EAL: Detected 2 lcore(s)
EAL: Probing VFIO support…
EAL: PCI device 0000:06:00.0 on NUMA socket -1
EAL: probe driver: 15b3:1015 net_mlx5
PMD: mlx5.c:428: mlx5_pci_probe(): cannot access device, is mlx5_ib loaded? [ Yes it is loaded ]
EAL: PCI device 0000:06:00.1 on NUMA socket -1
EAL: No probed ethernet devices
PANIC in main():
Empty set of forwarding logical cores - check the core mask supplied in the command parameters
Thank you for mentioning this. I had no idea and struggled with this for a long time. I forgot one time to bind the Mellanox card to the UIO driver, and suddenly it worked! I wish that had been in the documentation somewhere.
yskoh
January 11, 2017, 8:21am
3
Hi Kaijun,
Did you bind the devices to UIO/VFIO? If so, you should bind it back to kernel driver. Mellanox PMD doesn’t use UIO/VFIO but its control path goes through regular kernel driver unlike Intel NICs.
Thanks,
Yongseok
Thanks all yes that worked.
— Original Message —
yskoh
January 12, 2017, 6:24pm
5
Thank you for the suggestion. We will put more effort to improve documentation. Meanwhile, please refer to the following ones.
DPDK.org - DPDK doc DPDK
MLX4 poll mode driver 35. MLX4 poll mode driver library — Data Plane Development Kit 22.07.0 documentation
MLX5 poll mode driver 36. MLX5 Ethernet Poll Mode Driver — Data Plane Development Kit 22.07.0 documentation
Mellanox.com http://www.mellanox.com/page/products_dyn?product_family=209&mtag=pmd_for_dpdk - LTS(Long-Term Support) version is released here. We will move to MLNX_DPDK_16.11_1.0 this month.
Quick Start Guide http://www.mellanox.com/related-docs/prod_software/MLNX_DPDK_Quick_Start_Guide_v2.2_4.2.pdf is still applicable to 16.11 and coming 17.02.
Thanks,
Yongseok
