Hello Mellanox community,
I have an debian-server with an ConnectX-4 card (MCX415A-CCAT, firmware version 12.12.1100, there is also an ConnectX-3 card and 2x10G Intel card). Im using DPDK 19.11 and libibverbs 24.0-2~bpo10+1 and no OEFD.
I try to start a custom written DPDK-app and get the following log output:
sudo build/pixelflut_v6_client
EAL: Detected 40 lcore(s)
EAL: Detected 2 NUMA nodes
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode ‘PA’
EAL: No available hugepages reported in hugepages-1048576kB
EAL: Probing VFIO support…
EAL: VFIO support initialized
EAL: PCI device 0000:01:00.0 on NUMA socket 0
EAL: probe driver: 8086:10fb net_ixgbe
EAL: PCI device 0000:01:00.1 on NUMA socket 0
EAL: PCI device 0000:04:00.0 on NUMA socket 0
EAL: probe driver: 15b3:1013 net_mlx5
net_mlx5: port 2 verbs maximum priority: 0 expected 8/16 <<< THIS IS THE ERROR
net_mlx5: probe of PCI device 0000:04:00.0 aborted after encountering an error: Operation not supported <<< THIS IS THE ERROR
EAL: Requested device 0000:04:00.0 cannot be used
EAL: PCI device 0000:07:00.0 on NUMA socket 0
EAL: probe driver: 8086:1521 net_e1000_igb
EAL: PCI device 0000:07:00.1 on NUMA socket 0
EAL: PCI device 0000:42:00.0 on NUMA socket 1
EAL: probe driver: 15b3:1003 net_mlx4
Skipping disabled port 0
Skipping disabled port 1
Skipping disabled port 2
Skipping disabled port 3
EAL: Error - exiting with code: 1
Cause: All available ports are disabled. Please set portmask. <<< This message is expected
I would appreciate any help! Thanks a lot!
Here are some Information about my system:
$RTE_SDK/usertools/dpdk-devbind.py --status
Network devices using DPDK-compatible driver
0000:01:00.0 ‘82599ES 10-Gigabit SFI/SFP+ Network Connection 10fb’ drv=uio_pci_generic unused=ixgbe,vfio-pci
0000:01:00.1 ‘82599ES 10-Gigabit SFI/SFP+ Network Connection 10fb’ drv=uio_pci_generic unused=ixgbe,vfio-pci
Network devices using kernel driver
0000:04:00.0 ‘MT27700 Family [ConnectX-4] 1013’ if=enp4s0 drv=mlx5_core unused=vfio-pci,uio_pci_generic
0000:07:00.0 ‘I350 Gigabit Network Connection 1521’ if=eno3 drv=igb unused=vfio-pci,uio_pci_generic Active
0000:07:00.1 ‘I350 Gigabit Network Connection 1521’ if=eno4 drv=igb unused=vfio-pci,uio_pci_generic
0000:42:00.0 ‘MT27500 Family [ConnectX-3] 1003’ if=enp66s0d1,enp66s0 drv=mlx4_core unused=vfio-pci,uio_pci_generic
./ibv_devinfo
hca_id: mlx5_0
transport: InfiniBand (0)
fw_ver: 12.12.1100
node_guid: 7cfe:9003:0031:0dd2
sys_image_guid: 7cfe:9003:0031:0dd2
vendor_id: 0x02c9
vendor_part_id: 4115
hw_ver: 0x0
board_id: MT_2140110033
phys_port_cnt: 1
port: 1
state: PORT_DOWN (1)
max_mtu: 4096 (5)
active_mtu: 1024 (3)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
link_layer: Ethernet
apt search libibverbs
Sorting… Done
Full Text Search… Done
ibverbs-providers/buster-backports,now 24.0-2~bpo10+1 amd64 [installed,automatic]
ibverbs-utils/buster-backports,now 24.0-2~bpo10+1 amd64 [installed]
libibverbs-dev/buster-backports,now 24.0-2~bpo10+1 amd64 [installed]
libibverbs1/buster-backports,now 24.0-2~bpo10+1 amd64 [installed,automatic]
librdmacm-dev/stable 22.1-1 amd64
librdmacm1/buster-backports,now 24.0-2~bpo10+1 amd64 [installed]
rdmacm-utils/buster-backports,now 24.0-2~bpo10+1 amd64 [installed]
