8.827966] Compat-mlnx-ofed backport release: 5f67178
[ 8.827967] Backport based on mlnx_ofed/mlnx-ofa_kernel-4.0.git 5f67178
[ 8.827967] compat.git: mlnx_ofed/mlnx-ofa_kernel-4.0.git
[ 8.859145] VFIO - User Level meta-driver version: 0.3
[ 8.866907] mlx5_core 0000:67:00.0: firmware version: 16.27.2008
[ 8.866939] mlx5_core 0000:67:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8 GT/s x16 link at 0000:64:00.0 (capable of 252.048 Gb/s with 16 GT/s x16 link)
[ 9.110752] mlx5_core 0000:67:00.0: Rate limit: 127 rates are supported, range: 0Mbps to 97656Mbps
[ 9.110887] mlx5_core 0000:67:00.0: E-Switch: Total vports 2, per vport: max uc(1024) max mc(16384)
[ 9.113009] port_module: 16 callbacks suppressed
[ 9.113013] mlx5_core 0000:67:00.0: Port module event: module 0, Cable plugged
[ 9.113389] mlx5_core 0000:67:00.0: mlx5_pcie_event:303:(pid 127): PCIe slot advertised sufficient power (27W).
[ 9.117849] mlx5_core 0000:67:00.0: mlx5_fw_tracer_start:810:(pid 176): FWTracer: Ownership granted and active
[ 9.122969] mlx5_core 0000:67:00.1: firmware version: 16.27.2008
[ 9.123009] mlx5_core 0000:67:00.1: 126.016 Gb/s available PCIe bandwidth, limited by 8 GT/s x16 link at 0000:64:00.0 (capable of 252.048 Gb/s with 16 GT/s x16 link)
[ 9.373672] mlx5_core 0000:67:00.1: Rate limit: 127 rates are supported, range: 0Mbps to 97656Mbps
[ 9.373869] mlx5_core 0000:67:00.1: E-Switch: Total vports 2, per vport: max uc(1024) max mc(16384)
[ 9.376332] mlx5_core 0000:67:00.1: Port module event: module 1, Cable plugged
[ 9.376587] mlx5_core 0000:67:00.1: mlx5_pcie_event:303:(pid 296): PCIe slot advertised sufficient power (27W).
[ 9.386598] mlx5_core 0000:67:00.0: MLX5E: StrdRq(1) RqSz(8) StrdSz(2048) RxCqeCmprss(0)
[ 9.617153] mlx5_core 0000:67:00.1: MLX5E: StrdRq(1) RqSz(8) StrdSz(2048) RxCqeCmprss(0)
[ 9.617361] mlx5_core 0000:67:00.0 enp103s0f0: renamed from eth0
[ 9.657377] IPv6: ADDRCONF(NETDEV_UP): enp103s0f0: link is not ready
[ 9.993216] mlx5_core 0000:67:00.0 enp103s0f0: Link down
[ 9.994309] IPv6: ADDRCONF(NETDEV_UP): enp103s0f0: link is not ready
[ 10.082331] mlx5_ib: Mellanox Connect-IB Infiniband driver v5.0-2.1.8
[ 10.142307] mlx5_core 0000:67:00.1 enp103s0f1: renamed from eth0
[ 10.177593] IPv6: ADDRCONF(NETDEV_UP): enp103s0f1: link is not ready
[ 10.408386] mlx5_core 0000:67:00.1 enp103s0f1: Link down
[ 10.414962] IPv6: ADDRCONF(NETDEV_UP): enp103s0f1: link is not ready
user@rat:~/dpdk/dpdk-stable-18.11.8/usertools$ ./dpdk-devbind.py -s
Network devices using kernel driver
0000:00:1f.6 ‘Ethernet Connection (2) I219-LM 15b7’ if=eno1 drv=e1000e unused=
0000:04:00.0 ‘I210 Gigabit Network Connection 1533’ if=enp4s0 drv=igb unused= Active
0000:67:00.0 ‘MT28800 Family [ConnectX-5 Ex] 1019’ if=enp103s0f0 drv=mlx5_core unused=
0000:67:00.1 ‘MT28800 Family [ConnectX-5 Ex] 1019’ if=enp103s0f1 drv=mlx5_core unused=
root@rat:/home/user/dpdk/pktgen-dpdk-pktgen-3.6.1/app/x86_64-native-linuxapp-gcc# ./pktgen -l 0-4 -n 3 – -P -m “[1:3].0, [2:4].1”
net_mlx5: mlx5.c:1740: mlx5_glue_init(): cannot load glue library: librte_pmd_mlx5_glue.so.18.11.0: cannot open shared object file: No such file or directory
net_mlx5: mlx5.c:1758: mlx5_glue_init(): cannot initialize PMD due to missing run-time dependency on rdma-core libraries (libibverbs, libmlx5)
Copyright (c) <2010-2019>, Intel Corporation. All rights reserved. Powered by DPDK
EAL: Detected 16 lcore(s)
EAL: Detected 1 NUMA nodes
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: No free hugepages reported in hugepages-2048kB
EAL: Probing VFIO support…
EAL: VFIO support initialized
EAL: PCI device 0000:00:1f.6 on NUMA socket 0
EAL: probe driver: 8086:15b7 net_e1000_em
EAL: PCI device 0000:04:00.0 on NUMA socket 0
EAL: probe driver: 8086:1533 net_e1000_igb
Lua 5.3.1 Copyright (C) 1994-2015 Lua.org, PUC-Rio
*** Copyright (c) <2010-2019>, Intel Corporation. All rights reserved.
*** Pktgen created by: Keith Wiles – >>> Powered by DPDK <<<
!PANIC!: *** Did not find any ports to use ***
PANIC in pktgen_config_ports():
*** Did not find any ports to use ***6: [./pktgen(_start+0x29) [0x480629]]
5: [/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f17db67b830]]
4: [./pktgen(main+0x58a) [0x475e2a]]
3: [./pktgen(pktgen_config_ports+0x1332) [0x4a5b72]]
2: [./pktgen(__rte_panic+0xc3) [0x466ea6]]
1: [./pktgen(rte_dump_stack+0x2b) [0x5963bb]]
Aborted (core dumped)
