I have been trying to configure my Mellanox NIC (MCX512A-ACAT) in order to have a 10G-BASE SR connection using SFP and fiber optic cables, to another board (a custom made board that supports the same type of connections). I have the following problems:
- I cannot set speed, duplex or autoneg via ethtool, using sudo/root.
The following outputs are produced:
ethtool -s enp6s0f1 autoneg off
Cannot set new settings: Operation not supported
not setting autoneg
ethtool -s enp6s0f1 duplex full
Cannot advertise duplex full
ethtool -s enp6s0f1 speed 10000
Cannot advertise speed 10000
- I have a link down, status that I cannot change in any way. Attempting the ip link set enp6s0f1 up returns nothing and does nothing.
Here are some outputs and some things I have found while trying to resolve this, that might be useful:
A) ifconfig
enp6s0f1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.2.50 netmask 255.255.255.248 broadcast 192.168.2.55
inet6 fe80::a75d:a26b:de27:4c78 prefixlen 64 scopeid 0x20
ether 98:03:9b:cc:82:a9 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
B) ethtool
Settings for enp6s0f1:
Supported ports: [ FIBRE ]
Supported link modes: 1000baseKX/Full
10000baseKR/Full
25000baseCR/Full
25000baseKR/Full
25000baseSR/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 1000baseKX/Full
10000baseKR/Full
25000baseCR/Full
25000baseKR/Full
25000baseSR/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000004 (4)
link
Link detected: no
C) ip addr show enp6s0f1
5: enp6s0f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 98:03:9b:cc:82:a9 brd ff:ff:ff:ff:ff:ff
inet 192.168.2.50/29 brd 192.168.2.55 scope global noprefixroute enp6s0f1
valid_lft forever preferred_lft forever
inet6 fe80::a75d:a26b:de27:4c78/64 scope link tentative noprefixroute
D) This occurs on both slots of the NIC, using different SFPs and cables (which however produce light, have been tested for being functional and reliable). Currently, I am attempting an external loopback on the fibers, which fails, I presume due to the link status.
E) I am able to use nmtui to configure and activate my connections.
F) dmesg | grep -e mlx5_core -e enp6s0f1
[ 1.365269] mlx5_core 0000:06:00.0: firmware version: 16.24.1000
[ 1.365306] mlx5_core 0000:06:00.0: 63.008 Gb/s available PCIe bandwidth (8 GT/s x8 link)
[ 1.580318] mlx5_core 0000:06:00.0: irq 74 for MSI/MSI-X
[ 1.580331] mlx5_core 0000:06:00.0: irq 75 for MSI/MSI-X
[ 1.580336] mlx5_core 0000:06:00.0: irq 76 for MSI/MSI-X
[ 1.580342] mlx5_core 0000:06:00.0: irq 77 for MSI/MSI-X
[ 1.580347] mlx5_core 0000:06:00.0: irq 78 for MSI/MSI-X
[ 1.580352] mlx5_core 0000:06:00.0: irq 79 for MSI/MSI-X
[ 1.580356] mlx5_core 0000:06:00.0: irq 80 for MSI/MSI-X
[ 1.580360] mlx5_core 0000:06:00.0: irq 81 for MSI/MSI-X
[ 1.580365] mlx5_core 0000:06:00.0: irq 82 for MSI/MSI-X
[ 1.580369] mlx5_core 0000:06:00.0: irq 83 for MSI/MSI-X
[ 1.580374] mlx5_core 0000:06:00.0: irq 84 for MSI/MSI-X
[ 1.580378] mlx5_core 0000:06:00.0: irq 85 for MSI/MSI-X
[ 1.580385] mlx5_core 0000:06:00.0: irq 86 for MSI/MSI-X
[ 1.580389] mlx5_core 0000:06:00.0: irq 87 for MSI/MSI-X
[ 1.580394] mlx5_core 0000:06:00.0: irq 88 for MSI/MSI-X
[ 1.580398] mlx5_core 0000:06:00.0: irq 89 for MSI/MSI-X
[ 1.581401] mlx5_core 0000:06:00.0: Port module event: module 0, Cable unplugged
[ 1.588381] mlx5_core 0000:06:00.1: firmware version: 16.24.1000
[ 1.588437] mlx5_core 0000:06:00.1: 63.008 Gb/s available PCIe bandwidth (8 GT/s x8 link)
[ 1.808030] mlx5_core 0000:06:00.1: irq 91 for MSI/MSI-X
[ 1.808036] mlx5_core 0000:06:00.1: irq 92 for MSI/MSI-X
[ 1.808041] mlx5_core 0000:06:00.1: irq 93 for MSI/MSI-X
[ 1.808046] mlx5_core 0000:06:00.1: irq 94 for MSI/MSI-X
[ 1.808051] mlx5_core 0000:06:00.1: irq 95 for MSI/MSI-X
[ 1.808056] mlx5_core 0000:06:00.1: irq 96 for MSI/MSI-X
[ 1.808061] mlx5_core 0000:06:00.1: irq 97 for MSI/MSI-X
[ 1.808065] mlx5_core 0000:06:00.1: irq 98 for MSI/MSI-X
[ 1.808069] mlx5_core 0000:06:00.1: irq 99 for MSI/MSI-X
[ 1.808074] mlx5_core 0000:06:00.1: irq 100 for MSI/MSI-X
[ 1.808078] mlx5_core 0000:06:00.1: irq 101 for MSI/MSI-X
[ 1.808082] mlx5_core 0000:06:00.1: irq 102 for MSI/MSI-X
[ 1.808087] mlx5_core 0000:06:00.1: irq 103 for MSI/MSI-X
[ 1.808091] mlx5_core 0000:06:00.1: irq 104 for MSI/MSI-X
[ 1.808096] mlx5_core 0000:06:00.1: irq 105 for MSI/MSI-X
[ 1.808100] mlx5_core 0000:06:00.1: irq 106 for MSI/MSI-X
[ 1.809457] mlx5_core 0000:06:00.1: Port module event: module 1, Cable plugged
[ 1.816221] mlx5_core 0000:06:00.0: slow_pci_heuristic:4521:(pid 321): Max link speed = 25000, PCI BW = 63008
[ 1.816289] mlx5_core 0000:06:00.0: MLX5E: StrdRq(1) RqSz(8) StrdSz(2048) RxCqeCmprss(0)
[ 1.945731] mlx5_core 0000:06:00.1: MLX5E: StrdRq(1) RqSz(8) StrdSz(2048) RxCqeCmprss(0)
[ 6.913876] mlx5_core 0000:06:00.0 enp6s0f0: Link down
[ 6.919262] IPv6: ADDRCONF(NETDEV_UP): enp6s0f1: link is not ready
[ 6.985507] mlx5_core 0000:06:00.1 enp6s0f1: Link down
[ 6.988709] IPv6: ADDRCONF(NETDEV_UP): enp6s0f1: link is not ready
[ 17.441260] IPv6: ADDRCONF(NETDEV_UP): enp6s0f1: link is not ready
[ 17.443918] IPv6: ADDRCONF(NETDEV_UP): enp6s0f1: link is not ready
[69629.698456] mlx5_core 0000:06:00.1: Port module event: module 1, Cable unplugged
[69639.097465] mlx5_core 0000:06:00.1: Port module event: module 1, Cable plugged
[69720.194832] mlx5_core 0000:06:00.0: Port module event: module 0, Cable plugged
[146454.650697] IPv6: ADDRCONF(NETDEV_UP): enp6s0f1: link is not ready
[146529.819726] IPv6: ADDRCONF(NETDEV_UP): enp6s0f1: link is not ready
G) cat /etc/centos-release: CentOS Linux release 7.9.2009 (Core)
I apologize for the long post, and can provide any additional information. I have checked to the best of my ability all user guides and online resolutions, but if you have any suggestions they could be very helpful!
Mary
