Trouble with ConnectX-3 VPI adapter card over XenServer 6.2 (Service Pack 1)
Hi all,
we are trying to use a ConnectX-3 VPI adapter card over XenServer 6.2, for this we have followed the following steps:
  1. Install XenServer 6.2 on my system (Supermicro 1027GR-TRF)
  2. Install XenServer 6.2 updates (service pack 1) following the directions from http://support.citrix.com/article/CTX138115#XenServer 6.2 http://support.citrix.com/article/CTX138115#XenServer%206.2
  3. Install MLNX_OFED 2.1-1.0.6 and update firmware (./mlnxofedinstall --force-fw-update). Installation and update have been completed without errors. The firmware version is 2.30.8000.
After that, we have restarted the system and the openibd service but the InfiniBand network interfaces have not been detected:
[root@xenserver ~]# /etc/init.d/openibd restart
hostname: `Host’ unknown
Unloading HCA driver: [ OK ]
Loading HCA driver and Access Layer: [ OK ]
Setting up InfiniBand network interfaces:
Setting up service network . . . [ done ]
I.e. the ib0 network interface has not been detected by the system.
Do you know if XenServer 6.2 works with ConnectX-3? Could you please get some information about that? We have devoted a lot of time and now we wonder whether it really works.
Hi iliyasa, thank you for your reply.
I can not install the version 1.5.3-4.0.42. I have installed the Driver Development Kit for XenServer 6.2.0 (Service Pack 1) and I’m trying to build ofed modules against the 2.6.32.43-0.4.1.xs1.8.0.847.170785xen kernel but I get the following error:
./mlnx_add_kernel_support.sh -m /mnt/tmp/MLNX_OFED_LINUX-1.5.3-4.0.42-xenserver-i686/ -t /mnt/tmp/temp --make-tgz -v
Note: This program will create MLNX_OFED_LINUX TGZ for rhel5.7 under /tmp directory.
All Mellanox, OEM, OFED, or Distribution IB packages will be removed.
Do you want to continue?[y/N]:y
See log file /tmp/mlnx_ofed_iso.4237.log
Detected MLNX_OFED_LINUX-1.5.3-4.0.42
Running cp -a /mnt/tmp/MLNX_OFED_LINUX-1.5.3-4.0.42-xenserver-i686/ /mnt/tmp/temp/mlnx_iso.4237/MLNX_OFED_LINUX-1.5.3-4.0.42-rhel5.7-i686
Running tar xzf /mnt/tmp/temp/mlnx_iso.4237/MLNX_OFED_LINUX-1.5.3-4.0.42-rhel5.7-i686/src/MLNX_OFED_SRC-1.5.3-4.0.42.tgz
Building OFED RPMs. Please wait…
Running MLNX_OFED_SRC-1.5.3-4.0.42/install.pl -c /mnt/tmp/temp/mlnx_iso.4237/ofed.conf --kernel 2.6.32.43-0.4.1.xs1.8.0.847.170785xen --kernel-sources /lib/modules/2.6.32.43-0.4.1.xs1.8.0.847.170785xen/build/ --builddir /mnt/tmp/temp/mlnx_iso.4237 --disable-kmp
ERROR: Failed executing “MLNX_OFED_SRC-1.5.3-4.0.42/install.pl -c /mnt/tmp/temp/mlnx_iso.4237/ofed.conf --kernel 2.6.32.43-0.4.1.xs1.8.0.847.170785xen --kernel-sources /lib/modules/2.6.32.43-0.4.1.xs1.8.0.847.170785xen/build/ --builddir /mnt/tmp/temp/mlnx_iso.4237 --disable-kmp”
ERROR: See /tmp/mlnx_ofed_iso.4237.log
The log file does not show additional info:
cxgb3 is not available on this platform
qib is not available on this platform
knem is not available on this platform
ib-bonding is not available on this platform
Below is the list of OFED packages that you have chosen
(some may have been added by the installer due to package dependencies):
ofed-scripts
kernel-ib
kernel-ib-devel
kernel-mft
Build ofed-scripts RPM
Running rpmbuild --rebuild --define ‘_topdir /mnt/tmp/temp/mlnx_iso.4237/OFED_topdir’ --define ‘dist %{nil}’ --target i386 --define ‘_prefix /usr’ --define ‘_exec_prefix /usr’ --define ‘_sysconfdir /etc’ --define ‘_usr /usr’ /mnt/tmp/temp/mlnx_iso.4237/MLNX_OFED_SRC-1.5.3-4.0.42/SRPMS/ofed-scripts-1.5.3-OFED.1.5.3.4.0.42.src.rpm
Install ofed-scripts RPM:
Running rpm -iv /mnt/tmp/temp/mlnx_iso.4237/MLNX_OFED_SRC-1.5.3-4.0.42/RPMS/centos-release-5-7.el5.centos/i686/ofed-scripts-1.5.3-OFED.1.5.3.4.0.42.i386.rpm
Build ofa_kernel RPM
Running rpmbuild --rebuild --define ‘_topdir /mnt/tmp/temp/mlnx_iso.4237/OFED_topdir’ --define ‘_target_cpu i686’ --nodeps --define ‘_dist .rhel5u7’ --define ‘configure_options --with-core-mod --with-user_mad-mod --with-user_access-mod --with-addr_trans-mod --with-mthca-mod --with-mlx4-mod --with-mlx4_en-mod --with-mlx4_ib-mod --with-mlx4_vnic-mod --with-nes-mod --with-ipoib-mod --with-sdp-mod --with-srp-mod --with-rds-mod’ --define ‘build_kernel_ib 1’ --define ‘build_kernel_ib_devel 1’ --define ‘KVERSION 2.6.32.43-0.4.1.xs1.8.0.847.170785xen’ --define ‘K_SRC /lib/modules/2.6.32.43-0.4.1.xs1.8.0.847.170785xen/build/’ --define ‘network_dir /etc/sysconfig/network-scripts’ --define ‘_prefix /usr’ --define ‘__arch_install_post %{nil}’ /mnt/tmp/temp/mlnx_iso.4237/MLNX_OFED_SRC-1.5.3-4.0.42/SRPMS/ofa_kernel-1.5.3-OFED.1.5.3.4.0.42.g3cb72fe.src.rpm
kernel-ib was not created
Hello Iliyasa,
yes, I installed the additional packages required by the driver, I used the CentOS Base.repo for this, is that correct?
There seems to be a problem loading the mlx4_core module, dmesg looks like this:
[ 2668.552338] mlx4_core: Mellanox ConnectX core driver v1.1 (Apr 29 2014)
[ 2668.552341] mlx4_core: Initializing 0000:01:00.0
[ 2668.552429] mlx4_core 0000:01:00.0: PCI INT A → GSI 16 (level, low) → IRQ 16
[ 2668.552538] mlx4_core 0000:01:00.0: setting latency timer to 64
[ 2674.974496] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.976285] mlx4_core 0000:01:00.0: irq 1265 (313) for MSI/MSI-X
[ 2674.976287] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.977975] mlx4_core 0000:01:00.0: irq 1264 (312) for MSI/MSI-X
[ 2674.977977] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.979637] mlx4_core 0000:01:00.0: irq 1263 (311) for MSI/MSI-X
[ 2674.979639] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.981309] mlx4_core 0000:01:00.0: irq 1262 (310) for MSI/MSI-X
[ 2674.981311] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.982980] mlx4_core 0000:01:00.0: irq 1261 (309) for MSI/MSI-X
[ 2674.982982] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.984659] mlx4_core 0000:01:00.0: irq 1260 (308) for MSI/MSI-X
[ 2674.984661] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.986341] mlx4_core 0000:01:00.0: irq 1259 (307) for MSI/MSI-X
[ 2674.986343] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.988054] mlx4_core 0000:01:00.0: irq 1258 (306) for MSI/MSI-X
[ 2674.988056] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.989742] mlx4_core 0000:01:00.0: irq 1257 (305) for MSI/MSI-X
[ 2674.989744] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2674.991413] mlx4_core 0000:01:00.0: irq 1256 (304) for MSI/MSI-X
[ 2735.064254] mlx4_core 0000:01:00.0: command CONF_SPECIAL_QP (0x23) timed out: in_param=0x0, in_mod=0x40, op_mod=0x0, get_status err=0, status_reg=0x23006000, go_bit=0, t_bit=1, toggle=0x0
[ 2735.064266] mlx4_core 0000:01:00.0: Failed to initialize queue pair table (err=1), aborting.
[ 2735.106905] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.108107] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.109302] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.110502] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.111699] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.112901] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.114100] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.115299] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.116498] mlx4_core 0000:01:00.0: get owner: 7ff0
[ 2735.117701] mlx4_core 0000:01:00.0: get owner: 7ff0
Have you had any similar problem?
Thanks in advance.
Actually I meant MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686. I have tried this driver and xenserver was able to pick up the card but the driver has put this into Ethernet mode. I’m trying to see why it has done this but this maybe a a separate issue or related. I’ll try with a different card and follow-up.
Edit: I try to change it to IB but it tells me it is an Illegal port configuration attempted.
Hi !
you’re right. after installing OFED 1.5.4, my system can detect ib0, and it works!
thanks for your help
I don’t think your card is supported. Please check you card model and psid and goto the firmware download page for its latest firmware.
Updating Firmware for Single Port InfiniHost™ III Lx MemFree PCI Express HCA Cards - Mellanox Technologies Firmware for Single Port InfiniHost™ III Lx Cards
Hi, I have tried with MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686 and the firmware update, but I have obtained the same results that was shown on the first post. So I have some questions:
Did you use XenServer 6.2 (Service Pack 1)?
What’s the command used to install the ofed? (I have used ./mlnxofedinstall --force-firmware-update)
Did you use another additional driver or only the mlnx_ofed software stack?
Thank you in advance.
Ok I’ve had success with a different card as I was Ethernet card before.
[root@xenserver6 ~]# /root/MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686/mlnxofedinstall --fw-update-only
Logs dir: /tmp/MLNX_OFED_LINUX-2.2-1.0.1.10792.logs
Attempting to perform Firmware update…
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX3
Part Number: MCX353A-FCB_A2-A5
Description: ConnectX-3 VPI adapter card; single-port QSFP; FDR IB (56Gb/s) and 40GigE; PCIe3.0 x8 8GT/s; RoHS R6
PSID: MT_1100120019
PCI Device Name: 0000:04:00.0
Versions: Current Available
FW 2.30.8000 2.31.5050
PXE 3.4.0151 3.4.0225
Status: Update required
Found 1 device(s) requiring firmware update…
Device #1: Updating FW … Done
Restart needed for updates to take effect.
Log File: /tmp/MLNX_OFED_LINUX-2.2-1.0.1.10792.logs/fw_update.log
Please reboot your system for the changes to take effect.
[root@xenserver6 ~]# /sbin/connectx_port_config -s --------------------------------
Port configuration for PCI device: 0000:04:00.0 is:
auto (ib)
[root@xenserver6 ~]# flint -d /dev/mst/mt4099_pci_cr0 q
Image type: FS2
FW Version: 2.31.5050
FW Release Date: 30.4.2014
Product Version: 02.31.50.50
Rom Info: type=PXE version=3.4.225 devid=4099 proto=VPI
Device ID: 4099
Description: Node Port1 Port2 Sys image
GUIDs: 0002c903001e8a20 0002c903001e8a21 0002c903001e8a22 0002c903001e8a23
MACs: 0002c91e8a20 0002c91e8a21
VSD:
PSID: MT_1100120019
[root@xenserver6 ~]# ibstat
CA ‘mlx4_0’
CA type: MT4099
Number of ports: 1
Firmware version: 2.31.5050
Hardware version: 1
Node GUID: 0x0002c903001e8a20
System image GUID: 0x0002c903001e8a23
Port 1:
State: Down
Physical state: Polling
Rate: 10
Base lid: 0
LMC: 0
SM lid: 0
Capability mask: 0x02514868
Port GUID: 0x0002c903001e8a21
Link layer: InfiniBand
[root@xenserver6 ~]# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:25:90:C9:31:44
UP BROADCAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
eth1 Link encap:Ethernet HWaddr 00:25:90:C9:31:45
inet6 addr: fe80::225:90ff:fec9:3145/64 Scope:Link
UP BROADCAST RUNNING PROMISC MTU:1500 Metric:1
RX packets:731 errors:0 dropped:0 overruns:0 frame:0
TX packets:382 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:154168 (150.5 KiB) TX bytes:50319 (49.1 KiB)
ib0 Link encap:InfiniBand HWaddr A0:00:01:00:FE:80:00:00:00:00:00:00:00:0 0:00:00:00:00:00:00
BROADCAST MULTICAST MTU:4092 Metric:1
collisions:0 txqueuelen:128
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:24 errors:0 dropped:0 overruns:0 frame:0
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:14979 (14.6 KiB) TX bytes:14979 (14.6 KiB)
xenbr0 Link encap:Ethernet HWaddr 00:25:90:C9:31:44
inet6 addr: fe80::225:90ff:fec9:3144/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:468 (468.0 b)
xenbr1 Link encap:Ethernet HWaddr 00:25:90:C9:31:45
inet addr:192.168.50.1 Bcast:192.168.50.255 Mask:255.255.255.0
RX packets:732 errors:0 dropped:0 overruns:0 frame:0
TX packets:389 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:154228 (150.6 KiB) TX bytes:52753 (51.5 KiB)
Have you tried version 1_5_3-4_0_42 instead? You may need to contact Mellanox support for XenServer driver.
Yes, XenServer SP1 with all updates. And just by running ./mlnxofedinstall
Might I ask did you install the additional packages required by the driver? Before you install MLNX_OFED 2.2.
yum install pciutils python libxml2-python libnl expat glib2 tcl bc libstdc++ tk
Hi. I have same problem. can you help me?
I also use XenServer 6.2 SP1 and installed MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686.
but my server couldn’t find ib0.
heres some output :
[root@Epiclesis MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686]# ./mlnxofedinstall --fw-update-only
Logs dir: /tmp/MLNX_OFED_LINUX-2.2-1.0.1.10272.logs
Device #1:
Device Type: InfiniHostIIILx
Part Number: –
Description:
PSID:
PCI Device Name: 0000:07:00.0
FW –
Status: Failed to open device
-E- Failed to query 0000:07:00.0 device, error : No such file or directory MFE_OLD_DEVICE_TYPE
Log File: /tmp/MLNX_OFED_LINUX-2.2-1.0.1.10272.logs/fw_update.log
Failed to update Firmware.
See /tmp/MLNX_OFED_LINUX-2.2-1.0.1.10272.logs/fw_update.log
To load the new driver, run:
[root@Epiclesis MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686]# mst start
Starting MST (Mellanox Software Tools) driver set
[warn] mst_pci is already loaded, skipping
[warn] mst_pciconf is already loaded, skipping
Create devices
-W- Missing “lsusb” command, skipping MTUSB devices detection
[root@Epiclesis MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686]# mst status
MST modules:
MST PCI module loaded
MST PCI configuration module loaded
MST devices:
/dev/mst/mt25204_pciconf0 - PCI configuration cycles access.
domain:bus:dev.fn=0000:07:00.0 addr.reg=88 data.reg=92
Chip revision is: A0
/dev/mst/mt25204_pci_cr0 - PCI direct access.
domain:bus:dev.fn=0000:07:00.0 bar=0xc4100000 size=0x100000
[root@Epiclesis MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686]# flint -d /dev/mst/mt25204_pci_cr0 q
-E- Cannot open Device: /dev/mst/mt25204_pci_cr0. Operation not permitted MFE_OLD_DEVICE_TYPE
[root@Epiclesis MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686]# hca_self_test.ofed
---- Performing Adapter Device Self Test ----
Number of CAs Detected … 1
PCI Device Check … PASS
Kernel Arch … i686
Host Driver Version … MLNX_OFED_LINUX-2.2-1.0.1 (OFED-2.2-1.0.0): 2.6.32.43-0.4.1.xs1.8.0.847.170785xen
Host Driver RPM Check … PASS
Firmware on CA #0 HCA … v1.2.0
Firmware Check on CA #0 (HCA) … NA
REASON: NO required fw version
Host Driver Initialization … PASS
Number of CA Ports Active … 1
Port State of Port #1 on CA #0 (HCA)… UP 4X (InfiniBand)
Error Counter Check on CA #0 (HCA)… PASS
Kernel Syslog Check … PASS
Node GUID on CA #0 (HCA) … 00:08:f1:04:03:99:2c:d4
------------------ DONE ---------------------
[root@Epiclesis MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686]# ibstat
CA ‘mthca0’
CA type: MT25204
Number of ports: 1
Firmware version: 1.2.0
Hardware version: a0
Node GUID: 0x0008f10403992cd4
System image GUID: 0x0008f10403992cd7
Port 1:
State: Active
Physical state: LinkUp
Rate: 10
Base lid: 2
LMC: 0
SM lid: 1
Capability mask: 0x02510a68
Port GUID: 0x0008f10403992cd5
[root@Epiclesis MLNX_OFED_LINUX-2.2-1.0.1-xenserver6.x-i686]# lspci|grep Mella
07:00.0 InfiniBand: Mellanox Technologies MT25204 [InfiniHost III Lx HCA] (rev a0)
I really appreciate any help. thanks.
Hi all,
Finally the problem was fixed. After several tests, it seems that the problem was due to hardware incompatibility.
We have repeated the same steps in other node (with different integrated board) and all seems to be ok.
