ConnectX4-LX - Passthrough issues
Hi all!
Since some days I’m trying to passthrough my Mellanox 4 LX to a VM (Proxmox Hypervisor) without success.
mlx5_core0: WARN: wait_fw_init:733:(pid 0): Waiting for FW initialization, timeout abort in 100 s
and after 100s
mlx5_core0: ERR: Firmware over 120000 MS in pre-initializing state, aborting
mlx5_core0: ERR: init_one:1644:(pid 0): mlx5_load_one failed -16
device_attach: mlx5_core0 attach returned 16
Here some info about my config and card:
I did all normal bios and base proxmox configs to turn on sriov/passthru support. SR-IOV, VT-d, iommu and ROM Bar explicited enabled in Motherboard BIOS running the last version. intel_iommu=on iommu=pt also enabled in Kernel Host.
~# dmesg | grep mlx5
[ 1.091581] mlx5_core 0000:01:00.0: firmware version: 14.32.1010
[ 1.091611] mlx5_core 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x8 link)
[ 1.392555] mlx5_core 0000:01:00.0: E-Switch: Total vports 10, per vport: max uc(128) max mc(2048)
[ 1.397452] mlx5_core 0000:01:00.0: Port module event: module 0, Cable plugged
[ 1.648688] mlx5_core 0000:01:00.0: MLX5E: StrdRq(0) RqSz(1024) StrdSz(256) RxCqeCmprss(0 basic)
[ 1.648710] mlx5_core 0000:01:00.0: is_dpll_supported:213:(pid 186): Missing SyncE capability
[ 1.652515] mlx5_core 0000:01:00.1: firmware version: 14.32.1010
[ 1.652559] mlx5_core 0000:01:00.1: 63.008 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x8 link)
[ 1.975024] mlx5_core 0000:01:00.1: E-Switch: Total vports 10, per vport: max uc(128) max mc(2048)
[ 1.981124] mlx5_core 0000:01:00.1: port_module:252:(pid 0): Port module event[error]: module 1, Cable error, Unknown error
[ 2.263045] mlx5_core 0000:01:00.1: MLX5E: StrdRq(0) RqSz(1024) StrdSz(256) RxCqeCmprss(0 basic)
[ 2.263058] mlx5_core 0000:01:00.1: is_dpll_supported:213:(pid 186): Missing SyncE capability
[ 2.292685] mlx5_core 0000:01:00.0 enp1s0f0np0: renamed from eth0
[ 2.302847] mlx5_core 0000:01:00.1 enp1s0f1np1: renamed from eth1
[ 5.320648] mlx5_core 0000:01:00.0 enp1s0f0np0: entered allmulticast mode
[ 6.641338] mlx5_core 0000:01:00.0 enp1s0f0np0: Link up
[ 6.666739] mlx5_core 0000:01:00.1 enp1s0f1np1: entered allmulticast mode
[ 7.897118] mlx5_core 0000:01:00.1 enp1s0f1np1: Link up
[ 12.326943] mlx5_core 0000:01:00.0 enp1s0f0np0: entered promiscuous mode
[ 12.342129] mlx5_core 0000:01:00.0: mlx5e_fs_set_rx_mode_work:842:(pid 257): S-tagged traffic will be dropped while C-tag vlan stripping is enabled
[ 12.768375] mlx5_core 0000:01:00.1 enp1s0f1np1: entered promiscuous mode
~# lspci -D | grep Mellanox
0000:01:00.0 Ethernet controller: Mellanox Technologies MT27710 Family [ConnectX-4 Lx]
0000:01:00.1 Ethernet controller: Mellanox Technologies MT27710 Family [ConnectX-4 Lx]
~# mst status
MST modules:
MST PCI module is not loaded
MST PCI configuration module loaded
MST devices:
/dev/mst/mt4117_pciconf0 - PCI configuration cycles access.
domain:bus:dev.fn=0000:01:00.0 addr.reg=88 data.reg=92 cr_bar.gw_offset=-1
Chip revision is: 00
~# mlxconfig -d /dev/mst/mt4117_pciconf0 q
Device #1:
Device type: ConnectX4LX
Description: ConnectX-4 Lx EN network interface card; 25GbE dual-port SFP28; PCIe3.0 x8; ROHS R6
Device: /dev/mst/mt4117_pciconf0
Configurations: Next Boot
MEMIC_BAR_SIZE 0
MEMIC_SIZE_LIMIT _256KB(1)
FLEX_PARSER_PROFILE_ENABLE 0
FLEX_IPV4_OVER_VXLAN_PORT 0
ROCE_NEXT_PROTOCOL 254
PF_NUM_OF_VF_VALID False(0)
NON_PREFETCHABLE_PF_BAR False(0)
VF_VPD_ENABLE False(0)
STRICT_VF_MSIX_NUM False(0)
VF_NODNIC_ENABLE False(0)
NUM_PF_MSIX_VALID True(1)
NUM_OF_VFS 8
NUM_OF_PF 2
SRIOV_EN True(1)
PF_LOG_BAR_SIZE 5
VF_LOG_BAR_SIZE 0
NUM_PF_MSIX 63
NUM_VF_MSIX 11
INT_LOG_MAX_PAYLOAD_SIZE AUTOMATIC(0)
PCIE_CREDIT_TOKEN_TIMEOUT 0
ACCURATE_TX_SCHEDULER False(0)
PARTIAL_RESET_EN False(0)
SW_RECOVERY_ON_ERRORS False(0)
RESET_WITH_HOST_ON_ERRORS False(0)
PCI_BUS0_RESTRICT_SPEED PCI_GEN_1(0)
PCI_BUS0_RESTRICT_ASPM False(0)
PCI_BUS0_RESTRICT_WIDTH PCI_X1(0)
PCI_BUS0_RESTRICT False(0)
PCI_DOWNSTREAM_PORT_OWNER Array[0…15]
CQE_COMPRESSION BALANCED(0)
IP_OVER_VXLAN_EN False(0)
MKEY_BY_NAME False(0)
UCTX_EN True(1)
PCI_ATOMIC_MODE PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
TUNNEL_ECN_COPY_DISABLE False(0)
LRO_LOG_TIMEOUT0 6
LRO_LOG_TIMEOUT1 7
LRO_LOG_TIMEOUT2 8
LRO_LOG_TIMEOUT3 13
ICM_CACHE_MODE DEVICE_DEFAULT(0)
TX_SCHEDULER_BURST 0
LOG_MAX_QUEUE 17
LOG_DCR_HASH_TABLE_SIZE 14
MAX_PACKET_LIFETIME 0
DCR_LIFO_SIZE 16384
ROCE_CC_PRIO_MASK_P1 255
ROCE_CC_CNP_MODERATION_P1 DEVICE_DEFAULT(0)
ROCE_CC_PRIO_MASK_P2 255
ROCE_CC_CNP_MODERATION_P2 DEVICE_DEFAULT(0)
CLAMP_TGT_RATE_AFTER_TIME_INC_P1 True(1)
CLAMP_TGT_RATE_P1 False(0)
RPG_TIME_RESET_P1 300
RPG_BYTE_RESET_P1 32767
RPG_THRESHOLD_P1 1
RPG_MAX_RATE_P1 0
RPG_AI_RATE_P1 5
RPG_HAI_RATE_P1 50
RPG_GD_P1 11
RPG_MIN_DEC_FAC_P1 50
RPG_MIN_RATE_P1 1
RATE_TO_SET_ON_FIRST_CNP_P1 0
DCE_TCP_G_P1 1019
DCE_TCP_RTT_P1 1
RATE_REDUCE_MONITOR_PERIOD_P1 4
INITIAL_ALPHA_VALUE_P1 1023
MIN_TIME_BETWEEN_CNPS_P1 4
CNP_802P_PRIO_P1 6
CNP_DSCP_P1 48
CLAMP_TGT_RATE_AFTER_TIME_INC_P2 True(1)
CLAMP_TGT_RATE_P2 False(0)
RPG_TIME_RESET_P2 300
RPG_BYTE_RESET_P2 32767
RPG_THRESHOLD_P2 1
RPG_MAX_RATE_P2 0
RPG_AI_RATE_P2 5
RPG_HAI_RATE_P2 50
RPG_GD_P2 11
RPG_MIN_DEC_FAC_P2 50
RPG_MIN_RATE_P2 1
RATE_TO_SET_ON_FIRST_CNP_P2 0
DCE_TCP_G_P2 1019
DCE_TCP_RTT_P2 1
RATE_REDUCE_MONITOR_PERIOD_P2 4
INITIAL_ALPHA_VALUE_P2 1023
MIN_TIME_BETWEEN_CNPS_P2 4
CNP_802P_PRIO_P2 6
CNP_DSCP_P2 48
LLDP_NB_DCBX_P1 False(0)
LLDP_NB_RX_MODE_P1 OFF(0)
LLDP_NB_TX_MODE_P1 OFF(0)
LLDP_NB_DCBX_P2 False(0)
LLDP_NB_RX_MODE_P2 OFF(0)
LLDP_NB_TX_MODE_P2 OFF(0)
ROCE_RTT_RESP_DSCP_P1 0
ROCE_RTT_RESP_DSCP_MODE_P1 DEVICE_DEFAULT(0)
ROCE_RTT_RESP_DSCP_P2 0
ROCE_RTT_RESP_DSCP_MODE_P2 DEVICE_DEFAULT(0)
DCBX_IEEE_P1 True(1)
DCBX_CEE_P1 True(1)
DCBX_WILLING_P1 True(1)
DCBX_IEEE_P2 True(1)
DCBX_CEE_P2 True(1)
DCBX_WILLING_P2 True(1)
KEEP_ETH_LINK_UP_P1 True(1)
KEEP_IB_LINK_UP_P1 False(0)
KEEP_LINK_UP_ON_BOOT_P1 False(0)
KEEP_LINK_UP_ON_STANDBY_P1 False(0)
DO_NOT_CLEAR_PORT_STATS_P1 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P1 False(0)
KEEP_ETH_LINK_UP_P2 True(1)
KEEP_IB_LINK_UP_P2 False(0)
KEEP_LINK_UP_ON_BOOT_P2 False(0)
KEEP_LINK_UP_ON_STANDBY_P2 False(0)
DO_NOT_CLEAR_PORT_STATS_P2 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P2 False(0)
NUM_OF_VL_P1 _4_VLs(3)
NUM_OF_TC_P1 _8_TCs(0)
NUM_OF_PFC_P1 8
VL15_BUFFER_SIZE_P1 0
NUM_OF_VL_P2 _4_VLs(3)
NUM_OF_TC_P2 _8_TCs(0)
NUM_OF_PFC_P2 8
VL15_BUFFER_SIZE_P2 0
DUP_MAC_ACTION_P1 LAST_CFG(0)
SRIOV_IB_ROUTING_MODE_P1 LID(1)
DUP_MAC_ACTION_P2 LAST_CFG(0)
SRIOV_IB_ROUTING_MODE_P2 LID(1)
PHY_FEC_OVERRIDE_P1 DEVICE_DEFAULT(0)
PHY_FEC_OVERRIDE_P2 DEVICE_DEFAULT(0)
PF_SD_GROUP 0
ROCE_CONTROL ROCE_ENABLE(2)
PCI_WR_ORDERING per_mkey(0)
MULTI_PORT_VHCA_EN False(0)
PORT_OWNER True(1)
ALLOW_RD_COUNTERS True(1)
RENEG_ON_CHANGE True(1)
TRACER_ENABLE True(1)
IP_VER IPv4(0)
BOOT_UNDI_NETWORK_WAIT 0
UEFI_HII_EN True(1)
BOOT_DBG_LOG False(0)
UEFI_LOGS DISABLED(0)
BOOT_VLAN 1
LEGACY_BOOT_PROTOCOL PXE(1)
BOOT_INTERRUPT_DIS False(0)
BOOT_LACP_DIS True(1)
BOOT_VLAN_EN False(0)
BOOT_PKEY 0
DYNAMIC_VF_MSIX_TABLE False(0)
EXP_ROM_UEFI_ARM_ENABLE False(0)
EXP_ROM_UEFI_x86_ENABLE False(0)
EXP_ROM_PXE_ENABLE True(1)
ADVANCED_PCI_SETTINGS False(0)
SAFE_MODE_THRESHOLD 10
SAFE_MODE_ENABLE True(1)
~# qm config 100
agent: 1
bios: ovmf
boot: order=scsi0
cores: 4
cpu: host,flags=+aes
efidisk0: storage:vm-100-disk-0,efitype=4m,size=4M
machine: q35
memory: 8192
meta: creation-qemu=9.0.0,ctime=1721405047
net0: virtio=00:0F:94:64:32:81,bridge=vmbr1,firewall=1
net1: virtio=BC:24:11:14:03:5D,bridge=vmbr2,firewall=1
numa: 0
onboot: 1
ostype: l26
scsi0: storage:vm-100-disk-1,backup=0,discard=on,iothread=1,size=32G,ssd=1
scsihw: virtio-scsi-single
smbios1: uuid=914847d4-9b9e-43eb-87f2-a9c012889b65
sockets: 1
startup: order=1
tablet: 0
vmgenid: 17d91629-98dd-4748-aff2-bf914a73759f
dmidecode 3.4
Getting SMBIOS data from sysfs.
SMBIOS 3.2.0 present.
Table at 0x73A5F000.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 1.D0
Release Date: 08/23/2023
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 32 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 5.17
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: Micro-Star International Co., Ltd.
Product Name: MS-7C77
Version: 1.0
Serial Number: Default string
UUID: 8847732e-cfae-4219-ab80-2cf05d7bf62d
Wake-up Type: Power Switch
SKU Number: Default string
Family: Default string
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Product Name: MEG Z490I UNIFY (MS-7C77)
Version: 1.0
Serial Number: K717347478
Asset Tag: Default string
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Default string
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 22 bytes
Chassis Information
Type: Desktop
Lock: Not Present
Version: 1.0
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
I ran out of ideas already. Any help will be much appreciated!
We not tested on Proxmox. In the mean time cx4-lx EOL long time ago.
You can try latest firmware see if it can work.
It’s already the latest one published on nvidia’s webpage.
ConnectX4LxEN: fw-ConnectX4Lx-rel-14_32_1010-MCX4121A-ACA_Ax-UEFI-14.25.17-FlexBoot-3.6.502
MD5SUM: 87ff1a8dfa120862017c44f527814903
SHA256: 729380524ac29e0b0981ad3f0b7aeb46f93da1f5e95e123f5a8c39bf6a29ff9a
Release Date: 5-Dec-21
./mlxup
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX4LX
Part Number: MCX4121A-ACA_Ax
PSID: MT_2420110034
PCI Device Name: /dev/mst/mt4117_pciconf0
Base MAC: 506b4b29a75a
Versions: Current Available
FW 14.32.1010 14.32.1010
PXE 3.6.0502 3.6.0502
UEFI 14.25.0017 14.25.0017
Status: Up to date
