfio-pci: [Errno 19] No such device
Error: unbind failed for 0000:07:00.0 - Cannot open /sys/bus/pci/drivers//unbind: [Errno 13] Permission denied: '/sys/bus/pci/drivers//unbind'
$ sudo ./dpdk-23.11/usertools/dpdk-devbind.py -b vfio-pci 0000:07:00.0
Error: No such device - I don’t know why.
Add parameter to pktgen
Reference: Stack Overflow
$ sudo ./pktgen -l 0,1 -n 4 -a 07:00.0 -d librte_net_mlx5.so -- -P -m "[1].0" -T
EAL: Probe PCI driver: mlx5_pci (15b3:a2d3) device: 0000:07:00.0 (socket -1)
====== Pktgen got a Segment Fault
Obtained 12 stack frames.
./pktgen(+0x29535) [0x558259321535]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f9d49dc1420]
/usr/local/lib/x86_64-linux-gnu/librte_net_mlx5.so(+0x1ca8c) [0x7f9d494dea8c]
/usr/local/lib/x86_64-linux-gnu/librte_net_mlx5.so(+0x1e2e3) [0x7f9d494e02e3]
/usr/local/lib/x86_64-linux-gnu/librte_net_mlx5.so(+0x15e0b0) [0x7f9d496200b0]
/usr/local/lib/x86_64-linux-gnu/librte_common_mlx5.so.24(+0xa7cc) [0x7f9d4949b7cc]
/usr/local/lib/x86_64-linux-gnu/librte_bus_pci.so.24(+0x4500) [0x7f9d49b7f500]
/usr/local/lib/x86_64-linux-gnu/librte_eal.so.24(rte_bus_probe+0x33) [0x7f9d49fc5313]
/usr/local/lib/x86_64-linux-gnu/librte_eal.so.24(+0x15654) [0x7f9d49fc1654]
./pktgen(+0xaf38) [0x558259302f38]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f9d49bdd083]
./pktgen(+0xbb7e) [0x558259303b7e]
Got a Segment Fault
Set CONFIG_RTE_LIBRTE_MLX5_PMD=y
Reference: Nvidia Forum
~/dpdk-23.11$ cat config/common_base
I added config/common_base in DPDK folder and compiled DPDK.
I don’t know whether this work or not.
Reinstall MLNX_OFED driver
I download MLNX_OFED_LINUX-24.01-0.3.3.1-ubuntu20.04-x86_64 from Nvidia website and install:
sudo ./mlnxofedinstall --upstream-libs --dpdk --force
But it didn’t solve my problem.
