Hi all,
I have a VM running on top of VMWare ESXi which gets a Mellanox VF exposed.
This is the output of dpdk-devbind -s inside the VM, after installing the OFED v5.4:
[root@localhost MLNX_OFED_LINUX-5.4-1.0.3.0-rhel7.9-x86_64]# dpdk-devbind -s
Network devices using DPDK-compatible driver
0000:04:00.0 'VMXNET3 Ethernet Controller 07b0' drv=igb_uio unused=vmxnet3,vfio-pci,uio_pci_generic
0000:13:00.0 'Ethernet Virtual Function 700 Series 154c' drv=igb_uio unused=iavf,vfio-pci,uio_pci_generic
Network devices using kernel driver
0000:0b:00.0 'VMXNET3 Ethernet Controller 07b0' if=ens192 drv=vmxnet3 unused=igb_uio,vfio-pci,uio_pci_generic *Active*
0000:1b:00.0 'MT28800 Family [ConnectX-5 Ex Virtual Function] 101a' if=ens256 drv=mlx5_core unused=igb_uio,vfio-pci,uio_pci_generic
However when I try to start my DPDK application on it I get:
DPDK: EAL argv param is [hmcapture --syslog=local0 --lcores=0@0,1@1,2@2,3@3,4@1 --pci-whitelist=0000:04:00.0 --pci-whitelist=0000:13:00.0 --pci-whitelist=0000:1b:00.0]
EAL: Detected 12 lcore(s)
EAL: Detected 2 NUMA nodes
EAL: Detected static linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
EAL: Probing VFIO support...
EAL: VFIO support initialized
EAL: PCI device 0000:04:00.0 on NUMA socket -1
EAL: Device 0000:04:00.0 is not NUMA-aware, defaulting socket to 0
EAL: probe driver: 15ad:7b0 net_vmxnet3
EAL: PCI device 0000:13:00.0 on NUMA socket -1
EAL: Device 0000:13:00.0 is not NUMA-aware, defaulting socket to 0
EAL: probe driver: 8086:154c net_i40e_vf
EAL: PCI device 0000:1b:00.0 on NUMA socket -1
EAL: Device 0000:1b:00.0 is not NUMA-aware, defaulting socket to 0
EAL: probe driver: 15b3:101a net_mlx5
net_mlx5: unable to recognize master/representors on the multiple IB devices
EAL: Requested device 0000:1b:00.0 cannot be used
I’m trying to understand this “net_mlx5: unable to recognize master/representors on the multiple IB devices” but I cannot fix it… any suggestion?
thanks a lot for any hint
