Hello.
I purchased a ConnectX-5 VPI adapter card (MCX555A-ECAT) and have it running in a PCIe 4.0 x16 slot on my new H12SSL-i motherboard. OS is Windows 2019.
I’m using a Mellanox MSX6005F-2BFS Switch and new MC2207128-003 passive copper cable.
The subnet manager (opensm) is running on a CentOS with connectx-2 vpi card.
@strsrv ~]$ sudo cat /etc/system-release
CentOS Linux release 7.9.2009 (Core)
@strsrv ~]$ sudo yum info opensm-3.3.21-4.el7_9.x86_64>
Installed Packages
Arch : x86_64
Version : 3.3.21
Release : 4.el7_9
Repo : installed
From repo : updates
Summary : OpenIB InfiniBand Subnet Manager and management utilities
@strsrv ~]$ lspci | grep Mellanox
82:00.0 Network controller: Mellanox Technologies MT25408A0-FCC-QI ConnectX, Dual Port 40Gb/s InfiniBand / 10GigE Adapter IC with PCIe 2.0 x8 5.0GT/s In… (rev b0)
My problem is the ConnectX-5 card never gets a link on the Windows side when connected to the SX6005 Switch. Despite trying different cables and using the current version of WinOF-2 and firmware.
Not working:
c:\Program Files\Mellanox\MLNX_WinOF2\Management Tools>mlx5cmd -dbg -pddrinfo
NIC 1:
Adapter: Mellanox ConnectX-5 Adapter
Location (PCI bus, device, function): (129,0,0)
Operational Info
State : Polling
Active protocol : InfiniBand
Physical state : 0
Active link width : Unknown
Enabled PHY manager link width : {1x}
Enabled core to PHY link width : {1x}
Active link speed : Unknown
Enabled PHY manager link speed : {SDR, DDR, QDR, FDR10, FDR, EDR}
Enabled core to PHY link speed : {SDR, DDR, QDR, FDR10, FDR}
Active negotiation mode : 4
Loopback mode : 0
FEC : 0
Cable supported speeds : {SDR, DDR, QDR, FDR10, FDR}
Troubleshoot Info
Status Opcode : 2
Group Opcode : 0
Message : Negotiation failure
c:\Program Files\Mellanox\WinMFT>flint -d mt4119_pciconf0 query
Image type: FS4
FW Version: 16.35.3006
FW Release Date: 6.7.2023
Product Version: 16.35.3006
Rom Info: type=UEFI version=14.29.15 cpu=AMD64
type=PXE version=3.6.902 cpu=AMD64
Description: UID GuidsNumber
Base GUID: 506b4b030043fb22 4
Base MAC: 506b4b43fb22 4
Image VSD: N/A
Device VSD: N/A
PSID: MT_0000000010
Security Attributes: N/A
c:\Program Files\Mellanox\WinMFT>mlxlink -d mt4119_pciconf0
Operational Info
State : Polling
Physical state : ETH_AN_FSM_ABILITY_DETECT
Speed : N/A
Width : N/A
FEC : N/A
Loopback Mode : No Loopback
Auto Negotiation : ON
Supported Info
Enabled Link Speed : 0x0000001f (FDR,FDR10,QDR,DDR,SDR)
Supported Cable Speed : 0x0000001f (FDR,FDR10,QDR,DDR,SDR)
Troubleshooting Info
Status Opcode : 2
Group Opcode : PHY FW
Recommendation : Negotiation failure
Tool Information
Firmware Version : 16.35.3006
MFT Version : mft 4.26.1-3
C:\Users\Administrator.XTC41>mlxcables
Querying Cables …
Cable #1:
Cable name : mt4119_pciconf0_cable_0
No FW data to show
-------- Cable EEPROM --------
Identifier : QSFP+ (0dh)
Technology : Copper cable unequalized (a0h)
Compliance : 40GBASE-CR4, FDR,QDR,DDR,SDR
Attenuation: 2.5GHz : 6dB
5.0GHz : 10dB
7.0GHz : 13dB
12.9GHz : 0dB
25.78GHz : 0dB
OUI : 0x0002c9
Vendor : Mellanox
Serial number : MT2022VS01614
Part number : MC2207128-003
Revision : A3
Temperature [c] : N/A
Digital Diagnostic Monitoring : NO
Length [m] : 3 m
If I connect the ConnectX-2 card to the ConnectX-5 card back to back (no SX6005 Switch) with the same FDR cable (MC2207128-003) both sides show link up.
If I remove the and FDR cable from a working connectx-2 card and put it in the connectx-5 card leaving the port side alone on the SX6005 Switch, the connectx-5 comes up. Then taking one of the new FDR cables and using another port on the Switch and attach it to the connectx-2 card, it doesn’t link up.
ConnectX-5 Card when its up:
NIC 1:
Operational Info
State : Active
Physical state : 7
Active link width : {4x}
Active link speed : {FDR}
Active negotiation mode : 1
Loopback mode : 0
FEC : 0
Troubleshoot Info
Status Opcode : 0
Group Opcode : 0
Message : No issue was observed
C:\Program Files\Mellanox\WinMFT>mlxlink -d mt4119_pciconf0
Operational Info
State : Active
Physical state : LinkUp
Speed : IB-FDR
Width : 4x
FEC : No FEC
Supported Info
Status Opcode : 0
Group Opcode : N/A
Recommendation : No issue was observed
Tool Information
Firmware Version : 16.35.3502
Can someone explain what’s going on here?
